SOURCE: 1998 olddmobile Intrique's low coolant light came came on
coolant level sensor is either stuck or sink to low level , or still wants more coolant
SOURCE: antifreeze level low light on
the sensor float is stuck or the sesor is bad depending on the system.
SOURCE: Low Coolant warning Light
on the passenger side of the radiator there should be a coolant level sensor several inches from the top facing the engine. they are known for plugging up with sludge or just going bad. They connect with a metal retaining clip around the outside edge and are easy to change
SOURCE: Code P0742 on 2001 Pontiac Grand Prix with 3.1L
Not an intrigue, sorry. run over anything lately? A pinched cooler line could cause this. Or maybe just an old, gummy transmission.
SOURCE: I have a 2000 silhouette. the coolant level low
Bleed the air out of the coolant system,and add more coolant,to radiator,and reservoir,and make sure the cooling fans are coming on,if the low coolant light stays on,remove the low coolant light sensor,and clean it off,it is located on passengers side in the radiator,it has a wire clip you have to remove,and dont loose it,after cleaning it,put the clip back on the sensor,and push the sensor back in the hole.
it's not an oldsmobile alero, i don't know how that got there or how to fix, it, sorry
