Question about Emerson MW8107WA Microwave Oven
How to replace a fuse on a emerson microwave - Emerson MW8107WA Microwave Oven
  • etterpaint
    etterpaint Dec 08, 2012
    The micowave is a MW811ss
5 Suggested Answers
MicrowaveSvc
  • 9085 Answers
SOURCE: Blown Fuse
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
Posted on Apr 01, 2008
  • 234 Answers
SOURCE: Replace Emerson Microwave Ove Fuse
Most of the manufactory has put them in the back where the power cord comes in.
Posted on Mar 14, 2009
rhozel2010
  • 269 Answers
SOURCE: Emerson MW9111 will not heat- all timers & clock work
Hi! try checking the fuse that goes to the magnetron.
Posted on Sep 12, 2009
  • 9 Answers
SOURCE: Emerson Microwave Model MW8119SB found blown
Chances are that either the diode or capacitor are shorted. Be very careful, the capacitor can store a charge and should be discharged first for safety. Hope that helps...
Geno
Posted on Dec 06, 2009
My Emerson Microwave MW9117W has lost power and was wondering if there was a fuse or something that needed replacing
There are fuses inside. The big thing is to figure out why the fuse went bad. either something shorted and blew the fuse, or it got hot and went bad due to bad connections at fuse holder. or maybe a bad door switch blew the fuse. I have also had fuses just get old and tired., and just needed to be replaced.
Aug 19, 2017 | Emerson Microwave Ovens
My emerson microwave will not power on
First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open. Use the VOM
God bless you
Apr 02, 2013 | Emerson Fans Emerson MW8115SS Microwave...
Emerson Microwave Model MW8119SB found blown fuse. Replaced fuse power came back punched in 10 sec started microwave and fuse blew again.
Geno
Dec 06, 2009 | Emerson Microwave Ovens
Normally when you take the cover off, the fuse will be on the right of the oven on the circuit board.
Sep 10, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Emerson Microwave stopped working
Have 1 of 2 choices, the main fuse or the control board for the front switches and clock. primary of the small power transformer has opened. Unplug the unit and take case off and measure the fuse with an ohm meter. if u read 1 ohm or less then fuse is good. then measure across the main power plug tips. If read open then the power transformer is bad. Need to replace the board as not sure if transformer is available.
Jul 26, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Mar 13, 2009 | Emerson MW8168B Microwave Oven
Need a replacement fuse for an Emerson Microwave Model MW8774
Please understand there are some liability issues that Emerson or their parts supplier have in selling you the fuse.
You should be able to find one by going online and searching with the terms you gave, using Google. I just did, and there are a number of hits to choose from.
Try Sears Parts Direct or Repair Clinic as well. You will need to enter your model number to find the parts listing.
In all likelihood, you have a failed controller board or microwave circuit (magnetron, transformer, diode, capacitor). Be prepared for additional troubleshooting.
REPLACE THE FUSE WITH AN EXACT REPLACEMENT> DO NOT REPLACE WITH A LARGER (more amps) FUSE TYPE.
Jan 16, 2009 | Emerson MW8777W Microwave Oven
Emerson MW8106W Blew internal 20A fuse.
You almost certainly have a shorted high-voltage capacitor.
Here is a link you or someone you know can use for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing researchdept@fox-international.com
Many Emerson microwave owner's manuals are available for free download here.
Oct 19, 2008 | Emerson MW8106W Microwave Oven
Emerson MW 8115SS
There is a 20 amp replaceable fuse inside the cabinet next to the power cord
Aug 17, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
Emerson MW8107WA Microwave Oven Logo
206 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
