Question about Hisense PHD-4220 Television
Hisense dcdi by faroudja is on an optical aye
Is there an option to put in an optical aye for sound outside sound box
Can I link up a sound box to my Sony Wega 23in TV?
What are you trying?optical? RCA? Hdmi?there should be an option in the sound menu of tv to select any of the above.i believe optical out is the best because it automatically figures connection,but make sure you remove the plastic caps as these often get overlooked.
Jan 29, 2015 | Sony Cameras
Can i connect a sounbar to my tv
Yes you can; Most sound bars have a Optical in port and many new tv's have an optical out option, or an option to change it to an out in the settings. Other wise connect the sound bar to your digital set to box!
Nov 19, 2013 | Televison & Video
No audio when watching HDTV and the home theatre receiver is set to cab/sat. HDMI cable is run from the receiver to the TV. Cable is run from the cable box to the receiver. Tried using "y" audio...
If your TV has HDMI in and digital optical out, run your HDMI cable via HDMI out on box to, HDMI in on TV then, run digital optical ouyt from TV to digital optical in on reciever. Your reciever has video pass through but, not the best option. Video components should run to TV then out to reciever. If you do not have digital optical out on TV, you may be able to use RCA.
Jun 24, 2011 | Insignia Audio Players & Recorders
5.1 settings
Receiver just receives the audio data over optical digital cable and processes it. It is up to the DirectTV box what will send to receiver (if stereo or some Dolby Digital for example).
You can check the format (decoder, no. of channels, bitrate) of current audio signal after pressing Option button on remote and choosing Signal Info menu.
Jan 16, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Digital Audio Output Problem
connect the optical line from the DTV box to the audio system directly.
Sep 24, 2009 | Pioneer Elite PRO-1540HD 60 in. Plasma...
Sony DG510 - Not Getting surround sound out of Cable
Did you try it on BOTH the SAT and Video 2 optical ports? Still not working? Could be the Optical cable is bad.
Does your Cable Box also have a coaxial digital ouput? It looks just like a standard RCA connector but says Digital somewhere near it. Try one conductor of a standard audio cable from it to the "DVD" coax connector. Select DVD to hear it.
If it still doesn't work jump into the Cable Box setup to make sure it's output is set up properly.
I would recommend using the coaxial digital option if you have it.
1) The cable isn't special or expensive like the optical cable is; a garden-variety RCA cable works just fine.
2) You have virtually unlimited distance to work with in the house.
3) You don't have to be so darned careful with it as with optical.
Mar 06, 2009 | Sony STR-DG510 Receiver
How do aye get in2 my 2002 celica to change the bulbs
you have to take the bumper off to get to the lights
Dec 11, 2008 | 2002 Toyota Celica
No Audio thru Optical input
If its a PS3 please realize that you adjust the sound options using the sound option menu on the ps3, so its possible that you have the PS3 set to RCA cable and not the HDMI therefore the optical cable isnt getting any sound from the TV
Feb 24, 2008 | Yamaha HTR-5830 Receiver
Sony Audio Optical Out to Bose Optical In not working
Set the source for Optical-In on the Bose system to TV
Dec 16, 2007 | Bose Lifestyle 28 System
Hisense PHD-4220 Television Logo
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
