Question about Motorola Mobility RAZR V3
Resprogram speed dial numbers problem
I can't program a new number into my previously used speed dial. I had to manually put in all my numbers when I switched phones and carriers. Now when I tried to put a specific number into a single digit speed dial, it says "in use". I found the number occupying that speed dial space and reset the speed dial so it will show "empty" for a number ....but once again it says "in use" when I try to place a phone number into the space. Anyone have an answer for this? Thanks.
  • 2 more comments
  • John Dorsett Jun 14, 2007
    Thanks but I didn't find my Black VT3 RAZR in the list. The closest was a V3c
  • Anonymous Dec 16, 2008
    Is there any solution for this problem??
  • F Garcia
    F Garcia Jan 07, 2009
    When trying to put a number in speed dial from the phone memory I get a message that this location is in use, but when I press this button it shows Speed #3 is empty, its the same for location #7.
    Can you help me? please.
    Very truly,
    F. Garcia
  • Anonymous Mar 30, 2014
    how to store phone numbers & set up speed dial & how to acess speed dial
  • 35 Answers
You can reprogram them using bitpim.
Posted on Jun 13, 2007
NEED HELP IN SET UP SPEED DIAL NUMBER
To enter or edit a speed dial number on the Uniden D1788, go to PHONE BOOK (the book icon), when SELECT appears use the up/down arrows to select the previously entered phone book name, press MENU/SELECT (EDIT appears), press MENU/SELECT (EDIT NAME appears), press MENU/SELECT (EDIT NUMBER appears), press MENU/SELECT (SPEED DIAL - XXXXX) appears. Now, to assign a speed dail number, use the up/down arrows to select the desired speed dial number (Expl: SPD2) and then press MENU/SELECT to save it. The selections are SPD0 to SPD9 and also NO SELECTION to remove an existing speed dial number. You can also assign a speed dial number that's already used to a different phone book name. It will remove it from the old name and reassign it to the new name. Use the above procedure to assign a speed dial number to a new phone book entry when SPEED DIAL appears.
Nov 05, 2012 | Uniden DECT 6.0 Cordless Phone System...
I need instruction manual to program speed dial
I was unable to locate a user manual for that particular device, however the basic instructions for programming speed dial functions are normally very similar between most phones.
Generally there are ONE TOUCH Speed Dial buttons labelled something like M1, M2, and M3 on the dial pad somewhere.
There should also be another button labelled PROG or STORE on the keypad as well.
Normally to program a number into a ONE TOUCH speed dial memory location you carry out the following procedure:
Lift the handset.
Then press the PROG (or STORE) button.
Now just use the number keypad to dial the full telephone number that you want to store in a Speed Dial location.
Once the full telephone number is dialed, then push the M1 button to store that phone number in the M1 One Touch Speed Dial location.
The phone may or may not show some kind of confirmation that the M1 location was just programmed, then just hang up the handset.
Now when you lift the handset and press the M1 button, the phone should automatically dial the phone number you programmed into it.
Now just repeat the same process for the M2 and M3 One Touch Speed Dial buttons with other phone numbers if necessary.
To change one of the Speed Dial numbers, just carry out the normal programming procedure for that location using the new phone number and the old number will simply be overwritten.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 02, 2011 | Southwestern Bell FM-480 Corded Phone
Hi I have a panasonic KX-T433 phone system which I am trying to put in speed dial numbers, we have to dial 9 to dial out does any one know how to do this using a 9 in front?
You have neither a 7730 (the category you asked in) or a 7433 phone sytem. If your phone is really a 7433, you have a TD phone system. Which "speed dial numbers" are you trying to program? System speed dials, are stored in system program 001 and consist of a 3 digit number (may be 2) with a "9" in front and the number as you would dial it from the keypad. Personal speed dial numbers depend on the button you're programming it onto. If it's a button with a light, you dial "2" in front of it. If not, you don't. So, Program 99, button, and either 29 + number STORE or 9+number STORE programs a personal speed dial.
There are other programs to store under the tone pad keys. Those features are covered in your User's manual for the TD system.
Carl
Jul 06, 2011 | Panasonic KX-T7730 Corded Phone
How do I change the speed dial outgoing number??
For personal speed dial numbers press feature *4 , enter in speed dial bank number 71-94 (256-279, it changes with different versions), enter number, press ok
- speed dial numbers 01- 70 are system wide speed dial numbers and are changed in system programming2.gif.System programming is done on M7310,M7324 and T7316 set only.
Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say Terminals&Sets.
The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the next key 3 times(bottom right arrow).
The display should say Sys speed dial.
Press the show key (top right arrow)
The display should say speed dial#:--
enter in the speed dial number you wish to program(40-70) .
