Question about Philips 55PP9401 55" Rear Projection Television
How to replace the converge ic
The red converge are not working in vertical
    Sergeant:
  • 233 Answers
Your convergence IC's have gone bad. There are 2 of them, you should go ahead and change both while you have it apart..
These IC's operate at a very high temp, and usually only last 4-5 years.
If you remove the back of the set, you will want to look for the BIGGEST heatsink in there, on that heatsink, you will see 2 lage IC's , probably STK392-110, or STK392-120's or something close...regardless - you can go on ebay to order the new ones, but MAKE SURE they are Genuine SANYO IC's and not counterfiet cheapies. the cheap ones may last 2 years, or only last 2 minutes..
You will also need some "Heat transfer paste" - you can pick this up at radio shack.
Once you remove the old IC's, using a solder ****** (radio shack will have this as well...) test all the large resistors near them.. pull one side of the resistor out of the board so you can check it out of circuit. they will usually have the value in Ohms, printed directly on the resistor, but you may have to use the resistor color code to find out what value they are....However, usually if there is any damage, the resistor will look like it has been very HOT or fried. replace the IC's and any bad resistors, and you should be good to go.
If after replacing the IC's and any defective resistors, the convergence is still bad, make sure to use a multimeter to check ALL fuses on the boards, --- sometimes when the IC's go, they will take out a fuse to the convergence power supply. If you find any bad fuses, replace them accordingly!
If this STILL doesnt make it look right, you will need to find out how to get into service mode and do a coarse convergence adjustment. This information can be found in the Service manual for your set. If you dont have one you can download it at manualuniverse.com
Hope that helps!
Posted on Jan 12, 2009
  • Philips Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This how to replace the converge ic - 2c07611.png problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
how to replace the converge ic - 578ba6c.jpgture of a set that needs the fluid changed.
TV set after how to replace the converge ic - 2c07611.pnge
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 12, 2009
My tv has many lines in the screen. what kind of problem is this and what does it need to be fixed?
You may be suggesting a convergence problem..when the blue and red boxes will not center. You have bad grounds on the convergence ICs. Resolder or replace theses ICs. Or you may be asking about a problem in the vertical section. Vertical problems will appear as horizontal lines on the TV. In this case you have bad capacitors near ithe vertical IC and must also resolder or replace the vertical IC.
Nov 15, 2009 | Mitsubishi VS-45607 45" Rear Projection...
43fdx15b Hitachi 42in red vertical lines magic focus inop for red
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors.Shops usually charge from $200-$300
Sep 26, 2009 | Hitachi Televison & Video
Hitachi 50" rear projection worked fine one day then just shut off
Replace this:
--(if led red is off).: IC .STRM6511.
---(if led red is on)....Replace all (3) : STK4274 convergence IC
---Sometimes vertical IC need replace too.
Thank you
Aug 10, 2009 | Hitachi 50UX57B 50" Rear Projection...
I have a toshiba TP55C81 projection TV. The red The red vertical adjustments stopped working. The adjustmnet knob in the control panel does not effect the adjustment and none of the vertical adjustmen
You need to replace the vertical STK convergence chip but I would recommend that you replace the horizontal chip at the same time as this is likely to fail soon.
The following relates to the repair I have recently carried out to my Toshibal 40WH08B rear projection TV but shuold be very similar to your model. Replace the STK chips with the same type on your model:
On the convergence board PB 9487 (the one with the 2 large heat sinks that the r, b & g guns plug into) you will see two STK392-110 ics connected to the large heat sinks. Replace both of these and readjust convergence in service mode if necessary.
I obtained the replacement ics from Charles Hyde & Sons Ltd (see link below). I ordered the general ics not the Toshiba ones as these are identical as far as I could see and they cost £17.19 each instead of £36.68 each.
http://www.chsinteractive.co.uk/search.html?query=stk392-110
You will need to desolder the heat sinks as well as the ics as access to the ic mount screws are obstructed by the conv.dig board (metal cased). Buy a good quality desolder pump if you dont have one.
One last thing I should mention. The white paste between the ics and the heatsink is silicon thermal compound. Without this the heatsinks will not take heat from the ics effectivly and the ics will burn out! I recommend that you clean all of the old paste off the heatsinks and apply new to the whole of the metal plates on the back of the ics before you screw them to the heatsinks. You can get the thermal compound and the desolder pump from the same supplier I recommended for the ics.
Let know if your are having any problems.
May 30, 2009 | Toshiba TP55F80/81 55" Rear Projection...
Red convergence can't be adjusted
replace the two STK394-250 Convergence ICs.You can get the original replacement ICs at the following link with free step by step instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/stk394250/cName/convergence-ics
These are the original ICs not the cheap chineses knock offs
Apr 30, 2009 | Mitsubishi WT-42313 42" Rear Projection...
Red vertical convergant line
convergence Ics you will need two STK392-120 convergence ICs. You can get replacement ICs at the following link with free instructions.
Jan 19, 2009 | Hitachi FDX Series 43FDX10B 43" Rear...
Mitsubishi VS50805 Serial # 102718 No red in picture
Replace the convergence ICs your model uses two STK392-040 Convergence ICs. You can get replacements at the following link with instructions.
Dec 28, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi rear projection tv
replace vertical IC and shadows/ghosting the problem is either electrolytic capcitor or video IC or convergence adjustment
Aug 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Can't control red convergence on VS-45607
The STKs are three channel ICs they each control horizontal and vertical of one color the third channel controls part of green and the other half of green is controled by the other ICs third channel. Its customary for the Ics to fail and only have one channel bad in the IC. However its recomended to change both because of the bad Ic having green it can actually weaken the other IC and that one will fail shortly.
Aug 03, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Sony kp53v80 Red convergence stuck vertically
Did you replace the convergence ICs? The 4.7 ohm 1/2wwatt resistors and the pico fuses? Let me know and I will assist you, as often sonys will blow the 3.5 pico and a few of the 4.7 ohm 1/2watt resistors when the Ics fail.
Jul 28, 2008 | Televison & Video
Philips 55PP9401 55" Rear Projection Television Logo
302 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
