Question about HP PL4260N 42 in. Plasma HDTV
No sound when connecting dvd player with HDMI cable
    Top Expert:
  • HP Master
  • 14,553 Answers
HDMI is prone to audio issues---it does not for example like being connected at either end with the units powered up and or on.
Try disconnection of power to both units for a short time--do it with the HDMI disconnected. Then connect HDMI back at both ends and power the units on----it cannot hurt and it may help.
The other alternatives are the HDMI in the set is acting up or even bad---If the player has Component outputs try going that way to the set---I have never been able to see a difference in picture or sound quality from component to HDMI.
The only advantage it has is less cables in my view.
Posted on Dec 08, 2012
Trouble connecting my insignia 32in.Tv To my DVD player
Yes you can use Just the red,white and yellow cable from your dvd player to the tv....now make sure you have it connected correctly...sometimes its easy to confused the yellow and white connections. make sure your tv is turned to Input that you have used for connecting the cables on the back....such as...input 1...select input 1 on your tv....or if it says dvd...then select dvdv on yoru tv..You can use a HDMI cable...just plug HDMI from your dvd player to your tv and select HDMI on yoru tv..Good luck
Mar 08, 2015 | Insignia IS-LCDTV32 32 in. Television
Bypassing built-in TV/DVD Player for another DVD player
Connect another DVD player to an unused input port on the back of the tv. If there is a HDMI port available connect it there if the dvd player has HDMI. Then all you have to do is change the input number on the tv. If you get picture but no sound, use RCA audio cables from the player to the tv. Not all HDMI cables pass audio.
Jan 02, 2014 | Televison & Video
No sound on lg tv when connect dvd player through hdmi
I have the same problem. Good picture with no sound at all. I have a LG DVX583KH and LG TV LM7200. I connected the DVD player to TV via HDMI cable, I have a clear picture but no sound. I try to hook up the DVD to other TV and it works both sound and picture. Please help
Apr 13, 2013 | LG DVX583KH Player
Samsung ps wx30 surround sound system. speakers are plugged in to dvd player. dvd player is connected to tv via hdmi cable. speakers only work when using dvd player and not tv/sky etc.. am i missing some...
Hi,here is my simple solution...
To listen your TV on your
samsung ps wx30 surround sound system ,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out " of your TV unit
** to "AUX input " or "TV" OR "Any input" of your
dvd player or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
dvd player corresponding your RCA or Optic connection or HDMI ..
There you go..Your TV sound is on the
dvd player By this means whatever you watch on the
TV (
tuner, satellite , Xbox , etc..) ,it's sound will come thru your
dvd player.
Hope this helps!..if more he?p requires pls let me know..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Audio Players & Recorders
I can't get the sound to work from my tv to my dvd/vcr player. i have it plugged into the right spots on the tv & dvd/vcr player stil no sound
Tries another set of cable,some time the cable have bad shorted at the cable neck flexable and not working correctly are the causes.Ur DVD/VCR player have a HDMI hub connection,used a HDMI cable for connection will work better for a HDTV.
Jun 09, 2011 | Insignia 42" LCD Flat-Panel HDTV
No sound coming to the speakers.
What is the model number of your receiver?
Many receivers don't support audio over HDMI, they just switch the signal from hdmi-in 1-4 to hdmi-out, but can't analyze the data to take audio out of it. Your receiver is probably one of those.
You need to connect the DVD player also via spdif digital cable. Look at the player to see if it has optical (square black plug) or coax (orange RCA plug) connector. Receiver probably has both of them.
Feb 27, 2010 | Audio Players & Recorders
I have connected my Bush DS-A332B dvd player to my Sharp Aquos 32GD8E 32 inch flat screen TV with a Bush HDMI cable (26602BU) but can only get sound and no picture. The cable is slotted into Ext 5 yet when...
I have same problem sound but no picture, have tried it on 2 different tv's but no luck, have tried 2 different hdmi leads (both Bush 26602bu) but no luck. I even thought it was the port on my tv but it works fine with another dvd player and the same lead. I even returned the dvd player and exchanged it, still the same... It's driving me nuts...
Help please......
Sep 14, 2009 | Televison & Video
Audio doesnt come thru my hdmi cable from the dvd player. And video doesnt go thru hdmi cable to projector. Have to run rca cables to both
Hi there
Check your DVD players' settings/manual to ensure the HDMI port is the default output port. Also confirm that both audio and video are enabled on that HDMI channel as it can be separated to be only video or only audio in a lot of cases.
Confirm you are at least getting video out from the DVD with a direct connection to your projector with the HDMI cable.
If video is making it to the projector direct from the DVD, you will need to confirm your amp is monitoring the HDMI input if there isn't a specific input selection for it. Connect your DVD to the amp and your amp to the projector and test again that you are still getting video AT LEAST. This will help narrow down which device is not playing the HDMI game if you still have issues at this point.
To sum up;
Confirm HDMI is the default output from the DVD for both audio and video.
Ensure you are getting video AT LEAST with a direct test to projector.
Confirm your amp is monitoring the HDMI input coming from the DVD.
Hope this helps.
Jul 29, 2009 | Yamaha HTR-6130 Receiver
Right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Jan 07, 2009 | Audio Players & Recorders
Dvd installation
Why do you need to connect the rca cables when you get better sound through hdmi?
Feb 20, 2008 | Yamaha RX-V1800
HP PL4260N 42 in. Plasma HDTV Logo
Top HP Televison & Video Experts
Tony
Computer Links
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