Press the show key (top right arrow) .
The display should show the existing speed dial number
Press the chg key
Enter in new telephone number
press ok when finished
repeat for remaining speed dials
Press the release key when finished
Oct 14, 2009 | NorStar M7310 Corded Phone
I can't change the speed dial numbers on my phone
You should only have to hit Feature - Redial and then select the soft key that you wish to re-program. Typically you will then type 1 and then the extension you want to program.
Jul 06, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Programming Auto Dial Number
Yep. Those are speed dial numbers. They are programmed from ext 101 or the main phone. Without picking up the handset, press PROG **1234 and dial 001 and ENTER. Dial your 3 digit speed dial number If there is something there, it will be displayed. A speed dial number is stored with the trunk access code in it (usually 9) so if you're putting in a new number, include the "9" plus the number exactly the way you dial it. Dial your new number with the access code and press ENTER.
Number changed :-)
You can keep putting in a whole boatload of new numbers with this procedure.
Carl
Mar 16, 2009 | Panasonic KX-T7633 Corded Phone
NorStar T7316E Corded Phone Manual
1 you can but it must be done via log on to switch with lap top (you may use handset but very tricky)
2 use feature *4
Speed dial -
using
FEATURE 0
Dial an external telephone number using a two- or three-digit code. There
are two types of speed dial codes: system (01-70 or 001 to 255) and
personal (71 to 94). System speed dial codes can be used from any
display telephone in the system. System speed dial codes are assigned by
your System Administrator.
Personal speed dial codes are used exclusively at your telephone.
To make a call using a speed dial code:
1. Press FEATURE 0.
2. Enter the two- or three-digit code for the number.
Speed dial -
programming
To program personal speed dial numbers:
1. Press FEATURE *4.
2. Enter a two-digit code from 71 to 94.
3. Specify the external line by pressing a line button, a line pool button, or
the intercom button. If you do not specify the external line, the system
automatically chooses a line for the call.
4. Dial the telephone number you want to program (up to 24 digits).
5. Press HOLD.
6. Record the code and number you have just programmed.
Note: You cannot program personal speed dial numbers while another
user is programming your system.
May 15, 2008 | NorStar T7316E Corded Phone
Programming speed dial!!
ARE YOU PROGRAMMING PERSONAL SPEED DIALS, SYSTEM SPEED DIALS OR BUTTONS ON THE PHONE AS SPEED DIALS.
IF SYSTEM YOU MUST BE ALLOWED IN THE PROGRAMMING BY YOUR INSTALLER TO DO THESE UPGRADES. NORMALLY THE RECEPTION/ FIRST EXTENSION ON THE SYSTEM HAS THIS ABILITY. ADMIN PASSWORD IS 1234 PROGRAM 001 IS WHERE YOU PUT IN THE NUMBER AND 002 IS WHERE YOU PUT IN THE NAME
UNDER MANAGER PROGRAMMING, PAGES APPROX 210-215
Apr 28, 2008 | Panasonic KX-T7730 Corded Phone
Uniden 900MHz phone model EX17960A
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers in the speed dial memory.
1) When the phone is in standby mode, press the memory key. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number; each number can be up to 20 digits.
7
3) If you need the phone to pause during the dialing sequence, press
the redial/p key to insert a two-second delay between the
numbers. You can enter multiple pauses to increase the delay.
Each pause counts as a digit.
4) Press the memory key again.
5) To store this number as one of the ten speed dial numbers, enter a
digit from 0 to 9. If there is already a number in that speed dial
setting, it will overwrite the previously stored number without
warning. You will hear a confirmation tone indicating that the
number has been stored.
NOTE: When storing numbers into memory, if the handset is idle
(i.e., no key is pressed) for more than 30 seconds, it will beep rapidly, and the phone
will return to standby mode.
Dialing a Stored Number
1) When the phone is in standby mode, press the talk key, and listen for a dial tone.
2) Press the memory key and enter the speed dial entry (0-9) that has the stored number you
want to dial. (If you enter a digit that does not contain a stored number, the handset will
beep rapidly, and the phone will not dial.)
Nov 13, 2007 | Lands Phones
Need to program access code into phone line for long distance numbers
Does it work when you press speaker/hook and manual dial same fax number you are trying to program
It sounds like you are adding digit needed for outside line when it is in fact a direct/dedicated fax line, that needs it not (or vise versa).
Are you printing a report of rapid/speed dials that you set to ensure the number you put in is correct?
Nov 05, 2007 | Brother IntelliFax-1860C All-In-One InkJet...
Motorola Mobility RAZR V3 Logo
208 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
