Question about Vtech 9009111 Cordless Phone
Vtech out of range or no power at base
Tried many solutions, none work. just bought these phones today
  • 16 Answers
SOURCE: My vtech cordless reads out of range or no power
Official solution to this issue:
Make sure base station serial number matches all handsets serial numbers.
If they don't match you will have to de-register the units.
De-register the base station by holding the find handset button for 10 secs or until the In Use light illuminates, release the button and then tap it once more. You should hear a short beep followed by a longer beep.
Press Menu Select and the press the following without pause - *7890#
You should now see Test Base at the top of the screen press the Vol up button until Test Handset is present.
Press Menu/Select and you should see SW Version displayed. Press Vol up button until you see regstr clear, then press Menu Select and then Menu Select again.
At the handset remove the battery for 15 secs and then place the battery back into the handset. You should see 1. Place handset ... 2. press # on the handset screen. DO NOT FOLLOW THE ON SCREEN DIRECTIONS.
Next place the Handset on the base station and press the find handset button for 4 secs until the In Use light shows up. Remove the handset and press the # button.
Your handset should now display Handset 1. You can do all the other handsets the same way.
Hope this helps!
Posted on Jan 12, 2011
  • 3 Answers
SOURCE: vtech 5808
This model of phone have serious problem regarding the battery. This phone use a lot of juice out of the battery. I'm pretty sure that when your battery is foul charge it doesn't do it. So the problem is in the handset. When your battery starting to get to low you loose your connection. Why?...Because the detection to LOW_BATT in your handset is not calibrate adequately. So it thinks that the batt is weak, to weak to make a conversation.
The other problem could be that your handset doesn't really foul charge your battery. So when you are to far from the base or talking for to long . There's not enough power in the battery to raise the output signal level(db) to your base.
Posted on Nov 21, 2007
AlmostBob
  • 550 Answers
SOURCE: Vtech ia5870 dual handsets model problem:
http://www.vtechcanada.com/manuals/5870ciben.pdf
from the troubleshooting section of the manual
• Unplug the base unit’s electrical power and remove the battery from the handset. Wait for 15 seconds then plug in the battery place the handset in the base unit and plug in the power. Allow up to one minute for the cordless handset and base to synchronize
not a guarantee, something to try
Posted on Aug 30, 2008
  • 47 Answers
SOURCE: My Phone will not connect to the base unit...
My handset displays CONNECTING...
Move the handset closer to the telephone base. You might have moved out of range.
This is what was listed in the Vtech Manual.
What I suggest is not just powering it off, but remove battery and wait a couple of minutes. Put battery back in and try it. The other thing I suggest is a new battery or switching it temporarily with a phone that works, to see if that helps before you buy a new one. If the battery is weak it will have trouble reaching the base.
Posted on Jan 06, 2009
  • 50 Answers
SOURCE: Phones stopped working. They only read
I'm not familar with the Vtech but I would suspect that all 4 units work off of the answering machine base. It sounds like it is seeing a dial tone.
Take a working phones like the wall phone, if it is easily removed, and use a known good connecting cable between the good wall phone and the jack that the Vtech is plugged into.
If that works, take the connecting cable loose and replace it with the Vtech connecting cable. If that works check the jack on the Vtech for crossed wire. If non found, connect it to the jack the wall phone was plugged into. If this doesn't provide satisfaction, let me know exactly what you did and what happened and we will go from there.
Posted on May 28, 2009
Why do my VTech phones says outer range or no base on both of my phones
Out of range OR No power at base is shown in the handset ...
www.vtechphones.com/support/.../353
VTech Communications Inc.Out of range OR No power at base is shown in the handset display window. Why don't ... Tip 1 of 5. Confirm proper installation of the telephone base and charger power adapters, and handset battery. You should only use the VTech power adapters provided with your telephone. ... Next Tip This solved my problem. Tip 2 of 5.
FAQs - VTech Communications
www.vtechphones.com/.../frequently-asked-...
VTech Communications Inc.Have a question about VTech cordless phones? Visit our ... How do I find my model number ... My battery pack does not last very long between charges.
VTech CS6429-4 DECT 6.0 Expandable Cordless Phone ...
Jan 08, 2016 | Vtech Lands Phones
Out of range or no pwr base vtech phone on help
Try disconnecting the base from the power supply. Then take the battery out. wait a few minues, then plug baack in and reinsert the battery, and it should work. You might have to reset the date and time. \check the V-Tech site for instructions.Good luck.
cherriwh
Sep 10, 2012 | Vtech 9009111 Cordless Phone
ALL 3 OF MY CORDLESS PHONES SAY OUT OF BASE/RANGE/NO POWER...WHAT GIVES? NONE WILL GIVE ME A DIAL TONE!?
two steps one be inte range of the fone step 2 try to increase the hight of the place of the phone by wich you can get more coverage
Apr 23, 2011 | Vtech Cordless 6041 Phone
Jan 06, 2009 | Vtech Cordless 6041 Phone
One phone just stopped working
some DECT handsets have an internal fuse and please swap the batteries to check if both batteries are Ok
Nov 27, 2008 | Vtech Cordless 6041 Phone
Uniden dect 6.00
handset dies or cuts off frequently during calls or when talk is pressed to answer even when fully charged and right in front of the base unit. Beyond frustrating.
If I hadn't lost the reciept, I'd return this useless phone in an instant.
Aug 30, 2008 | Uniden DECT 6.0 Cordless Telephone...
Aug 30, 2008 | Vtech ia5870 Analog Cordless Phone
Vtech 9009111 Cordless Phone Logo
622 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
