Question about Eureka Whirlwind Litespeed 5740 Bagless Upright Cyclonic Vacuum
Eureka whirlwind litespeed 5843 baygess upright acuum, when overheat the switch won't work, when cool off it starts working. but now it turn on and run few seconds and stop.
SOURCE: eureka whirlwinde litespeed vacuum - model 5841
very simple under all three screws in the front (two on sides and one in back) once open--you can take off that panel...take brush out...take old belt out...put new belt on..around brush..place both inside...and make sure belt is around that little pole thing towards the back close panel, replace screws
Posted on Jul 24, 2008
MNfisherman
  • 11896 Answers
SOURCE: My Eureka Lite speed whirlwind has a bad odor when it runs.
It is either the filter or on the roller or belt.
  1. Eureka Parts Storewww.Eurekapartstore.com Unbeatable prices on Eureka Parts Largest site for Eureka parts.
  2. Eureka Partswww.ThinkVacuums.com/Eureka Eureka Central Vacuum Accessories Find Hoses, Tools, Nozzles & More! Google Checkout
  3. Eureka Part Storewww.vacuums24x7.com/Eureka-Parts Bags, Belts, Filters, Repair Parts. Complete Selection Eureka Parts.
Posted on Jul 06, 2009
VacuumRepair
  • 438 Answers
SOURCE: what belt do I purchase for eureka whirlwind
If you have the exact model Eureka that this repair was listed under, model 4388 then please find a link to the belt you need below. If you'd like to verify the model number, please check the back or the bottom of the vacuum for a sticker that also will contain the serial number, and look for the word Model Number. If you don't have the 4388, please just add a comment with the model you have and I'll be more then happy to verify these two models take the same belt, or give you a link to the belt that goes to your model if they are different.
Here's a link to the exact belt called for on the model 4388:
Eureka Extended Life Style U Belt, Part 61120
Here's step by step instructions on how to replace the belt:
How To Replace Brush Roll Belt
NOTE: Turn off the switch and unplug the electrical cord
before replacing belt. Belt pulleys can become
hot during normal use. To prevent injury, avoid
touching the motor pulley when checking the belt.
1. Lower handle to floor to change belt.
2. Loosen, but do not remove, two screws to release hood.
Lift hood to remove.
3. Lift left end of brush roll.
4. Remove and discard belt.
5. Place new belt around motor pulley.
6. Place belt around brush roll pulley.
7. Align left end cap with square in base. Push
end cap into place; see left side view.
8. Pull right side of brush roll to stretch belt.
Secure right end cap into base.
9. Rotate brush roll to seat belt.
10. Replace the hood. Make sure hood front is
behind furniture guard. Hood should seat
onto self-locating screw tabs.
11. Tighten screws.
I hope this information was helpful to you in changing the belt. If you have any questions about how to change this belt, please just add a comment here on the repair page of Fixya, and I'll be happy to answer any follow up questions you might have. If you found this helpful, please be so kind and rate my repair helpful and / or leave feedback for me.
Thanks so much,
Chris Jones
GoVacuum.com
Posted on Apr 21, 2010
  • 357 Answers
SOURCE: the vacuum roller won't turn but the belt is fine
The belt may look fine but it's probably stretched out. Rubber belts are usually good for about 1 year. The tension of the belt is what allows it to turn under the strain of the carpet. Make sure the brushroll spins freely when held out of the machine. Eureka brushrolls are prone to melt down on the end caps. If that has happened you will need a new one.
Posted on May 01, 2010
SOURCE: Whirlwind 4388 Bagless Upright Cyclonic Vacuum: what belt do I need for a eureka whirlwind hepa va...
Is there a belt for the Eureka 4388 B-2 Model"
Posted on Jul 03, 2010
Belt
Un plug unit, turn unit over,remove screws on panel covering the belt. ,first start belt on large pulley and then start it on small pulley turn brush by hand to wind the belt on. Google the model number or go to Wal-M and look in their "bags and Belt" book located next to the Vacuum cleaners.
Apr 19, 2014 | Eureka Whirlwind LiteSpeed 5843 Upright...
Owners manual
Here's a link to the owners manual for your Eureka 5843 Vacuum:
http://www.eureka.com/service/manuals/71496B.pdf
Please be sure to rate a thumbs up if this was helpful! Thank you.
Oct 08, 2011 | Eureka Whirlwind LiteSpeed 5843 Upright...
Eureka Model Whirlwind litespeed. The rotart brush does not turn or rotate. Should it turn or rotate in order to give better suction?
Hello fnintel, yes, if you are using the upright vacuum it should spin, ( the belt likely slipped off, or the brush is clogged with hair and the likes.)
However, if you are using the hose on the vacuum like a shop vac, some models bypass the rotary brush.
Jan 09, 2011 | Eureka Whirlwind Litespeed 5840 Bagless...
The bristles aren't rotating. Is there an easy solution to this?
The belt probably broke. Simply purchase another belt and replace. These belts are made for much stress, and if you've had the vacuum for even a month, they can easily break.
It may also have slipped off the motor shaft, causing the brush to spin freely.
Aug 22, 2010 | Eureka Whirlwind LiteSpeed 5843 Upright...
How do I replace the belt on my mom's Eureka Whirlwind litespeed 12 amp 15" ?
take the cover off from the bottom there should be clips or screws on the bottom.and work the old belt off and new one on
Aug 12, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
The vacuum roller won't turn but the belt is fine Eureka Whirlwind Litespeed
May 01, 2010 | Eureka Whirlwind Litespeed 5840 Bagless...
Jul 06, 2009 | Eureka WhirlWind Litespeed 5844 Upright...
My Eureka Whirlwind vacuum on-off switch won't turn off
the power switch is bad. go to your local hardware store and buy a new power switch and replace it.
Mar 23, 2009 | Eureka Whirlwind Litespeed 5740 Bagless...
Eureka Whirlwind Litespeed 5740 Bagless Upright Cyclonic Vacuum Logo
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
