Question about Google Toolbar
Screen on side - Google Toolbar
  • Google Master
  • 27,725 Answers
You can use the desktop toolbar on your computer to help you navigate around your computer, gaining access to programs and files. You may have previously moved the toolbar to the side of your desktop intentionally or accidentally. You can move the toolbar back to its original position at the bottom of the screen and lock it in place to prevent it from being accidentally moved in the future.
Right-click on the toolbar at the side of your desktop with your mouse. Locate the "Lock the toolbar" option in the drop-down menu. If it has a tick next to it, this means it is secured in place. Left-click on the button with your mouse to unlock the toolbar. Left-click on the toolbar, and drag it to the bottom of the screen. Right-click on the toolbar, and select "Lock the toolbar" to fix the toolbar in place at the bottom of the screen. Hope this helps.
Posted on Dec 11, 2012
How do I create a split screen so I can see questions and answer at the same time?
Try this: right click on the taskbar and a pop up box should show up with options, stack screens, cascade screen, and side by side. Click on the side by side.
Oct 28, 2013 | Computers & Internet
The screen display of doubledown casino is cropped on the right side. I don't get a full screen. I cannot click on to invite friends.
The right side of the screen is copped. Icannot get to the icon to cliuck to invite friends or to start to play. I noticed that the screen was getting cropped earlier. When I returned to the game The right side was cut off.Why?
Jan 02, 2013 | Evermoremedia DoubleDown Casino
Panasonic plasma TH-42pz700 has left hand side of screen distorted
The set uses two boards to drive the screen --one for each half or side.
Different names are used like sustain or in LCD sets inverter.
Apr 02, 2012 | Panasonic Viera TH-42PX80U Plasma TV
4gb pmp350-4 mp3 player touch screen. Screen is back only can see a shadow images of icons try to reset screen is still very dark. can this be fix?
From the main menu of you mp3 player touch the lower right corner of the screen, then touch the lower left side of the screen, then press the lower middle section of the screen. Then press the lower left side of the screen again and then the lower middle screen. Then press the lower left side of the screen until the screen brightens. From there you should see your screen to further assist yourself...Your welcome(:
Dec 27, 2010 | Polaroid Juke Jam PDP602 MP3 Player
Touch screen letters inop on right side. Also when I try to scroll on left side it selects a street instead.
try to calabrate the touch screen if it dosnt work replace the touch screen part# CSX1085
Jul 22, 2009 | Pioneer AVIC-D2 DVD Nav/6.5"...
Heated rear window of a renault laguna is not working
hi.disconnect both sides of heated element on rear screen.connect a wire on one side and the other side maybe using a spade connector.connect one side to a 12v car battery same with the other.may get a slight spark.leave on and see if screen gets hot.better when mist is on screen to see working.if it doesmt demist more than likely screen needs replacing.try a electric meter connected on screen.should be lowish resistance.also try connecting a volt meter to the screen heater connections you taken off screen.one lead one side and same with other.set meter to volts normally 20v setting.put key in car switch one rear screen .voltage should read on meter.about 12v.if not switch may be faulty or heated screen relay.hope this helps
Mar 18, 2009 | 2004 Renault 181
Ds lite
To remove the top external casing first you have to separate the top part from the bottom part of the DS by dissasembling the bottom part and unplugging the top screen ribbon and the white and black wires, then slide these cables through the hinge hole to separate the parts.
Then you must take out the 4 screws under the cover pads in the screen side, and slide the screen side from the external side so the screen side should move like 5mm from the external side and then you would be able to separate both and see the screen, mic and speakers.
May 12, 2008 | Nintendo DS Lite Console
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
I need to replace a broken screen on my sony kf 50we610
Hi drdoolittle,
Some screens have labels, so place them so the labels are upright and tward the front of the TV.
The outside screen is the lenticular screen. The black vertical lined side is outside. The fresnel screen has very fine circular lines in it. You can find them by feeling them. This goes against the lenticular back side of the screen. the fesnel has a flat side that is the back. It will be tward the mirror. If the mirror has two shiny sides, then it should be placed with the mirror side out. You can tell this by placing your finger tip on the mirror. If the finger nail meets a fingernail, then this is the mirrored side. Install this side tward the front.
Try to keep dust from between the screens. Check by looking through the screens before you put the in the frame. Then check them again after you put them in the frame.
Wear latex gloves to keep finger prints away.
Clean back of screen assembly and install the screen on the TV.
You can now watch the TV.
Cheers, CrazyLee
Sep 07, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Computers & Internet Logo
56 people viewed this question
Top Google Computers & Internet Experts
Robet
Robet
Sunil Pratap Singh
Sunil Pratap Singh
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
