Question about LG WM-2277HW Front Load Washer
Lg wm2077cw ce code motor spinning slow - LG WM-2277HW Front Load Washer
5 Suggested Answers
  • 56 Answers
SOURCE: LG WM2077CW small item trapped behind drum
you would need to remove bottom exit rubber pipe from drum and use a flash light to free coin or screw,hope this helps
Posted on May 27, 2009
taran_2005
  • 10515 Answers
SOURCE: LG washerwon't spin
I had the same error code along with the drum "freezing" up. The first unit that was delivered 2 years ago leaked water from the detergent compartment and they sent a second unit. I have only had this unit for 2 years and I am very disappointed in the LG product. LG was no help on the phone and I the only people that could service it were 45min away from were I live. I took the advice of a posting on this website that it could be a part called the sensor assembly and ordered it from an online electronics store (www.mcminone.com). To get to the sensor assembly, you first unplug and take off the back plate that has 4 small screws. Next, unscrew the big bolt in the middle and take off the hubcap looking part the bolt was securing. Next unclip the two sets of wires on the bottom of the circle you are looking at (the set of wires to the right are connected to the sensor assembly you want to replace). Next you will unscrew the 6 or so smaller bolts to take off the circular piece that the sensor assembly is snapped to. Take it off, unclip the old sensor assembly and clip on the new one – and reassemble. This worked perfectly for me and the part only cost $18 bucks plus shipping. When working, this product works well but I will not be purchasing any LG products in the future.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 03, 2009
SOURCE: LE code appeares on my LG front load washer
A majority of the time when the LE code appears.. the Hall sensor in the motor is bad. Replacing it. Part # 6501KW2002A from MCM electronics... can help. Good luck.
Posted on Dec 02, 2009
  • 185 Answers
SOURCE: MY LG TROMM WM2077CW WASHER
you may have stripped teeth on the motor rotor (plastic) to metal drum shaft. this is found behind rear access cover. you will need a #17 socket and breaker bar to remove rotor shaft bolt. if you have a "LE" CODE displayed, you will need a new hall sensor.
Posted on May 16, 2011
I have an LG washer that get stuck in low spin at 10 minutes left.
If you just do a spin only cycle does it go fully sped?
May 16, 2018 | LG Washing Machines
Lg tromm wm2077cw le code
Replace "hall" sensor. Motor sensor is an easy fix and a known problem. Try appliancepartspros.com. They have video to show you how. And part.
Feb 27, 2015 | LG Washing Machines
MY LG TROMM WM2077CW WASHER DRUM WILL SPIN FOR A BIT THEN IT STARTS STUTTING AND WON'T SPIN. THANKS SCOTT
May 03, 2011 | LG WM2016C
Nov 17, 2009 | LG Washing Machines
LE CODE AND A BURNING SMELL
The LE code represent a failed or locked motor. the replacement of the electrical motor will be needed in this situation.
Jul 19, 2009 | LG WM2077CW XL Front Load Stackable Washer...
May 27, 2009 | LG WM2077CW Laundry XL Front Load...
LG WM2077CW LE Error, won't spin
It sounds like the motor sensor has failed and needs to be replaced.  Yes a DYI can do it.  The sensor is in the back.
Remove the back cover.
Use a 17mm socket to remove the center bolt holding the rotor.  Remove the rotor by pulling it straight out.  It will be hard but keep pulling.
Now use a 10mm socket to remove the 6 bolts holding the stator assembly.  Carefully remove the stator and turn it around to locate two connectors.  The 5 wire connector is the motor sensor.  Replace it and reinstall and it should work fine.
Apr 27, 2008 | LG WM2077CW XL Front Load Stackable Washer...
LE code, Unplugged but machine doesn't want to spin properly
your unit doesn't have brushes, the problem is the hall sensor, which is located on the stator. Have this replaced and your problems will go away. Insure you are using 'HE' branded detergent as well.
Oct 21, 2007 | LG WM2077CW Laundry XL Front Load...
Washer doesn't spin
Try to replace the capacitor and let me know with your results. Good luck!
Sep 01, 2007 | LG WM2077CW Laundry XL Front Load...
LG WM-2277HW Front Load Washer Logo
14 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
