Heating & Cooling Logo
Posted on Jan 12, 2009
We seem to have developed a problem with our boiler, worcester 20/25 heatsave. Every time we turn on a hot water tap, when we turn the tap off, there apears to be a loud noise from the boiler or pipes for a second or so. The heating and hot water etc are working fine. This has developed iver the last week or so?
Anonymous
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Jan 12, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
Helped
7496
Points
54
It seams the valve that senses water flow is not operating properly,causing the boiler to keep heating the water when it has nowhere to go,i,e the taps turned off,thus boiling the water.
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Low pressure coming from Hot Water Tap
Were is the water boiler located.
1helpful
Operating worcester bosch 240 gas boiler
  1. If there is no water on the floor, your crack is probably OK so far. The water thing is a worry though. NEVER fire a boiler that is low on water. Adding water to a hot boiler will crack it. Tell me all you can on what components you have in the water and gas lines.
I have a Worcester 24cdi combi boiler. When I put the hot water tap on, the water comes out cold. The hot water light on the boiler is flashing rapidly and the flame indicator light also flashes red. I...
i would take it back trade it in for a new one depending on how long you've had the boiler for, i ad the same problem with mine, so i brought mine back in they couldn't fine the problem so the gave me a new free of charge, also read the manual for that thing thats one thing i never did when i first got mine
6helpful
Flashing red light on Worcester 24i junior combi boiler
Pressure is ok? at 1 bar or above
I think on this one there should be a reset button [red] on the left hand top of the casing - or lower the control panel [ phillips screw on each side] and the button is on the left of the base plate. Press this and try the heating.or hot tap
P.S. if you're on a prepayment meter check you have gas.
A trickle of hot water from taps, central heating ok
it sounds like your shut off valve might be bad even though it turns on and off by turing it doesn't mean that the washer is not stuck to the seat and not opening, try replacing the valve
3answers
Faulty Worcester boiler
we have a worcester24i rsf boiler installed in our mobile home buy the the water temperature seems locked in at a certain temperatutr any idea how we can change this
Top Heating & Cooling Experts
Paul Carew
john h
