Is there a way just to replace the dvd system on my ks3101 system?
The unit will not read the disk and motor does not turn the disk
2 Suggested Answers
SOURCE: I need a replacement remote
how can i get a replacement remote?
Posted on Apr 21, 2011
Tip
My player does not read disks
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
on Apr 21, 2009 | Philips Magnavox DVD/VCR Dual Player
DVD stuck inside sony dav-sc5. Pressed the eject button and nothing happened. Did the usual turn it off and on again and it started to read the disk but then nothing happened. Tried to eject it and nothing...
Have you tried to unplug the unit for 1 or 2 minutes to see if it can reset the computer chip inside of the DVD player?
I have had great sucess with this trick.
I hope that this helps you out of this situation.
asnowman
Feb 08, 2010 | Sony DAV-SC5 System
Place DVD in any slot and it says "reading disc" then "no disc"
May 04, 2009 | JVC THC5 Home Theater System with 5-Disc...
Not reading DVD and CD's :-(
May 01, 2009 | Philips HTS3450 System
No Read error even with out a DVD inserted
Apr 19, 2009 | Panasonic DMRES15 DVD Recorder
Will not read disc
To get parts try here.
Jan 23, 2009 | Panasonic DMRES15 DVD Recorder
Does not recognize/play DVD - shows "NO DISK"
If you are good at repairs.dismantle the Disk drive unit carefully from the main carriage and if the Optical lens reading unit has got a drive P C B ,then desolder the PCB so that you have only the CD mechanism on your table,with a Digital Multimeter check the Ohmic values of both the Spindle motor and Sled motor. the resistance should read between 4.5 ohms and 8ohms any value beyond this means that the drive signal voltage is not enough to move /rotate the disc and optical-pickup in syncronisation.you can get the drive-motors replaced,or replace the CDM assly available off the shelf.
this should solve the problem.hundreds SONY DVD players are running with this remedy.
Nov 29, 2008 | Sony DAV-C900 System
Wont play disk has error code
It is a lens problem, the laser lens is either dirty or the lens pickup is faulty.
Oct 01, 2008 | Sony DAV-DX250 System
15 people viewed this question
 Grubhead
Grubhead
