Question about Motorola Mobility H700 Wireless Headset
Headset disconnecting frequently
I am using the motorola h700 bluetooth headset with nokia6600. it was connecting well before. but now after connecting with device it gets disconnected within a minute. but the battery is full. blue light is blinking normally once in 5 secs. If close and open the headset it connects and once again disconnects. i have even tried unpairing and pairing of the headset with the mobile, the problem persists. give some solutions. thank you, by, sankar
  • 1 more comment
  • Anonymous Dec 30, 2007
    same problem with the RAZR and the H700 (motorola to motorola no less). I have tried all the same solutions with no success. Will hope for a solution.
  • Anonymous Mar 17, 2014
    device automatically disconnects from phone
  • Anonymous Mar 24, 2014
    headset stays blue and won't connect even after successful pair
I think that the problem is with the on/off switch inside the headset boom. Mine has been doing the same thing lately. I'd like to find out how to fix it myself, cause I'm sure having it repaired would cost about as much as just buying a new or better headset.
Posted on Jul 04, 2007
Motorola H700 won't stay connected
Your bluetooth is defective. Contact Motorola to get a replacement. This is THEIR fault. I had the same problem. www.motorola.com Hope i've helped you!!!
Mar 19, 2009 | Motorola Mobility H700 Wireless Headset
Tip
Switch playing up
I have a H700 , I bought last year and hardly used. I tried to use it few days ago and it keeps loosing connection to my phone. I figured out that the headset switch is very flaky and slight touch makes it connect and disconnect the bluetooth connection to my phone. Any clue to fix it ??
on Jun 19, 2008 | Motorola Mobility H700 Wireless Headset
Motorola h700 pass key
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Jan 22, 2009 | Motorola Mobility H700 Wireless Headset
Motorola earpiece H700 how to setrup earpiece .
Tips:
Jan 21, 2009 | Motorola Mobility H700 Wireless Headset
I can't sync my motorola h700c with my blackberry
1. Bluetooth enabled?
2. Options -> Bluetooth -> Add Device
Hold down the connect button on headset until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the blackberry. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the blackberry and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the blackberry.
Dec 11, 2008 | Motorola Mobility H700 Headset
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Motorola bluetooth pairing
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
Tips:
Motorola H700 Bluetooth connection problem
Tips:
Apr 01, 2008 | Motorola Mobility Bluetooth...
Reg: H700 connection with sony ericsson 580i
You may have to get a bluetooth headset specifically used with Ericson or change bluetooth setting on your cell to handsfree
Jan 08, 2008 | Motorola Mobility H700 Wireless Headset
My H700 does not connect. When I attempt to connect it shows the disconnect option but it isn't connected
My bluetooth does not work at all. Have had it on charger for days. It does turn purple, but does not work when I put it in my ear. Have checked the connection. It just seems dead. Bought it last November, but first time I've had a problem. Can you help? Barbara
Jun 20, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
268 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
