Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Huskavarna 455 rancher with pplug keeps popping out
What plug is that on top that pops out and you can push it in
  • Husqvarna Master
  • 2,239 Answers
This is the de compression button, it should be pushed in every time you start the saw, it makes it easier for you to start the saw and reduces the stress and wear on the starter components, it will automatically pop out when the saw starts.
Posted on Dec 08, 2012
SOURCE: my 455 rancher won't maintain power. I have
If you have been running ethnol mix in your saw there is a good chance that your fuel vent line is plugged. Loosen your fuel cap and start saw on its side and see if it runs. If it does you will have to clean your fuel vent.
Posted on Aug 03, 2009
spekgt
  • 60 Answers
SOURCE: 455 rancher chainsaw does not pump oil to the chain
If you look under the machine by the chain you'll see a flat head screw (next to the sprocket) which controls the bar and chain oil flow . Try to turn the screw and check if there's any oil flow to the chain . If not you will need to replace the oil pump (part # 537 10 55-02 which will cost you about $35.00) Hope this help
Posted on Aug 29, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a husqvarna 455 rancher. It was working
Why would you pay for something and then not force them to make good? I have a large bridge for sale, CHEAP. Make you a heck of a deal.
Take it back!!!
Lou
Posted on Sep 17, 2009
dontbother10
  • 2220 Answers
SOURCE: husqvarna rancher... chain tensioner not working
A Husqvarva IPL for a 455 Rancher 2005-01, follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/usa/2005/I05000/I0501036.pdf
See print "A" (clutch cover) pn 537 28 64-01 & pn 503 21 70-10, if missing or loose these may cause your problem. If not an inspection of the parts beneath may disclose the defect.
If the bar is what can be moved pn 537 28 65-01 or 537 28 66-01 may be stripped. After I determined what parts need replacement, I would contact a local Husky Dealer. They may have these parts on hand and if not ordering through them should save you shipping and handling fees.
If your saw was not manufactured between Jan 2005 and Mar 2005 you can find your IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 15, 2010
dontbother10
  • 2220 Answers
SOURCE: magneto to flywheel gap for Husqvarna 455 Chain Saw
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
Lou
Posted on Mar 22, 2010
Wher do the two carburator linkages hook up to a husqvarna on a 455 rancher
The throttle wire plasric end sits through the back of the crancase and into the square cut a way into the tank back handle, the hooked wire end drops into the carb throttle spindle on the r/h side of the carb, the blue clip on the spendle then rotated and locks the wire in, the choke pull just pushes into the choke spindle on the l/h side of the carb, it has a bullet style end to stop it popping out again
Dec 06, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 455 rancher new filters /plug get spark wont start put gas in cylinder and wont start what am i missing
Check to see if there is a leak in the air purge bulb (primer bulb), sometimes they crack and allow air in and don't push the gas through properly. Here is the manual for your saw.
Cheers!
http://www.manualslib.com/manual/514275/Husqvarna-455e-Rancher.html#manual
Sep 10, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
How to change the fuel line on a Husqvarna 455 Rancher
feed a wire threw the tank cut the new hose down to 1/3 about 1/2'' long slide it over the wire and pull it back till it pops threw then pull it threw
Aug 09, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Started 455 rancher after setting for about a month. always used stabil in fuel. started with choke on and then turned off choke once saw was running. the saw seemed to be stuck in high idle and would take...
This sounds like the throttle spindle sticking, or the cable sticking, if you remove the top cover and air filter, then push the throttle spindlefully back to the stop screw with your finger, then try again, the spindle may be a little gummed up.
Mar 18, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Chainsaw will not shut off using stop, I have to use the choke to shut it off. Husqvarna 455 Rancher
the wire on the stop switch probably came of the terminal. take the top cover off 3 screws ,and the air cleaner. you just replug it.
Jan 02, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
455 rancher engine bogging down and starting to smoke
Make sure you are using the correct fuel mix.
Check fuel tank vent, prone to blocking an can effect the performance
Clean air filter, check Spark plug.
Oct 03, 2010 | Husqvarna 455 Rancher 555cc 35 hp 20"...
Husky 55 rancher - I rebuilt this saw but now it won't start. Seems like not getting enough gas. What should I check for?
Check for plugged fuel filter and muffler. Check the fuel lines for decay or damage. Did you service the carburetor? Make sure the lower chamber diaphragm is not hard or cracked. Did you change the two jet settings? Put some fuel mix into the plug hole and pull it through--you should get a pop or two. If ok, then concentrate on the fuel problem. If no spark at the plug, check the ignition module gap to the flywheel magnets using a thin business card for a gauge. Hope this helps!
Jun 06, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
455 wont run
Make sure the muffler has not become plugged. Check the flywheel key as it may have sheared off for some reason causing the timing to be off, yet still generate sparks. Are the sparks blue and snappy? If not, check the ignition module gap to the flywheel magnets--use a thin business card for a gauge. A wide gap can cause weak spark. Hope this gets you running again!
Apr 30, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Won't crank, thing next to spark plug keeps popping up
Jerry is correct the compression release is ajdacent to the spark plug. If it pops the saw fired and the release closed (what it is supposed to do).
Read page 22 here:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_1151382-49.pdf
Excerpt follows: "Pull the starter handle (D): Pull the starter handle with your right hand and pull out the starter cord slowly until you feel a resistance (as the starter pawls engage) then pull firmly and rapidly until the engine fires. Push in the choke control as soon as the engine fires which can be heard through a "puff" sound. Keep on pulling the cord powerfully until the engine starts."
Continuing with the choke closed causes flooding. Please read the "Warm Engine" too it is slightly different.
HusqvarnaUSA.com
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week.
HTH
Lou
Jan 09, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
My 455 rancher won't maintain power. I have
if its over a year old and you used other than 93 octane, you need to rebuild the c arb, i did an runs like new
Jul 31, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
74 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
