Question about Philips 55PP9363 55" Rear Projection HDTV-Ready Television
Multipoint (Blue) Off
My television gives me a headache now when I watch it, because I have blue halos all over. Everybody has a blue shadow above or on the side of there head, and objects are the same way. I have tried fixing the multipoint, which does not work. The arrows are hard to push and once you fix one side and go to the other side, the first side you fixed is off. I am ready to throw the television out the door.
  • 934 Answers
It sounds like the convergence amp need to be replaced. That unit is a DPTV335 chassis and IC 7044 is an STK392-120. That together with all feed resistors for that circuit need to be tested for change in value.. Before doing that you might also check to see if the blue crt yoke is up tight in place and not tilted. Have you moved the TV at all recently, before this problem happened?? If so the yokes on these units have been known to slip down. You can look at this yourself by removing the frony covers and exposing the CRT area. Look at the blue yoke, comparing it to all the rest. Make sure to do this with the unit unplugged. At the back of the yoke you'll see a set screw that clamps the immediate rear of the yoke If the yoke has slipped it will be noticeably lower than the rest by comparison. If ANY of this sounds too complicated it's shop time. But replacing the repair to the convergence circuit isn't difficult. You might also ask as you're calling around the shops if they have that STK on-hand.. Also, take the unit in and you'll save on the cost of having the shop transport it... Good Luck Bill
Posted on Jun 10, 2007
SOURCE:
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Televison & Video
Halo around blue, extremely bad when watching
The CRT coolant in the Blue CRT needs replacement. The green will soon follow. Very common problem with phillips. You can get the phillips CRT coolant kit from www.tvrepairworld.com which contains the coolant and the CD with instructions.
May 10, 2010 | Philips 60PP9363 60" Rear Projection...
51 philips yellow streak
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 24, 2009 | Televison & Video
I have a yellow line on the right side of my Toshiba 50 rear projection TV and yellow shadows around people
It sounds like a convergence problem---go into the customer menu and select convergence---set should offer center and multipoint adjustment--in the multipoint look to see if the outer crosses adjust--if red or blue will not adjust somewhere--bad convergence IC's.
Jul 17, 2009 | Toshiba 42H83 42" Rear Projection...
Picture has a blue shadow
Seems convergence out IC is fried in TV so it gives blue shadow.
Check out Convergence Out IC which you need to replace in TV, if you have enough experience of repair of big TV, necessary tools and know basic electronics.
Dec 18, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Magnavox 51MP392H -- Multipoint Converge blue faded around edges
hey guys here is a great thread on this subject, its were I posted most of my pictures and there is a link to the manual in there. hope this helps,
BTW, IF ANY OF YOU GIVE UP ON YOUR 51MP392H/17 PLEASE LET ME KNOW!!!! I WANT TO BUY YOUR CONVERGENCE BOARD... "I killed mine" edwinkraus@hotmail.com
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/?page=1
Sep 29, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips nr.43pp7445/69
I don't understand you language but I think you need both convergence amplifier IC's replaced. I hope this helps.
Aug 17, 2008 | Philips 60P8341 60" Rear Projection...
Blue Multipoint converge failure Philips 55PP9753
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 12, 2008 | Philips 55PP9753 55" Rear Projection...
Blue Halos around people, objects
Sounds like coolant in the CRTs need changing. Blue is always the first color to get contaminated. Hope this helps.
Jan 11, 2008 | Proscan PS50700 50" Rear Projection...
Philips 55PP9363 55" Rear Projection HDTV-Ready Television Logo
60 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
