Question about Audiovox Televison & Video
Parking Break Override
I just purchased the Jensen Phase Liner series UV8 moble media reciver. I had no problem with the install util the parking break defeated me from watching dvd. I have a 2002 GMC Envoy and I need to know how to override this parking break issue. I have read others replys to just ground the wire to a part of the frame but I do not know where this would need to be. Please help.
    Problem Solver:
  • 14 Answers
Simple if you don't know where to ground the wire to, just ground it with the ground wire of the radio. Twist the pink and black wires together, then put them with the black ground comming from the car. Hope this helps.
Posted on Oct 06, 2009
How do i override the emergency brake with remote to uv8
Look for dvd hack for that model. I see some on ebay
Jan 05, 2010 | Jensen VM9510 Car DVD Player
I need the code to disable to parking break to watch my dvd's while driving with my jensen phase linear uv9
you will need the remote control to do so.
1.turn the radio on and select the setup menu.
2. while in the setup menu, use the remote and press 5-4-3-2-1-0, this should access another service menu.
3. from there, you will see a brake override option.
4. and your done.. hope this helps
Aug 17, 2009 | Phase Linear Car Audio & Video
Parking brake on a phase linear uv8
pulll the unit out there will be a wire marked park brake or most likly pink (remeber coming from the head unit ) next splice it in to the black wire or to a ground
Jan 30, 2009 | Jensen VM9411 Car Video Player
Jensen uv8 bypass code didn't work
no the code should work . unless jensen put a stop to the code in the newer modles.
Jan 19, 2009 | Jensen VM9510 Car DVD Player
Product jensen uv8 nov. 2007 model in a trooper 1996 auto
The pink wire in most instances is the DVD's sensor that the vehicle is not in motion and is parked. It then allows the DVD player to display the movie not the warning message nor the blue screen.
Your description "...pink wire on a bolt attached to the body..." indicates that said wire is constantly grounded. The DVD then cannot sense that the vehicle was parked. What this tell us is that the pink wire must first have a +12VDC before it is grounded. This changeover from + to 0 is the trigger. What is required is to have a single pole double throw switch. One end terminal is wired to ACC B+12 while the other to ground with the center terminal to the pink wire. Moving the switch from position OFF to ON (+12 to GND) simulates the parking brakes condition and will enable DVD playback.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 02, 2008 | Jensen VM9510 Car DVD Player
Place the pink wire to a ground. Hope this works for you.
Jun 01, 2008 | Jensen VM9410 Car DVD Player
Phase linear uv8 parking brake problem
for the uv8 to bypass the parking brake to watch dvds you have to take the pink wire and put one end to one of the screws on a two screw toggle switch connect the other end of the pink wire to the other screw and connect that to the black ground wire
Mar 12, 2008 | Phase Linear UDV9010 Car DVD Player
Phase Linear UV8
go to setup hit 543210 but hold 0 then turn the bake override on and then hit the X
Dec 11, 2007 | Jensen VM9510 Car DVD Player
Televison & Video Logo
66 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
