Question about Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television
Power cord was pulled out and looking to replace the cord
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Two types of power cords--ones that are soldered into a board inside the set and ones that plug onto a socket inside.
Almost any standard POLARIZED cord will work for the soldered in ones---Polarized cords at the plug have two lugs--one larger than the other---
The large pin goes to the neutral side of the electrical outlet--if replacing a soldered in cord you MUST get them the same.
The larger lug on the cord will have a white stripe on that side or a rough surface.
Neutral to neutral and hot to hot---the hot side in the set goes to the fuse.
This has been around for decades--it prevents the cord from being plugged in backwards (Polarity) and if installed backwards the set will work but you will have 120 volts potential voltage on all external metal fittings like the CABLE fitting---sparks will happen when you try to put the coax to the set and it will feed this back to all sets via the cable in your home.
Get it right the first time----a cord that plugs onto pins will have this also but the plug on the cord if original (Toshiba in this case) will not permit this reverse polarity because of the shape of the plug itself at the end of the cord.
Posted on Dec 08, 2012
  • jamie langridge Dec 08, 2012
    Thank you, this is very helpful
How do you replace the power cord on the Kenmore stove model # 79078589400, is it easy?
http://www.repairclinic.com/PartDetail/Power-Cord/3202006/684 here's a picture of your cord,it's for a gas stove,it has a quick disconnect on it,pull out the bottom draw,follow the cord into the stove i believe it's on the left side,unplug it from the stove by pulling apart the quick disconnect and plug in the new cord,it's not an electric stove so yes very easy.
Jan 10, 2012 | Kitchen Ranges
Looking to replace power cord on a hilti TE 6 S hammer drill
you can go to any repair shop and match the cord with a suitable replacement. There is a screw holding the back cover where the cord enters the tool. Hilti uses ferrules to crimp on the cord end for better contact if not you can solder them and after installation give them a slight pull to make sure tightened sufficiently.
Apr 10, 2011 | Hilti Drills
Tower won't turn on. There is a green light on the back near the power cord that's flashing green.
Pull the power cord out and allow it to reset. If you still have issues you may need to replace your power supply.
Aug 05, 2010 | HP Compaq Presario Media Center SR1750NX...
Self Propel Cord Replacement too loose!
measure it from the old cord thats the easiest way ?
Aug 26, 2009 | Toro Lawn Mower With Toro Power Tools
Replacment of starter pull cord
Remove the recoil cap cut the knot of the old cord off pull out the string. Cut a new cord the same length thread it in and knot it . rewind the spool until the cord in the spool. fish the cord out of the pull hole and tie on the pull handle
Aug 04, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Mar 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Pull cord
Yes. Most any hardware store can sell you a new cord. If you want to replace both the cord and the pull mechanism you may have to contact a dealer.
Jan 26, 2009 | Electrical Supplies
System turns on however hard drive will not cycle nor will mouse or key board activate
Turn power off and unplug power from computer.
Unplug printers,backup drives and speakers.
Open case and unplug power supply from the board.
plug power cord back in press the power button.
Of course nothing will happen.
unplug power cord again.
plug power supply back into the board.
plug power cord backup and press power switch.
If nothing happens unplug power cord again.
pull out your memory sticks and plug cord back in and press power button.
Of course not much will happen.
But really something is happening to your computer so continue.
Pull power cord and replace memory sticks.
replace power cord and press power switch.
Continue this pulling out pci cards one at a time until you find out what the problem might be.
Try different keyboards and mice too.
Good Luck
Oct 27, 2008 | Intel Computers & Internet
Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television Logo
65 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
