Question about Sony XM-SD22X Car Audio Amplifier
Car amp has power but will not push subs
Amp started smoking one night and stopped workin. i took it apart and saw nothing burt or anything that appeared out of the ordinary. hooked it to a friends subs and still nothing. power light comes on but no protect. hooked my subs to friends apm and they worked fine
  • Anonymous Apr 07, 2009
    amp has power but its not pushing subs
  • Anonymous Mar 30, 2014
    the car has a built in amp all ready. so i just want to hook up a amp for a 10' sub
  • 15,935 Answers
Output blown on power supply - repair by tech required.
Posted on Jan 12, 2009
I have an 1982 suzuki gs g. a few days ago someone bumped into and knocked it over in the night, the next morning when i tried to start it, it almost turned over, but a bunch of blue smoke came out and it...
Since the bike laid on its side all night,oil got into your top end and just needs to be run till all oil is cleared out.Clean the air box and anything connected to it.The breather from the crank case runs to the air box,that's why there's oil in it.Should only be a fine mist when running.This is the bottom ends only way to breathe,piston goes up,pulls air in from breather hose.Piston goes down,makes pressure and has to have a means to releave that pressure from the cases.This is how the bulk of bigger bikes are set up to opperate.Just laying on it's side for any length of time won't hurt anything other than what I just said.Takes a bit of time for it to finally clear all oil from tha breather system,and you'll have to change your plugs a coupl of times.Use NGK's that burn oil.
Oct 02, 2013 | 2000 Suzuki VL 125 Intruder LC
I have a Kenmore Model/Stock No.110 86568100 65681. It just stopped working late night. When I push the start button, nothing happens. I took the top of the dryer off in order to see if there was...
I would 1st check breaker. If that's not tripped, check power supply. There should be 220v. If those 2 things check good, there's several things it could be. Motor, timer, thermal fuse, door switch, start switch, and maybe a few others I'm forgetting.
Aug 23, 2017 | Dryers
Driving 2004 Grand Am down the road and it decides to shut down ! Got it started just enough to get it pulled off main road and saw smoke out back in mirror. Lights on radio works car only clicks when you...
YOU SAW SMOKE COMING OUT EXHAUST PIPE.SOUND LIKE BLOWN HEAD GASKET.TOO MUCH ANTIFREEZE GOT IN THE CRANKCASE AND CYLINDER BLOCK BY THE PISTONS CAUSING ENGINE TO HYDROLOCK.CHECK CRANK CASE TO SEE ITS FULL OF COOLANNT.IT WILL LOOK LIKE A MILK SHAKE.
Jun 20, 2010 | 2004 Pontiac Grand Am
Sony xplod amp won't work it stopped for no reason
try hooking the amp up with 3 wires, the red power wire, the black ground wire, and the remote wire, do not hook up the speakers at this time
Apr 25, 2010 | Car Audio & Video
The motor from my reciprocating saw started emitting smoke.
That small black piece, was it somewhat flat? I am thinking that it could be part of the fan or baffle. As far as the smoking when you had it apart how did the windings look on the armature and field? It is possible that this piece of plastic opened up the windings and there is a short in the electrical components. If that is the case I would suggest taking to a repair center to get is looked at. Let me know what you find
Jan 03, 2009 | Porter Cable Variable Speed Quik Change...
Hoover Savvy runs but has a burning smell...
Could be that the motor went bad, or one of the circuit boards is bad. The brush roll motor is the likely suspect.
Apr 14, 2008 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Smoking
Gee I would think that it is kind of obvious; your amp is blown. Just because it doesn't blow fuses doesn't mean much. If you hook the power up to the ground input and the ground to the power and then turn it on you pretty much toasted the amplifier. If you don't know why the amp is smoking, but you're trying to fix it yourself, you are basically telling me that you have no business doing so. I have been an installer for 15 years and even I am not dumb enough to try to fix a bad amplifier. Do everyone a REALLY big favor; stop messing around with something that you don't understand of have knowledge about before you hurt yourself.
Mar 16, 2008 | Legacy LA838 Car Audio Amplifier
Amp Turns on... then off
unplug all speakers and see if it still into protect .If unit powers up normally without speakers , then hook up a temporary speaker directly to speaker out to see if you have output.If it works .Then check speaker cables and speakers for shorts.Also make sure you have good ground and main power and standy are present.
Nov 30, 2007 | Kenwood KAC-9102D Car Audio Amplifier
AMP not workin
if you saw smoke something fried, im surprised it still kicks on at all. my best advice is if you kno how to use a soldering iron, see if you can locate the problem, (i.e. melted wires and such), if not best would be to look for a new amp. hope this helps
Sep 19, 2006 | Lightning Audio LA1.150.2 Car Audio...
Sony XM-SD22X Car Audio Amplifier Logo
327 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
