Question about Kenmore 50 Pint Dehumidifier Electronic Controls Energy Star 50501
Kenmore 50 pint dehumidifier fan won't turn off.
1 week old, fan doesn't stop running. Even when setting moisture level to above what dehumidifier displays (moisture displayed is 45, I've set level to 60, compressor is off but fan keeps going). Small, non-vented crawlspace, 100 square feet. Fan does shut off when removing water bucket. Dehumidifier has been collecting just under half a bucket of water a day.
3 Suggested Answers
SOURCE: I have a Kenmore 50 pint dehumidifier Model 580.54501400
It looks like it is simple to get the filter out but we are finding it to be imposible. How can we take it out. It doesn't just pull down.
Posted on Jun 17, 2010
  • 4736 Answers
SOURCE: My Kenmore 50 Pint dehumidifier doesn't seem
If it hasn't received routine maintenance recently, now is a good time.
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. In you have an analog unit
set the humidity extraction knob on Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope the above helped you to troubleshoot and solve the problem. Please let me know and thanks for choosing FixYa.
Posted on Aug 10, 2011
Never no water in dehumdidifer to empty
I'd suggest you (1) make sure dehumifier is plugged in, (2) the circuit it's connected to is live (breaker not tripped and fuse not blown - this is easily tested by plugging in an appliance (e.g., hair dryer) you know works). If the unit turns on, it is likely defective - unless there is a hose connected to the dehumidifier that reroutes the water removed from the air to a drain (is there moisture collecting somewhere within 6-10' of the unit?). If it doesn't turn on, and you've troubleshooted the above to ensure there is electricity to the receptacle, then it's either defective or the moisture setting for removal needs to be adjusted for the humidity in your basement. Perhaps it's dryer down there than you thought, or your hygrostat (? - whatever the doohickey is called that senses humidity level) is set at too high a level that it never turns on/trips in your area. Hope it helps.
Jul 31, 2012 | Haier 30 Pint Dehumidifier
My Kenmore 50 Pint dehumidifier doesn't seem to be collecting any moisture in the bucket. Just wondering if it may need maintenance? Thanks
problem.
Aug 10, 2011 | Kenmore 54501 Dehumidifier
I have the a Kenmore dehumidifier sometimes it runs fine and other times just the fan runs not the compressor or just the opposite the compressor runs not the fan it is only 2 1/2 years old. What should...
Kathy, I'm not sure you have a problem with the dehumidifier. Depending on which mode you're operating it in, the fan will run in an effort to recirculate the air. If the humidity level rises above the level you have the unit set on, the compressor will then turn ON. This is particularly true, if the unit is operating in continual mode. Then there are other times the fan isn't active, but the compressor turns on when the humidity sensor feels a rise in humidity. So, for the most part, I don't think it's a problem.
Just be sure that you clean the air intake filter at least once every two weeks, during times of daily operation.
Hope this helped you. Please let me know. Thanks.
Jun 27, 2011 | Kenmore 54351 Dehumidifier
My dehumidifer is not drawing any water, but the fan continues to run.
There are several reasons this may be happening. The 2 primary reasons are the humidity extraction level is set to high. Lower it to 35% . The lower the setting, the more moisture/humidity is extracted from the air. The higher the setting, the less if any moisture. humidity will be extracted from the air.
On most humidifiers the fan runs almost constantly while in operation. The idea is to continually move the air around and when the unit senses a rise in humidity, above what you have it set on, the compressor will turn ON to extract that humidity.
The 2nd thing that causes the problem is a dirty of clogged intake air filter. Which is easily solved by removing and cleaning the filter. Which should be done at least every 2 weeks, while the dehumidifier is in operation.
I said there were 2 reasons. Actually, there is a 3rd. Not enough clear air space all around the dehumidifier. A minimum of 12" should be maintained during operation.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 02, 2011 | Haier 45-Pint Dehumidifier
The unit turns out and runs fine. The fan blows. But the moisture is not being removed. I did insert a hose last fall and it worked fine then. Now it doesn't remove moisture with using the hose or...
You may have the humidity level set to high. If it's above 60%, that's what it's going to maintain, not remove. Set the humidity level on the lowest setting and try again. Whether you're using the hose or not, I don't suspect it's playing a role in it. Also, clean and reinstall the air intake filter.
Hope this helped you solve the problem. Please let me know. Thanks.
May 16, 2011 | Soleus CFM-40 Dehumidifier
Jul 09, 2009 | Kenmore Dehumidifiers
Humidifier Fan Doesn't Stop
RH at 70 % seems to me a little excessive you really should be working somewhere around 50 to 56% the fan has to move Air through the system.
I would like to know your room Air temp what is the Air temp comming off the system. what are your parameters.
Jun 08, 2009 | GE AHG40LA Dehumidifier
Kenmore 50 Pint Dehumidifier Electronic Controls Energy Star 50501 Logo
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
