Question about Amana NAV2335A Top Load Washer
Amana washer will not complete rinse cycle
Will not advance through rinse cycle, will just cycle over and over again
fanny
  • 146 Answers
SOURCE: Amana Top Load Washer model# LW3502W
Sounds like the water seal is damaged and the leaking water has damaged the top bearing which is just below the water seal. You will need to have the hub & seal kit replaced.
Posted on Oct 31, 2007
aborcass
  • 2651 Answers
SOURCE: stall in rinse cycle
loks as if its been amonth since this post, but i would chek your cold water supply, common problem
Posted on Oct 07, 2008
SOURCE: AMANA DISTINCTIONS FABRIC CONDITIONER RELEASE
MOdle NAH6800 I beleive its either 2 or 3 years old. I have water in the outer tub. I can hear it when I turn the tub is this normal
Posted on Mar 21, 2009
localwonder
  • 6784 Answers
SOURCE: TIMER ON WASHER MAKES A TICKING SOUND DURING CYCLE
HI, this timer is faulty and, these are early warning signs of potential failuer of this device in the near future. i would prepare to replace the timer control soon. the actual mechanism is showing signs of breakdown.
Posted on May 23, 2009
blueextc3221
  • 15935 Answers
SOURCE: amana
The timer is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Tip
We have a Kenmore 90 series hvy duty top loader, it works fine in wash cycle but...
This advice is for all Whirlpool manufactured TOP LOADING washing machines. This includes Kenmore, Estate and Roper models as well. This is an easy repair that anyone with a little know-how and determination can perform.
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up.
If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the white plastic lid switch connector plug. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located adjacent to one of the lid hinges in the rear.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first (this is the end of the clip with the 90 degree bend), and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
I hope this information is helpful..
on Jul 26, 2010 | Washing Machines
Washer will not advane from wash to rinse
It sounds like, when the dial gets to the pump stage, the contact expected to pump the water out isn't making contact. That could be a burnt contact within the controller, or a loose wire to to the pump from that section of the controller. Once the weight, or water level was low enough from your pumping it out, the sensor that checks the level/pressure allowed the spin. The problem could be on the control board too.
Here's an incomplete schematic I found:
http://www.doityourself.com/forum/electric-large-kitchen-home-appliances/474475-front-load-washer-amana-model-nfw7200tw.html
Jan 02, 2014 | Amana Front Load Washing Machine Washer...
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
May 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Does not advance from wash to rinse to spin
The washer is new and under warranty so I have asked for warranty service.
May 23, 2009 | General Electric WSXH208H Front Load...
Washer will not advance in the rinse cycle,water just runs continuely.
check the drain hose it should be only 6 to 8 inch in your drain line if drain hose is all the way in the drain line correct it and you will be fine.
May 21, 2009 | Washing Machines
Amana NAV2335A Top Load Washer Logo
121 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
