Question about Canon PowerShot SX20 IS Digital Camera
My pc won't detect my Canon powershot sx20is when turned on and connected with a cable
  • Cindy Weber Dec 10, 2012
    hunnypots, your advice solve my problem within minutes. Thanks to everyone for your help. :-)
angelo_mlc
  • 1035 Answers
SOURCE: Trying to download my pictures from Canon
Supported windows Operating system Windows 98 Second edition(SE)
Windows Me
Windows 2000 Service pack 4
Windows XP SP 1 and SP 2 Canon PowerShot A430 has no update about the new driver software for windows 7 Try doing this direct transfer in your computer 1. Connect the camera to your computer using the supplied USB cable of your camera. 2. Set the mode dial to (playback) and turn on the power.
The camera and computer will be able to communicate. 3. If there is no pop up window that has Canon CameraWindow, Click the [Start] menu and select [all Programs] or [Programs]. followed by [Canon Utilities], [Camera Window], [PowerShot-IXY-IXUS-DV 6] and [CameraWindow] 4. Download the images.
* Download the images using the camera or the computer.
* By default, the downloaded images are saved into the [My Pictures] folder. ** If the above process does not work you can just use the memory card of your camera and connect that on your laptop. (some laptop has built in card reader) The memory card works like a flash drive and you can just transfer files like transferring from one folder to another. ** Issue on the operating system compatibility.
Posted on Apr 14, 2010
SOURCE: Unable to download through usb
I had the same problem and realized that my computer wasn't recognizing my camera. I went through my device manager and looked under portable devices, I could see that my camera had an error in its driver, so I right clicked on my camera and uninstalled the driver for my camera, and unplugged and plugged my camera back in. It instantly recognized my camera and reinstalled the driver.
Posted on Jan 13, 2008
MrsJGreen
  • 130 Answers
SOURCE: Canon PowerShot SX100 is : Need
Here are the steps to take.
1. Establish whether or not you have a connection between your camera/computer by going to your start button, control panel, system, hardware tab and device manager. The camera must be powered on and in playback mode (should automatically go to playback mode when connected, camera's screen should go black if there is a connection). Make sure you have a fully or nearly fully charged battery in your camera.
2. Once in device manager, look under Imaging Devices. If your camera is properly connected it should show up as Canon Powershot SD800. If it shows a yellow exclamation point, there is a driver issue, and even if it doesn't show a yellow exclamation point, you may want to update your driver anyway by right clicking and having the system search automatically for driver updates. If download of driver begins, great...once finished, restart camera and your problem may be resolved.
3. If there are any other imaging devices, you may have to temporarily disable them to avoid conflicts.
4. If you have any other imaging software running, exit or close the program in your system tray (down by your clock in the right hand corner of your computer's desktop.
5. Try again to connect.
6. If you are on a desktop, try a rear usb port vs. a front port. You can also try a different port on a laptop. After each change, try restarting camera to establish connection.
7. Go to start/My Computer and look for the icon for your camera...you will be able to download images even without Canon software loaded onto computer so this is not a software issue if you have no hardware connection. If you see the icon, right click on it and choose Get or Import pictures. From there the default Microsoft scanner and camera wizard should launch and you will be able to import your images.
8. If still no connection, try going to Start/Run and type in services.msc here you are looking for 4 services to be running. Check under status of each service and make sure it reads that each of these services are started.
  • Canon Camera Access Library 8 (if Canon software loaded)
  • SSDP discovery service
  • Universal Plug and Play Device Host
  • Windows Image Acquisition
Once all of these services are started on your computer, restart camera once again. If any of the last three services are not on your computer or are not started, connecting will be a problem.
If all of these steps fail, try purchasing an SD card reader from your local electronics store for around $12 and download images from there. Canon also offers lifetime technical support for your Powershot, so give them a call if none of these steps work or if you would like someone to walk you through it.
Best of luck to you!
MrsJGreen
Posted on May 30, 2008
vickygomar
  • 460 Answers
SOURCE: can't upload pictures to computer doesn't show USB connection
am not sure how offten do you used the USB but in my case I use it frecuentely I own a kodak and I have to replace the USB cord at list every 4-5 times i use it.
I recomend u to buy a new one if this works the problem was in your old cord but if this wont work either you can returne the USB cord, its only to see if your old cord is the problem wish am 99.99% that it is .
Your rating and VOTE is very important to me....
I hope this information was helpful?
I like to tank you for the oportunity you give me to serve you .
please if you have any question or concer please e-mail me, I will be more then happy to assist you.
Sincerely
vickygomar
Posted on Jul 25, 2009
Dissolu
  • 221 Answers
SOURCE: Canon Powershot A1000 IS is connected, shows up in
Reinstall camera drivers from original Canon source
Posted on Aug 03, 2009
Download manuals free
unable to find service manual . try downloading on torrent sites. posted a youtube link hope this helps Repair or Rebuild Canon Powershot SX10 SX20 SX1 lens
Aug 22, 2014 | Canon Digital Camera PowerShot SX20IS...
My computer won't offload my pictures from my camera.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Dec 08, 2012 | Canon PowerShot A470 Digital Camera
Canon G12 does not connect to USB cable, gives error E41
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Sep 23, 2012 | Canon Powershot G12 10 Megapixel-5x...
Camera won't connect to computer
Make sure the camera is on, and the selector is on the 'setup' spot. Batteries should be fresh, and a memory stick should be in the camera.
What does the manual say?
You can also have the computer search for recently attached hardware.
Mar 16, 2012 | Canon PowerShot SD780 IS / IXUS 100 IS...
I have a Canon sx20IS when I connect in my computer, I can't find it. I need transfer my pictures to computer for the cable but I can't get it. Is it a driver problem?
Welcome to Fixya
Try the alternate way of transferring the pictures to your computer instead of using cable.
To download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer. Once the card is plugged in, it will appear to your computer as a removable drive. Just drag&drop pictures from the card to the computer's hard drive, the same way you copy any other files.
Cheers
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 21, 2011 | Canon PowerShot SX20 IS Digital Camera
I have canon powershot SX20IS. But it didn't connect to my laptop. My laptop and cable is ok. what should i do?
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Dec 16, 2010 | Canon PowerShot SX20 IS Digital Camera
Using transcend 16gb with canon powershot sx20is. getting memory card error. Please help.
It might just want you to format the card in the camera. This will completely erase it so download any pictures from it first.
Feb 02, 2010 | Canon PowerShot SX20 IS Digital Camera
Problem is following - computer can't detect canon cameras, i mean eos and powershot a590is. drivers are installed from solution disk, included with powershot /v.33.0/. nothing works, not cameraWindow, nor...
TRY TO USE A DIFFERENT DATA CABLE, OR BETTER TEST THE CAMERA BY CONNECTING IT TO ANOTHER PC, THIS WAY WE WILL KNOW IF YOU HAD A PROBLEM WITH YOUR DATA CABLE OR YOU PC,
Jul 08, 2009 | Canon PowerShot A590 IS Digital Camera
Canon PowerShot SX20 IS Digital Camera Logo
225 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
