Question about Kenmore 63942 Dryer
How do you change the dryer vent on a Kenmore 800 series
It vents from the back and we would like to vent it from the side. There is a knock out for a side vent.
  • 640 Answers
Yes and here is the part kit that you need..part # 279818..onthejob..everthing you need is in this kit..it all comes together..
Posted on Jan 18, 2009
Kenmore dryer 70 series
Check the vent for clogs and kinks. Could be something in the blower wheel causing the noise and blocking the vent.
Remove the vent from the back of the dryer, unplug the dryer, and reach inside the dryer vent to check for items lodged in the blower housing.
Feb 04, 2014 | Dryers
How do you side vent the Kenmore 800 dryer? I cannot rear vent the dryer due to space limitations. I MUST side vent.
You will need to take the dryer apart, pull the drum out. Then at the bottom you will see the main discharge, take it off and insert a 45 degree elbow, you will need to then install hard venting to reach the knock out on the side. Be sure to use metal duct tape when sealing the venting to avaoid fire haz.
Nov 09, 2010 | Kenmore 800 7982 Dryer
Moved dryer to a new home. Dryer vent comes out of the middle of the dryer. New home vent is next to the outside wall so i have a bend off the dryer vent and then a bent to the out side vent, Can you...
Some Kenmore dryers have a knockout at the back, lower corner that can be "knocked out". If you have one of these it can be vented out through the side. If the knockout is there, a kit is available for the venting. Just go to www.sears.com and under the parts direct tab enter your model number aka 000.00000, and search out the kit.
Aug 29, 2010 | Kenmore Dryers
How do you change the vent outlet direction?
there are knock out panels on both sides of the dryer. knock out the one you want to use with a hammer and flat head screw driver or chisel. Some dryers you have to remove the back (others you may have to remove the front) and disconnect the vent going out of the back of the machine and reinstall a new hose or pipe on the outlet where you removed the vent and run it through your new hole to the outside vent.
Jul 11, 2010 | Maytag PYE2300AY Electric Dryer
How can I change the vent from back to side
Hello my name is Heath it will be my pleasure to assist you. What you need to do is knock the knock out in the side out then you will have to pull the back off the dryer and connect the fflexible dryer vent hose to the connection insdie the dryer and run it through the side of the dryer to the outside termination.
Jun 22, 2010 | Dryers
Need to change venting from back to right side
there are knock out panels on both sides of the dryer. knock out the one you want to use with a hammer and flat head screw driver or chisel/ you will then have to remove the back and disconnect the vent going out of the back of the machine and reinstall a new hose or pipe on the outlet where you removed the vent and run it through your new hole to the outside vent.
May 27, 2010 | GE DPSE810EGWT Electric Dryer
Kenmore series 80 dryer not heating
UNPLUG REMOVE THE BACK,YOU WILL SEE THE HEATER BOX TO YOUR LEFT,THERE IS A SMALL FUSE ON THE LEFT SIDE TOP,CHECK THAT IF YOU HAVE A METER,ON THE BOTTOM HALF OF BOX IS THE HEATING COIL,REMOVE THE 2 BOTTOM WITES AND CHECK THAT WITH YOUR METER,IF YOU DON'T HAVE A METER REMOVE THE 2 SCREWS ONE ON EACH SIDE OF THE HEATING COIL AND REMOVE THE COIL,LOOK TO SEE IF ANY OF THE WIRES ARE BROKEN,IF IT WAS THE FUSE THAT'S BAD THERE MUST BE A REASON IT POPED,MAKE SURE YOUR WALL EXHAUST VENT IS CLEAR,ALSO IF YOU CHANGE THE FUSE CHANCE THE HIGH TEMP THERMOSTAT LOCATED ON THE LEFT SIDE BOTTOM,YOUR MODEL NUMBER IS INSIDE THE DRYER DOOR-MIKE
Mar 07, 2010 | Kenmore 800 7982 Dryer
Need to change vent from rear to left side
why don't you just go to home depot and buy a longer flex hose?mike
Feb 19, 2010 | Kenmore 64942 Electric Dryer
Kenmore 80 series Dryer: Door Light stays on and wont start
Mar 05, 2009 | Kenmore 800 7982 Dryer
Clothes don't dry but dryer gets hot
ck vent to outside starting and dryer back to verify vent issue try drying a load with hose disconnected
Nov 24, 2008 | Kenmore 60172 Electric Commercial Dryer
Kenmore 63942 Dryer Logo
276 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
