Hot point wm vlsr1090g3ww leaking
Washing machine has a place I think for over flow but does not connect to anything. There is water that is in the bottom and 3 times now I have found my laundry room flooded and not from someething leaking from with in the walls of the home
  • 2 more comments
  • Jenny Ray
    Jenny Ray Dec 08, 2012
    The place that I am talking about is a tube that runs along the tub and down below and there is nothing there to catch the water
  • Jenny Ray
    And it only happens when my washer is running
  • Jenny Ray
    The tub will fill and go through the first cycle but when it gets to the rinse part and the tub fills up it starts sloshing and the water comes out of that tube.
  • Jenny Ray
    When the tub is full for the rinse cycle and it starts rinsing the clothes and sloshing the water is what I mean. THats when I see the water coming out of that tube.
    Sergeant:
  • 291 Answers
Is this a top loading machine? Are you seeing water flowing through the overflow or are you thinking that may be your problem? Asking because I've personally never had a prob with that tube. Leaks have always been attributed to other causes. Top loading hotpoint leaks are usually caused by a leaking transmission seal, water drain pump, inlet valve or faulty pressure switch. Need more info sorry.
Posted on Dec 08, 2012
  • B.H. Countryman Dec 20, 2012
    It may be overfilling because the pressure switch is failing. Or pressure is failing to reach the switch adequately. This is what i do to troubleshoot a pressure switch when i've left by multimeter at home. The Hotpoints i work on are top-loading commercial machines and may be different from yours but i doubt it. If you can see the overflow tube then you must know how to get into it. If your tub is plastic there will be a little box attached to it near the bottom left side with a tube poking out it's top. That tube runs to your pressure switch; but the little box is our 1st check. Notice you can kind of see through that box there should be close to a 1/2" of water in there. It never fills up but more water will enter as the tub fills. First remove that hose from the top of that box and then put it back on. It should come right off and then go right back on easy-peasy. Now start filling the washer; let it fill to at least half-way. Open the lid so it doesn't start agitating and remove the tube again. Keep your eye on that box, it should begin to fill pretty rapidly with water and in fact should shoot right out of the hole on the top in 3 to 4 seconds after removing the tube with a full tub.
    If it doesn\'t fill up then you need to take a paperclip or a piece of wire etc. and ream out the hole until it does. You probably won\'t feel any resistance as it is likely a piece of lent or some-such. As soon as it starts to shoot out of the hole put that tube back on. Congratulate yourself because you probably just fixed your washer. But before you test it out you have to get that box emptied of all that excess water. First set it to drain (make sure to close the lid.) When empty or nearly empty set it to spin cycle and spin for at least one minute (Do Not skip this part. It is important.) You will notice the water is back to the level it was at when you first set eyes on that box. Now run the machine through a normal cycle.
  • 1294 Answers
SOURCE: Water Leak
If possible pull out your drawer and clean it up. Reason due to clogging with detergent, etc. Refer to your manual. If you can't get the drawer out, use a tooth brush to scrub; see that brush does not fall in. The dirt can fall in. To test if clear, pour water into drawer by opening it just so the water will fall in. Try all the drawers.
And rate me pl......
Posted on Dec 02, 2007
BADBOYJAY
  • 264 Answers
SOURCE: whirlpool front loading washing machine leaking
you will have to be nice to it as it will come out and with some fairy up liquid you can put it back so easy
Posted on Jan 07, 2008
aborcass
  • 2651 Answers
SOURCE: Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Posted on Oct 31, 2008
danromarris
  • 101 Answers
SOURCE: Kenmore 70 Series leaking water from bottom
I used to work for Sears as a home repair technician and washers and dryers were my specialty. Most likely the problem is with your water pump. I ran across this issue many times and what happens is people leave things in their pockets and it destroys the pump. A hair pin or coins, I have even seen socks and under ware get stuck in them causing leaks. What you want to do is tip the machine back and look at the pump. It is located right at the front of the washer with two hoses connected to it. You will want a pair of hose clamps though if you don't want water all over your floor. Disconnect the pump and look inside it for anything causing the motor inside to not work, this will cause slow draining and even leaking. If it looks clear then look for any cracks in the pump. If there is a crack then it needs to be replaced. Just call your local appliance repair place and tell them what you need. Pumps run around 30 bucks or less on average for Kenmore's. If everything looks good on the pump check the hoses that run from the pump and make sure there are no cracks or holes in the hoses. If they look good then the only thing left is the tub and the overflow tube. Chances are though that your pump is what the problem is and it is an easy fix. Good luck.
