Question about Brother CS6000i Computerized Sewing Machine
Brother cs6000i bobbin winder broken
Motor runs and bobbin appears to want to turn to wind thread. However, something is stopping it from moving.
  • 16 Answers
SOURCE: Unable to wind bobbin on Brother Css-8150 stopped suddenly
Checking to see if in fact that the bobbin shaft is turning. Run it without any bobbin on the bobbin shaft. Make sure that it is push over in the correct position and run it. I checked on mine and it does make the whirring sound and the the shaft does spin. Also check underneath the shaft to see if there is any thread wrapped around it. ( I had problems with that in the past). I hope this helps,
Posted on Sep 27, 2008
Australian S
  • 46 Answers
SOURCE: Brother CS6000i - Needle breaking, bobbin thread not picking up
There are a few possible causes, firstly make sure you have the correct needle and it is in the correct way and make sure when you fit the needle it is pusshed all the way up into the needle holder. If the shuttle or hook is moving around the bobbin case then the timing may have been knocked out. If the it is not moving it means either the gear or belt that drives the hoo / shuttle has been damaged or broken.
Posted on Jul 02, 2009
  • 52 Answers
SOURCE: Brother SE-270D sewing machine bobbin won't wind
the rubber ring on the bobbin winder has probably gone bad which would mean replacing it but you can buy a portable bobbin winder called a sidewinder for around 20.00
Posted on Jul 16, 2009
  • 8 Answers
SOURCE: brother CS 8060 bobbin wont wind...but motor runs
no idea... did you lock thread onto bobbin so it holds to wind?
Posted on Jul 18, 2009
bargainbox
  • 1388 Answers
SOURCE: The lower (bobbin) thread on my brand new Brother tangles
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
Best Wishes
Martyn
Bargain Box in Australia
Posted on Sep 08, 2009
Needle assembly doe not go up and down when the foot pedal is pressed but the bobbin does turn.
Make sure you have not disengaged the needle bar, such as when winding a bobbin. The manual says that when a bobbin is set for winding and the bobbin winder shaft is moved to the right, the needlebar is disengaged. If that appears to be okay on your machine, perhaps something in that mechanism is broken or misaligned preventing the needlebar from operating.
http://www.manualslib.com/manual/219390/Brother-Xl-2600.html?page=19#manual
Dec 31, 2015 | Brother XL2600 Mechanical Sewing Machine
Bobbin winder doesnt work
The bobbin winder tires on most of the new lower to medium end brother machines have a tendency to sort of melt. I honestly don't know what causes it, but basically the rubber ring that rides the handwheel and causes the bobbin winder to turn will liquify and drip off the bobbin winder and then re-solidify. It would be best to take your machine to a repair shop, to get the tire replaced and to have the old tire sludge cleaned out, though if you are adventurous, you could try it yourself. You can order a tire at the link I've provided, but most sewing machine repair shops can get you one as well.
Bobbin Winder Tire Babylock Brother X55238051
Jul 03, 2014 | Brother CS6000i Computerized Sewing...
Bobbin winder stopped working
The winder ring has most likely broken or come off. This part is not easily installed by a home user as the machine has to the taken apart to replace it.
Apr 03, 2014 | Brother SE-270D Computerized Sewing...
Bobbin winder belt melted
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
Jan 18, 2012 | Brother CS6000i Computerized Sewing...
The bobbin will tread at all! no fabric is caught-up. motor run but not threading.
If you need a manual to see if everything is set up as it should be for winding a bobbin or any other feature of the machine, you can view or download here - http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=CS80
If you are still have a problem, the bobbin winder may be broken.
You can have it repaired or purchase an auxiliary bobbin winder for a lot less money - SideWinder Bobbin Winder where sewing notions are sold.
Mar 20, 2010 | Brother CS-80
I need to know how to thread a bobbin?
TRY THIS, itma not be your model, but should help Title:
ac093.jpg Pre-tension disk ac094.jpg Bobbin winder shaft ac095.jpg Bobbin
1. Pull up the spool pin as far as possible, and then put a spool of thread on this pin. windingbobbin_a0991.jpg
2. Pass the thread around the pre-tension disk. Make sure that the thread passes under the pre- tension disk.
windingbobbin_a0992.jpg ac098.jpg Pre-tension disk c_b4.jpg Pulling it in as far as possible
Caution If the spool of thread is not in the right place, the thread may tangle on the spool pin.
3. Pass the end of the thread through the hole on the bobbin from the inside of the bobbin. windingbobbin_a0993.jpg
4. Put the bobbin onto the bobbin winder shaft and slide the bobbin winder shaft to the right. windingbobbin_a0994.jpg
5. Turn the bobbin clockwise, by hand, until the spring on the shaft slides into the groove of the bobbin. windingbobbin_a0995.jpg ac099.jpg Spring on the shaft ac0991.jpg Groove of the bobbin
7. While holding the end of the thread, gently press the foot controller or press start/ stop button (for models equipped with the start/stop button) to wind the thread around the bobbin a few times. Then stop the machine. windingbobbin_a0997.jpg
Note
  • If the sewing machine is to be operated using the foot controller, connect the foot controller before turning on the machine.
  • When the foot controller is plugged in, the start/stop button cannot be used to start sewing (only for models equipped with the start/stop button).
Caution Make sure you follow the instructions carefully.
If you do not cut the thread completely, and the bobbin is wound, when the thread runs low it may tangle around the bobbin and cause the needle to break.
9. Slide the sewing speed controller to the right (to set the speed to fast).
(For models equipped with the sewing speed controller.) windingbobbin_a0999.jpg ac0992.jpg Sewing speed controller
10. Press the foot controller or press start/stop button (for models equipped with the start/stop button) to start. windingbobbin_a18.jpg
11. When the bobbin seems full and begins spinning slowly, take your foot off the foot controller or press start/stop button (for models equipped with the start/stop button). windingbobbin_a19.jpg
12. Cut the thread, slide the bobbin winder shaft to the left and remove the bobbin. windingbobbin_a191.jpg
13. Slide the sewing speed controller back to its original position (for models equipped with the sewing speed controller). windingbobbin_a192.jpg
Caution Not winding the bobbin properly may cause the thread tension to loosen, and may break the needle.
woundbobbin3.jpg ac0993.jpg Wound evenly ac0994.jpg Wound poorly
Note
  • When the sewing machine is started or the handwheel is turned after winding the thread around the bobbin, the machine will make a clicking sound; this is not a malfunction.
  • The needle bar does not move when you slide the bobbin winding shaft to the right.
Sep 02, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother CS 8060 bobbin wont wind...but motor runs
Jul 17, 2009 | Brother CS-8060 Computerized Sewing...
Threading bobbin on singer stylist 522
To wind a bobbin put the cotton reel on the top pin, take the thread to the left and round the little wheel and back to the bobbin that should be on the winder, wind the thread round a few times to take a grip, release the stop motion in the balance wheel, turn the winder button so the winder moves to the balance wheel and press on the foot control slowly.
When you put the bobbin in the bobbin case make sure it turns anti clockwise.
Jun 27, 2009 | Brother CS-8072 Computerized Sewing...
BOBBIN WINDER NOT WORKING RIGHT
Try to lift the guide before the bobbin winder, by 2-3 millimeters.
If you can't lift the guide, then put something between the two, (a magnet perhaps) just to lift the thread a little bit upwards during winding.
Jun 09, 2008 | Brother CS6000i Computerized Sewing...
Brother CS6000i Computerized Sewing Machine Logo
251 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
