Question about Epson EMP-1715 LCD Projector
Epson 1715 overheating - Epson EMP-1715 LCD Projector
Can i use a gps30 with 1715 furuno
You can interface the GP30 to the 1715 and get Lat/Lon readings where the cursor is. The GPS has extra wires in the power cable. The 1715 will require a NMEA cable pn 000-154-028. Connect the white GPS wire to the yellow radar wire and the blue GPS wire to the green radar wire.
Feb 24, 2014 | Furuno GPS
My teperature light won't go off on my Epson EMP175 projector even after cleaning the filter and changing the lamp? Could it be a bad temperature sensor? How would I replace it and what is the part #? ...
Hello
This is definitely an overheating prolem,unplug the power cord. Plug the power cord back in and press the Power button. Make sure the room temperature is not above 95 F (35 C) and there is plenty of space around and under the projector for ventilation.
The air filter might need replacement.
If the projector continues to show the temperature light after you clean/replace the air filter, the problem may be caused by damage to the cooling fan or temperature sensor. Contact EPSON for help.
Dec 22, 2010 | Epson EMP-1715 LCD Projector
My Projector color is completely messed up, I have reset it and everything still looks pink.
In the image menu, make sure that your RGB/Component settings are correct. If they are incorrect this will cause a pink tint on the projector.
Oct 26, 2010 | Epson EMP-1715 LCD Projector
My new boat rader the furuno 1715 wil not tune.
Yes and it is in the book a new installation needs calibration!! The rough tuning is off by the sounds of it
Jan 14, 2010 | Furuno 1715 7" Monochrome Lcd 2.2kw Radar...
A furuno 1715 lcd radar was wired to battery backwords
internal damage to the display, fixable by Furuno, and probably economically feasible (guess $250 with round trip to Furuno)
Nov 17, 2009 | Furuno 1715 LCD Radar System GPS Receiver
Bissell 1715-g spotlifter
www.bissell.com and search model # 1715. It gives you the option to see the owner's manual in PDF.
Dec 12, 2008 | Bissell 1715-G Spotlifter Bagless Handheld...
Epson EMP-1715 LCD Projector Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
