Question about Canon MP-25DV Calculator
The calculator does not count the items being entered anymore.
Item count switch is on but it does not print the amount of items entered.
  • 3 Answers
Move the print button item buttom all the way to the right.
Posted on Jan 13, 2009
I have classic model KM-2030; need code to change paper size from 8-1/2 X 11 to A4. Thank you!
Setting the destination Description
Switches the operations and screens of the machine according to the destination.
Purpose
To be executed after replacing the backup RAM on the main PCB or initializing the backup RAM by running
maintenance item U020, in order to return the setting to the value before replacement or initialization.
Enter Maintenance Mode
Enter "10871087" from keypad, You should now be in maintenance mode.
Enter "252"press "Start / Print" key.
Select your destination from list on the display.
Press "Start / Print" key.
Enter 001 "Start / Print" key to exit to normal display.
Method
Press the start key. The screen for selecting an item is displayed.
Setting
1. Select the destination using the cursor up/down keys. The selected item is displayed in reverse.
Display Description
JAPAN METRIC Metric (Japan) specifications
INCH Inch (North America) specifications
EUROPE METRIC Metric (Europe) specifications
ASIA PACIFIC Metric (Asia Pacific) specifications
2. Press the start key. The setting is set, and the machine automatically returns to the same status as when
the power is turned on.
Completion
To exit this maintenance item without changing the current count, press the stop/clear key. The screen for
selecting a maintenance item No. is displayed.
Feb 09, 2011 | Kyocera Mita RADF-11 REVERSING...
How do I print the total amount on my ticker tape of what I've added? I pressed the equals sign but that didn't work.
OFF • P P•IC
ON POWER SWITCH; PRINT / ITEM COUNT MODE SELECTOR:
"OFF": Power OFF
"•": Power ON. Set to the non print mode.
"P": Power ON. Set to the print mode.
"P•IC": Power ON. Set to the print and item count mode.
1) For addition or subtraction, each time is pressed, 1 is added to the item
counter, and each time is pressed, 1 is subtracted.
• The count is printed when the calculated result is obtained.
• Pressing of , clears the counter.
2) When the grand total/rate setting mode selector is in the ON position (GT), the
counter will count the number of times that the calculation results have been
stored in the grand total memory. To print and clear the count, press the key.
3) The memory item counter will count the number of times that the key has
been pressed in the addition.
Note: • Each time the key is used in the subtraction, 1 will be subtracted from
the count.
• The count is printed when the memory is recalled.
• Pressing of the key clears the counter.
Note: The counter has a maximum capacity of 3 digits (up to ±999). If the count exceeds
the maximum, the counter will recount from zero.
Dec 17, 2010 | Sharp EL-1801P Calculator
How do I turn off and on the paper roll from printing
"OFF": Power OFF
"•": Power ON. Set to the non-print mode.
Nov 24, 2010 | Sharp EL-1701C Calculator
How do I turn off the item count?
There is a marking I/C or IC for item count, next to the top row lever. switch it off.
Hope this helps
Dec 08, 2009 | Adler Royal 121 PD Plus Calculator
How to use tax buttons on victor 1208-2 calcutator
1. Slide the "Rate Set/Item/PRT/On/Off" switch to "Rate Set" position
2. Enter the rate value.
3. Slide the "Rate Set/Item/PRT/On/Off" switch to "PRT" position.
You can also dowload the instruction manual
Jul 26, 2009 | Victor 1208-2 Calculator
Item counter
there are several positions on the print item button. All of the way to the right the counter is on. To stop counting move one mor position to the left.
Sep 09, 2008 | Canon MP-25DV Calculator
Track number of entries
on the top right there is a slide button ...move the button to "item". this counts the quantity of items you enter. hit the * to get the total and the count.
Aug 14, 2008 | Canon MP-25DV Calculator
Sales transaction
Pusedo is as follows
/get the cost of them items and add it to the total
when no onter items are found exit loop
if there are items continue loop //
item = y
total = 0
do while item = y
total = item + total
get cost of new item
if cost = 0 then item = n
loop
Print "BILL TOTAL = " + total
// minus discount
enter discount amt (in %) as da
discount = (da/100) * total
total = total - da
Print "DISCOUNT = " + discount
Print "new total " + total
//add vat
vat = (12/100) * total
total = total + vat
Print "VAT " + vat
Print "new Total " + total
//get pay
enter amt paid as amt
change = amt - total
Print "Paid " + amt
Print "change " + change
Print THANK YOU FOR SHOPPING AT FIXYA
Feb 20, 2008 | Computers & Internet
Item count on el-1701c
Helloooo
There is a switch located above the keyboard labled IC for item count...slide the switch to the on position and as you add a number will appear on the paper tape on the other side of the total. On some units it will appear on the Display also.
I hope this solves you problem.
Squipps
Jan 23, 2008 | Sharp EL-1701C Calculator
Item Count
The item counter isn't available on this model.
Apr 20, 2007 | Casio DR-250HD Calculator
Canon MP-25DV Calculator Logo
330 people viewed this question
old marine
old marine
