Question about Canon imageCLASS D860 All-In-One Laser Printer
I have a canon imageClass D860 and does not want to print or make copy from the Multi purpose tray. It always says paper jam. When you check there is paper jam.
  • Canon Master
  • 19,396 Answers
Remove the multi purpose tray and put it back in place.
Check the traction rollers that pick up the paper from tray, see if you can access them and move them gently with a screwdriver or a tip, just in case they are stuck, if paper jams on one side only, it is one of the rollers.
Posted on Jan 12, 2009
    Scholar:
  • 160 Answers
. There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
  • 45 Answers
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
No Image on copy after paper jam
Maybe problem with the scanner,see if it mooves
Jun 20, 2015 | Canon imageCLASS D860 All-In-One Laser...
MF4350d 1page only
You must check the paper settings, Canon MF 4350d have two trays, the Cassete/Drawer & MP tray or (Multi-purpose tray).
Go to Paper Settings found the panel of the Printer, Set Cassete tray as A4 or LTR size & MP Tray as Long size or Foolscap(FLSP).
You must go to Start>Devices and printers>Right click the Printer>Printer Properties>Preperences>Page size change to Letter>Apply and press Ok..
Make sure that everytime you print,it will match the paper size you want to able to use,..
Jun 07, 2014 | Canon ImageCLASS MF4350d Laser All-in-One ...
Canon imageCLASS D860, starts fine feeds paper through toner end then stops half way through. Sytem shows paper jam, but paper just stops moving. I can open it and lift paper out. paper wt. 20
try cleaning the pick-up and feed rollers with alcohol and see if that takes care of the problem. if it does for a short time that you need to replace those rollers
Feb 19, 2011 | Canon imageCLASS D860 All-In-One Laser...
Paper Jam but no papaer found Canon Image Class D860
Have you checked that the paper path is clean and free of paper fragments which sometimes get jammed in the sensors? Try blowing them with a compressed air bottle.
Aug 24, 2009 | Canon imageCLASS D860 All-In-One Laser...
Line appears on copies when using the automatic feeder.
You have a piece of dirt or whiteout on the scanner glass. When the paper is moving by, it creates a "Line" if the paper is sitting still on the glass, it may be a dot or it may even use a different glass alltogether for ADF vs Paltten scanning.
Jun 09, 2009 | Canon imageCLASS D860 All-In-One Laser...
Multi Purpose Tray does not print or make copy
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 12, 2009 | Canon imageCLASS D860 All-In-One Laser...
Default Tray
Did you set the default tray in the "Printer Properties" in Control Panel? Or, if you did, do you get any paper tray related error messages? It's possible that there is some sensor flag that's malfunctioning. Usually, however, it's just a setting in the printer driver.
Sep 05, 2008 | Canon imageCLASS D760 All-In-One Laser...
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Canon imageCLASS D860 All-In-One Laser Printer Logo
42 people viewed this question
old marine
old marine
