Question about Sanyo Office Equipment & Supplies
Sanyo plc-wxl46 power light just blinks - Sanyo Office Equipment & Supplies
Marrie
  • 563 Answers
SOURCE: Sanyo Pro Xtrax PLC-XU50
Hi there
If you have the know how open up the machine and replace the fuse on the Powersupply board ( where the AC socket sits in )
If this still occurs , I'm afraid you will have to replace the Powersupply board.
Posted on Apr 10, 2008
SOURCE: Sanyo PLC-XF46N projector shuts down before powering up completely
The Fix Ya rep suggested that I try the "Reset" button located next to the Audio out on the side of the projector; this solution proved to be the fix I needed. I was able to get the lamps to warm up and get into the menu to cut back the bulbs/power consumption on start-up, allowing the projector to function for a problem-free 4 hour period Unfortunately, I had the same issue this morning, but the same fix worked again.
Posted on Jul 07, 2008
  • 3 Answers
SOURCE: Sanyo PLC-XU47 seems to power cycle
Welcome to resolve the problem if you please say what are the solution to me the same problem
Posted on Aug 23, 2008
robgarcom
SOURCE: Sanyo PLC-XU58 projector completly dead
I had the same problem and the technician diagnosed as being caused by a faulty Ballast which he said caused the bulb to fail. He didn't test the bulb but his experience indicates that even if the bulb was not blown it would have been stressed and it would only be a short time before it fails completely.
When these fail there is no real reason for it it seems but it has been suggested that a probable cause could be not cleaning the filter, at least every six months. The result of a dirty filter would be overheating and this could be the cause of the failure.
Posted on Oct 12, 2008
SOURCE: sanyo plc sw30 help
i had a sanyo plc sw30 wich had the same problem and it turned out to be the bulb replaced it with new one and this seemed to solve the problem. Theres a few places to get new ones but they are not cheap looking at between £150 to £180 hope this helps
Posted on Nov 02, 2008
Why does my Sanyo PLC-XU51 projector power light blink red?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
May 25, 2014 | Sanyo Office Equipment & Supplies
My Sanyo plc xu70 projector lamp is brand new after replacing it still has the same prolem.when I turn it on the power light gets green for seconds then red blinks then it stops..what do you think the...
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Jan 17, 2014 | Sanyo Projector Lamp for PLC-XU70
My Sanyo tv is not working. The power light comes on and then starts blinking red.
I myself had a 55 inch hdtv ready projection tv and the lamp went out in it. It cost me $104.00 plus shipping to replace it. Check out discount replacement parts but remember that if it is a projection tv, it won't last but approximately two years and you will have to do it again.
Aug 25, 2012 | Sanyo SELECT PLC-XP45 Rear Projection...
Red lettering problem offset from white letters
i am sorry your add said free ,,, i can't afford your help, to me free is free and not a charge or a plan, if it cost, i will put up with the problem , and not recomend your product, to others, but thanks anyway...
Jan 11, 2010 | Sanyo PLC XU35 Multimedia Projector
I hv sanyo plcxu48 , its power on led continously blinks in red ,projector not getting on at all, pls advise
if you count the number of blinks and time between them and repost I will try and sort out the problem, the blinking is normally indicative of a fault
Dec 17, 2009 | Sanyo PLC-WXU30 Projector
Power light blinking red
if the lamp goes out after the red led goes on, there is a fan issue and the projector is overheating or the ballast/power supply can't hold the voltage.
Aug 04, 2009 | Sanyo PLC-XU47 LCD Projector
Jun 07, 2008 | Sanyo PLC XU35 Multimedia Projector
64 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
