Question about Sceptre Televison & Video
I have a sceptre flat screen i bought 2 years ago (40") the sound just quit can hook up external speakers?
Sound quit working can i hook up external speakers?
    Master:
  • Sceptre Master
  • 996 Answers
If the only speakers are defective in ur tv then may be use home theatre audio input pin to audio out pin of your tv to listen the sound
Posted on Jan 11, 2015
    Top Expert:
  • Sceptre Master
  • 14,553 Answers
Read the owner manual or check all the inputs on the rear to see if it has those connections---it is also possible a surround system routed from a box (cable or sat) might work to bypass this issue.
and do not forget to check in the set menu that the speakers did not somehow get switched to OFF.
Posted on Dec 08, 2012
5 Suggested Answers
SOURCE: Samsung 40" flat screen looses sound
this problem started on my LN-S4051D a couple of years ago. eventually the sound stopped working altogether. I then started using my surround sound speakers for the TV via optical out but soon that stopped working as well. I recently took the TV to a repair shop who said that the main board is bad and needs to be replaced. Labor plus parts was going to cost me $400. I said no thanks and paid for the estimate. Good luck.
Posted on Jul 07, 2010
  • 5 Answers
SOURCE: LG tv sound quit - will it work if I add external speaker system
Maybe!! It depends on where the audio sys failed. If it failed at the output drive, then you can take the audio off at the audio output jack and input it to your stereo system where there is an audio input. You'll need a cable with RCA jacks on it for this.
If your system is muted for some reason, this may not work.
Posted on Jun 18, 2010
  • 39 Answers
SOURCE: getting stereo speakers to work with flat panel tv
if you hook the low-level audio-out from the tv to an input to the stereo unit, whatever you play on tv will send audio to surround/stereo reciever unit. look on back of tv for red &white AUDIO OUTPUT terminals. plug red/white audio cables from tv to the back of your stereo & plug into audio input of an open source on stereo (tv/video,aux. in,etc.) good luck!
Posted on Mar 09, 2009
  • 181 Answers
SOURCE: We were watching tv and sound was fine then just
dry soldering main board
Posted on Aug 19, 2011
I have video but zero audio at all
you must verify first where the problem came from.check in the sound set up menu if set to off, if ok at this time you can use a powered pc speaker to isolate the cause. hooked up the powered pc speaker to the audio output jack of the tv, if you can get sound there the cause will be bad amplifier circuit.if you can not get sound there then the problem is bad sound processor at the board.
Sep 22, 2012 | Sceptre X405BV-FHD3 40 in. LCD HDTV
Aoc 32" lcd television sound quit
It could be a sound problem inside the set but first check the others:
Make sure in menu speakers are not by accident turned OFF>
Make sure volume is not turned down or muted on set OR A BOX IF ONE IS USED FOR SIGNAL TO THE SET.
Make sure in audio menu if it has a setting for Internal/external speakers it is set to internal.
Lastly hook a DVD etc. to a rear input to see if sound works that way--if it does something in set or a box is set wrong.
SD TECH
Apr 22, 2012 | ViewSonic Televison & Video
Tv is on with no picture or sound, only 4 months old!!
Hello
The power supply regulator board to your set has the fault. If you try to open the set, or try to repair it by yourself, the warranty will void. The set must have warranty as it is new. Why do you spend for it? Just contact the nearest authorised service center for Sceptre. the components in this set will be very hard to get from open electronic spare part market, and will costly too.
Mar 11, 2012 | Sceptre 32 X320BVHD 32 LCD TV
How to connect external speakers
Hello....I took a close look at your tv and. it doesn't seem to have an output for external speakers BUT...it does have line level outputs so it easily connected to amplified speaker systems or home theatre systems..If you want to expand your system...I would suggest a 5.1 channel surround sound system.....They are priced quite reasonably and will maximize your tv experience.....I hope this was helpful....PEACE...
Feb 08, 2012 | Sceptre X400BV-FHD 40 in. LCD TV
Why does the speakers reverberate sometimes?
Because the speakers are small and get too much power to them. That is the reason why people buy external sound theater systems to overcome most types of sound issues.
Jan 01, 2012 | Sceptre X400BV-FHD 40 in. LCD TV
I have a standard old Dell desktop, I hooked up a set of Creative T7700 speakers, they worked wonderful for about twenty minutes and the quit all together. I re-hooked the single line back to the flat...
By the single line I assume you mean the green line out cable and you have connected this to the sound connector on the monitor, so that you have the Dell computer using the monitor speakers?
The problem may be down to the sound chip on the Dell conflicting with Creative labs speakers, it may not support the 7:1 sound. You can try updating the Dell sound drivers, however Given the problem, I'd invest in a pci soundcard and hook the speakers up to that, or look at an external soundcard
Jul 28, 2011 | Computers & Internet
Jun 27, 2010 | Samsung LN-S4051D 40 in. LCD Television
LG 720p 50" Plasma NO SIGNAL when components hooked up correctly
Ur backlight inverter board is dead.
U need a new one.
Sep 07, 2009 | LG 42LC2D 42 in. LCD HDTV
I have a Sceptre X7G Komodo II 17" LCD monitor/built-in speakers
You would need to connect the speakers to your computer. There should be a little jack on the back of the monitor marked audio. This will need to be connected to your soundcard jack for front speakers. Once this cable is connected you should have sound from your speakers. Hope this helps.
Aug 15, 2009 | Sceptre X7G Komodo II 17 in. Flat Panel...
Dell 32 inch LCD Tv volume and menue problems
We also have a 32" LCD Dell flat screen tv #W3201C that has no sound. It's about 2/12 yrs old. One speaker started having a problem and we disconnected it. That was a couple weeks ago, now there is no sound at all. Dell should not be let off the hook so easily. Obviously there is a problem with the tv and it should be Dell's responsibility to make it right. Does anyone know if a class action suit has been initiated?
Mar 08, 2008 | Dell W3201C 32 in. LCD Television
Televison & Video Logo
191 people viewed this question
Top Sceptre Televison & Video Experts
Henry  Thomas
Henry Thomas
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
