Question about Toto Aquia II Dual Flush Toilet
FAMILIAR WITH TOTO AQUIA TOILETS AT ALL? - Toto Aquia II Dual Flush Toilet
  • 33 Answers
Everything you need to know about Toto! Hope it helps!
http://www.totousa.com/Default.aspx?tabid=215#
Posted on Jan 27, 2009
The dual flush push button flushing unit on my Toto cistren is not working
the connection rod under the lid is broken or not making the connection just lift the lift to see.
Oct 03, 2013 | Toto Aquia II Dual Flush Toilet
Leaking from water tank
Is the water leaking from the tank onto the floor or at the water valve located where it comes in from the wall.
Feb 08, 2013 | Toto Toilet - Elongated Bowl, Dual Max -...
No water in tank
Check to make sure the valve that goes from the back of the toilet to the wall is open.
May 31, 2011 | Toto Toilet - Elongated Bowl, Dual Max -...
How do you put the toto dual flush parts back together
Very carefully!!!!!! Why would you take it apart not knowing how to put it back together again?????? Take pictures next time, after you call a plumber to put it back together again Humpty....
Apr 20, 2011 | Toto Aquia II Dual Flush Toilet
Aquia II Dual Flush Toilet: toilet after flush removes to much water from bowl...
Adjust the float on the Fluid-master a little higher if possible. This should allow more water to enter the bowl after the flush.
May 16, 2010 | Toto Aquia II Dual Flush Toilet
REMOVAL OF TOTO AQUIA TOILET
first shut off water and then flush the john. this will remove most of the water. for water remaining in tank us a sponge or similar to remove remaining water. find where toilet bolts to floor and remove these bolts or nuts. then pick whole toilet from floor, there should be a wax ring under toilet, replace wax ring when putting back in. when putting back in just push down on toilet to squish wax ring and bolt to floor, turn on water and check for leaks. good luck
Apr 16, 2010 | Toto Aquia II Dual Flush Toilet
Looking to buy/install Toto Aquia II in my circa 1964 co-op apt.
When you say 10.5 inches from wall, do you mean that from the center of the drain in the floor to the back wall is 10.5 inches? If so, you need a toilet for a "10 inch rough-in" dimension. The Aquia doesn't come in that dimension. Sorry!
Caroma Sydney Smart model 270 comes in a 10 inch rough-in and is a dual flush model. Note that all dual flush toilets are fairly expensive as compared to normal toilets. HOWEVER, genrally speaking, ALL 10 inch rough-in toilets are fairly expensive just because the low volume that are sold.
Jul 02, 2009 | Toto Aquia II Dual Flush Toilet
I purchased a Toto Aquia II Dual Flush Toilet, around a year ago. No problems until now. The toilet won't flush. It doesn't appear to be running at all.
If this is one of those models that most people have, the valve that shuts the incoming water off when the tank is filled is probably bad. It only costs about 8-10 dollars to replace. This valve is actually a stem or tree shaped device.
Jan 14, 2009 | Toto Aquia II Dual Flush Toilet
Toto Aquia II Dual Flush Toilet Logo
329 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