Posted on Jan 21, 2009
SOURCE: My washing machine keeps leaking from the bottom
There are many possible cause of a leak. If it is set to portable make sure that the faucet is off after the cycle. You also need to make sure that you are not over loading the washing machine. Please refer to owners manual how much is the capacity your washing machine can take. Drain lines is also a possibility for this leak as well as the intake inlet. If it's leaking in the center most likely the bearing have broke off and you might need a new center seal. This job requires a professional to be replaced. My advice for Avanti users is to return it and buy something else that is trusted and branded for quality and performance.
Posted on May 21, 2009
What does "HC" mean?
The HC code indicates that the computer thinks the cold water inlet is getting hot water. The hot water inlet has the cold water coming in. Take off the inlet hoses and double check your water lines. If needed, swap the connections. While you have the hoses off, clear the filters and check for leaks. Check the flow rate and replace the hoses if the water flow is restricted. (Anti-burst hoses can reduce the flow when they detect a leak.)
If the hot water supply is correctly connected to the hot water inlet, then the electronic control board is getting faulty information. Unplug the washer for several minutes. If the code repeats, then the valve may be faulty. Alternative causes of the problem are the hoses, the wiring or the control board.
I hope this helps.
Mar 16, 2016 | Whirlpool WTW6400SW Cabrio Washer
Water refuses to come in
Hot water or cold?
If no cold water.... try for hot
Remove Hose at back of machine.
Check for water flow out of hose & any restriction inside connection point. Rubber washer blocking etc.
At Connection point...Does Solenoid valve click in & out.
It should unless timer is off or a door open etc.
This should give you some clues
Mar 05, 2015 | Washing Machines
I have an LG front loader washing maching, model# WM2277H* I have changed both the hot/cold water value and the washer is still leaking.
if leaking on front unit : check rubber seal front glass door. if it ripped you should change it.
If leaking behind unit : check water hose , is it placed properly ?
If leaking under unit : call technician to repair it.
good luck.
Mar 25, 2011 | LG WM-2277HW Front Load Washer
What is problem code IE and how do I fix it on my LG front load washing machine?
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle. if this doesn't help then there are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly. wm_inlet_filter_removal(1).jpg
Hope this helps.
Mar 09, 2011 | LG WM-2277HW Front Load Washer
I have water leaking onto the floor from my LG Tromm washing machine. I tried to check for blockage of the hose but it is still leaking.
Check the connections on the back of the washer for the cold & hot water connections. This just happen to me last week. My husband tighten them and resolved the problem. Good Luck !
Jan 16, 2011 | LG WM-2277HW Front Load Washer
The hot water not flowing into the washer and the cold water flows fine?
Let's think and work this one thru:
Your machine probably has several temperature settings, right?
So-- when you set it for COLD-- it fills at the normal rate?
When you set it for WARM-- does only COLD water still only come in?
And if you set it for HOT-- Nothing comes in?-- correct?
Now lets get to the pipes in the back:
Is there a Laundry sink, or a hose or something nearby, so you can be sure you have HOT water to the Washing Machine?-- Is the Hot water flowing good and strong nearby the WASHING MACHINE-- WHEN YOU TEST IT?
And the Valve is not shut at the Washing machine-- (Hot shut, but cold open?)
If you are sure that you have a good supply of HOT water to the machine,--- If you have tested that you actually have a good flow, -- say with the Hose removed, and you run the Hot water into the machine (by-passing the internal control valve!!)--
Then it sounds like: Either the control is not telling the internal solenoid valve to open-- or the valve needs to be replaced.
Do you want to attempt this repair-- or do you want to call for help at this point?
Let me know what you find-- and how far you want to go by yourself.
Mack B
Dec 30, 2010 | Washing Machines
Check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
May 17, 2009 | Electrolux EW1000i Front Load Washer
Water leaking from hot water connection
Try sliding the panel backwards it should slide off.. Hopefully this should do the trick
Apr 26, 2009 | LG WM-2277HW Front Load Washer
Water Leaks from beneath my washing machine
Our WM2077CW just started the water leaking from underneath. We unplugged the electrical cord and disconnected the hoses (water, drain). We then removed the inspection plate from the back and checked for wet hoses. The big black hose on the bottom was a little wet. On careful examination we found a small hole that looked like a material fatigue failure at the point where the accordion part of the hose met with the solid part of the hose near the main drum connection. I suspect this is may occur in other LG washers of the same design. Unless your floor is perfectly level it's hard to tell whether coming from the left or right side really indicates where underneath the water is coming from.
Nov 26, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
