Question about Passport 8500 Radar Detector
Is there any way to direct wire a pasport x50 8500 direct into car without using cigarette lighter plug
  • Anonymous Mar 30, 2014
    power wire schematics
    can I wire direct instead of using cigarette lighter cord
  • 15,935 Answers
Cut the plug. Attach the wire centered in the cig. lighter plug to 12V switched power, and the other to a ground.
EZ
Posted on Jan 12, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Where is cig lighter fuse in a kenworth k108
Most 12 volt outlets/plugs like one would plug a GPS into or a cigarette lighter, are 'hot' all the time. This means that they are hooked direct to positive side of the electrical system. If your cigarette lighter is not working check the wire from it to the hot side of the fuse block.
patrick
Jan 10, 2015 | Cars & Trucks
Can i use tomtom in 1996 ford mondeo cigarette lighter
So long as it is a 12 volt negative ground system then yes. Plug ins are designed for cigarrette lighters in cars.
Nov 24, 2013 | Tomtom GPS
Hi,i'm having trouble with the cig lighter on my car, it keeps blowing fuses. can i wire it directly to the battery with an inline fuse? How would i do this?
you could do this by running 2 wires directly from the battery to the back of the cig lighter and by fusing the positive.if it is only when using the cig lighter and not when charging a phone ect.it could be element on the cig lighter shorting
Apr 05, 2010 | 2000 Volkswagen Golf
Cigarette lighter need repair
Just remove the panel that the plug is in and disconnect the two wires behind make sure when purchasing new one you get OE direct fit...
Apr 03, 2010 | 1992 Chevrolet Lumina
Cigarette lighter plug still does not work after changing fuse.
Possibly the wire has come loose. This happens a lot with lighters! Try putting your finger in ( it won't hurt you, and you won't get electrocuted ), and turning the insides in a clock-wise direction . You will feel the whole lighter tighten up. If this doesn't help, turn it in an anti-clockwise direction. This will take the socket out of the car. Check that the two wires on the back of the lighter are firmly connected. Then put the lighter back in, and hopefully it's OK.
Mar 01, 2010 | 2003 Chevrolet Suburban 1500
Cigarett lighter power
The power wire for your socket is connected to the ignition switch. For the socket to operate without the key, the power wire must be relocated to a direct power source or directly to the battery. You can locate a "hot" source by using a 12Volt tester on the terminals of the fuse box. Just touch the tester to the terminals until one lights up without the key on. That terminal is "hot" and will allow your socket to have power at anytime. You should use a power source with a fuse for safety. You can hook directly to the battery but you should add a fuse inline to be safe.
Feb 23, 2010 | 2003 Toyota Tacoma
Powering a car amplifier
Bad idea. The wiring leading up to your cigarette lighter is usually a cheap 16 gauge wire. The amplifier will not be able to draw enough amperage through that power source. You could however, use the positive on your cigarette lighter as your remote for the amp. This would be helpful if your cigarette lighter turns off and on with the car.
Jun 24, 2009 | Car Audio & Video
Tottom direct power supply
No, it will fry the unit!!!
You need the cigarette lighter adapter to bring the voltage down to 5V. More than 5V will fry the One.
Apr 02, 2009 | Tomtom ONE 3rd Edition GPS
Zumo 450 Power Through Cigarette Lighter
You should be, Check to make sure the fuse isnt blown on either the cigarette lighter plug or in the plug that has the wires coming out of it.
Nov 24, 2008 | Garmin zumo 550 GPS Receiver
Passport 8500 Radar Detector Logo
177 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
John Nolan
Jason
Steve
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
