Question about GE Microwave Ovens
How do you reset a GE microwave model#JES1358WL01
How do you reset this microwave
4 Suggested Answers
  • 58 Answers
SOURCE: Microwave manufactured August 2008,
You may be able to remove the back panel (after you unplug it of course) and change out the fuse if its burned.... I have read up on these microwaves and there seems to be a lot of them doing this same thing. If its not the fuse then you are probably better off buying a new one because the repair cost will be more than the microwave itself........ Your looking at a repair cost of around $312....... Depending on who does it. Just try to replace the fuse and if that doesnt work, you can have somebody look at it if would like.
Posted on Aug 06, 2009
  • 672 Answers
SOURCE: I have GE microwave 1200
This link will take you to GE website and a pdf view of your needed manual.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40515-1.PDF
Posted on Aug 29, 2010
SOURCE: I have a GE model
well i have exact same model and there is a wire on inside of unit just on the right hand side that melts into 2 seperate pieces, this is the second time this has happened to mine so i will definantly be replacing it since there are only 3 service parts for this unit and none of which are a wiring harness nor a big convertor box
Posted on Nov 25, 2011
It is a GE microwave that says reset filter
Open the microwave door and press the access panel above the cavity opening where it says "PUSH" to lower the panel door. Models with an Upfront Filter have a Reset Filter notification light on the control panel to indicate when it is time to change the filter. The Reset Filter reminder will light every 6 months.
Sep 16, 2017 | GE Microwave Ovens
Reset clock on over the range microwave
Go to this link....you can download the users manual. The procedures for setting the clock are on page 22 of 68.
JVM1950SR1SS GE MICROWAVE Manual
Nov 02, 2014 | GE SpaceMaker Microwave Ovens
Microwave manufactured August 2008, Model#JES1358WL01, Ser#RR910340U made a lot pop last night, quit working, would not work again
Aug 06, 2009 | GE Microwave Ovens
Reset shows on display of my GE space saver microwave oven
change the board that has the reset on the display board it is bad
Mar 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave stops running after 3-5 seconds
hade same problem upper door switch by past it microwave works
Nov 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE model JES1358WL01 microwave. There is power, but it will not heat the food. What could my problem be?
Oct 14, 2008 | Microwave Ovens
Microwave JES1358WL01 Model # Serial# TL903007U Oct 2006 Date of Purchase 12/4/2007 WalMart Anadarko Ok Stopped working 5/2/2008 Kept working after the door was opened then would not work after I...
Since it's less than a year from your date of purchase, this should be fully under warranty.
The problem is most likely a bad door switch or door switch alignment, but let GE take care of it for you.
GE Customer Service is at http://www.geappliances.com/service_and_support/contact/
They can connect you with your nearest GE-authorized service center to fix it for you.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 07, 2008 | Microwave Ovens
My approx. 6 wk old GE Microwave (Model JES1358WL01), Ser.#TM904440U began "arcing" last week for no apparent reason--it did it again this morning while I was reheating my coffee...the same...
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet. In some models it is the plastic ceiling.
The small type can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 20, 2008 | Microwave Ovens
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
