Question about Sport & Outdoor - Others
Doesn't work when plugged in
No action when plugged in
    Problem Solver:
  • 10 Answers
Sounds like a power supply problem
Posted on Dec 18, 2012
Continusly red green lights on and no action
if the print dialog window indicates that there is a printer malfunction, check the printer for any possible paper jams, then check that the printer cartridges are inserted properly. close the dialog window, and press the blinking button on the printer.
if that doesn't work, restart printer: either press on/off button or unplug the printer. wait 15 seconds, then turn on/plug in the printer.
Oct 30, 2012 | HP LaserJet 1015 Printer
My Garmin Etrex Legend doesn't work its keys?
Go to garmin website , is it still under warranty?
Jul 14, 2012 | Garmin eTrex Legend GPS Receiver
My xbox 360 wont work because i had it 3 years now, i put a game in doesn't work... i need help people...?
If it no longer works because you had it for 3 years, then you know the solution: Never keep an Xbox for longer than 2.9999 years.
If there's a hard drive inside, this could be seized due to lack of use. Grab the Xbox on opposite corners, and as violently as you can, rotate the case back and forth in the plane that the hard drive is mounted in. This action may loosen the drive's platters. I'm just guessing. Do lights come on when plugged in or does it look dead?
May 05, 2012 | Microsoft Xbox 360 Console
REMOTE DOOR AND TRUNK LOCKS DON'T WORK, WINDOWS DON'T WORK, RADIO DOESN'T WORK ON 1997 BUICK PAQRK AVENUE.
Did the problem come on suddenly or was some previous action or work done......
Nov 08, 2011 | 1997 Buick Park Avenue
Page not printing on Canon PIXMA MP750
That's as common as rocks with inkjets, especially if Copy doesn't produce visible output. Fortunately the clean cycle gets results pretty often. You need to heed the printer humidity spec. and follow the manual's further actions for when 'Clean Head' doesn't work (typically cleaning its bedding and/or running some rubbing alcohol through via a handy empty cartridge.) See your local ink refiller if you want a friend to lean on for cleaning cartridge fiddling.
Oct 22, 2011 | Canon PIXMA MP750 All-In-One InkJet...
My car cranks up, but will not turn over...??
Hello and welcome to FixYa!
As a first course of action, I strongly suggest that you pull out one spark plug and connect on plug wire. You will need a little help here, put the spark plug tip on the engine and have it cranked by your helper. If there's no current then you definitely have a bad coil pack.
The coil pack gives current to the plugs to burn fuel. Your coil pack can be faulty that's why it only cranks but doesn't turn. Have it replaced and you'll be good.
Hope this helps and thank you for using FixYa! Have a good one!
May 05, 2011 | 2002 Chevrolet Malibu
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
Sport & Outdoor - Others Logo
515 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
