Question about Sanyo PLC-XT10A
Sanyo PLC-XT10A shuts off after 30 seconds
When it is sitting on it's feet it starts and runs fine. When it is hanging from a ceiling mount it starts and runs for 30 seconds and then shuts down - no overheat lights or messages, it just shuts down. The bulb has less than 100 hours and the filters are clean. The really odd part is that if I start it upright and then flip it over it will continue to run. Suggestions?
    Champion:
  • Sanyo Expert
  • 225 Answers
That is really odd maybe when its upside down something is barely coming loose or a fan is getting blocked?
Posted on Dec 08, 2012
SOURCE: Sanyo PLC-XT16
The problem is faulty capacitor on one of the control pcb's . needs to go to a technician for repair
Posted on Jul 04, 2008
charleshucke
  • 1114 Answers
SOURCE: Hello, When I mount the projector upside down
I have been a trainer for several years, and have never seen a projector that was mounted upside down. Try mounting it right side up using some brackets. That should resolve the issue you are experiencing.
Posted on Mar 02, 2011
Marrie
  • 563 Answers
SOURCE: Ghosting image
Hi there
I'll bet you any money that the problem is cable related.
We often get this problem and by swopping the cables we normally get the problem solved.
Hope this is of help
Posted on Mar 27, 2008
  • 3 Answers
SOURCE: Sanyo PLC - Z5 Lamp Replacement Light
Just had the same problem. Based on other suggestions on here I tried resetting the overheat switch, and IT WORKED!
So, you have to pull the 6 screws (one of them is shorter than the rest, remember where it goes) that hold the top on the projector. 3 are on the back, 3 on the bottom - look for the arrows next to the screws.
Put the projector on it's feet, and pull off the top. The button wires will still be connected, so just hold onto the top and find the black circle/shaft above where the lamp is. The shaft has white paint on the top/tip of it. Push it down with a light amount of force. You should hear/feel it click.
Put top back on, put screws in, and you should be good to go.
Don't forget to reset the lamp replacement counter in the menus.
Posted on Aug 01, 2008
SOURCE: Sanyo PLC SW20AR - Shuts itself down
check the follwoing :
check lamp physically for melted filament, white deposits on filament/ reflector, if so change lamp
if lamp looks perfect, the ballast needs to be replaced, also check for fans if they are running fine
Posted on Feb 08, 2009
Dell 5100mp projector fan is quiet when doing presentations on table top, but makes noise when ceiling mounted for home theatre. Noise get better after 20-30 minutes, but is just as noisy next time i...
turn it on when sitting on a table right side up. If possible, take the cover off and support carefully nearby the unit. Then slowly rotate the unit upside down and notice when the noise starts to get worse. Have a look at the fan area and see if there is anything that's causing the fan to make a worse noise. perhaps the bearings are getting worn out or something's not as titgh and vibration is being amplified by the fan unit.
Jun 07, 2011 | Dell 5100MP Multimedia Projector
Sanyo plc-xt10a will not power up. ready light is not on. power to unit is good.
First, check the lamp/lamp door--the door has a safety interlock that prevents power from getting to the projector. Make sure the power *is* getting to the unit by using a known-good power cord. Also, check the 3 air filters. If one or more was clogged with dust, the unit might have had a thermal sensor trip. There is also an internal fuse on the power supply which may have blown.When was the last time the projector worked correctly? Have there ever been any power problems related to that unit before? If the above checks yield no success, the projector will have to be repaired at a service facility. Hope I was of some help---Rick
Sep 09, 2009 | Sanyo (6103055602) Projector Lamp for...
Eiki EIP-25 shuts down after 30 sec (ceiling mounted)
there must be something loose inside. maybe the button panel.
Mar 07, 2009 | Eiki LC-X50M Projector
Feb 08, 2009 | Sanyo PLC SW20A Multimedia Projector
Sanyo PLC-SW30
The filters are starting to show their age. This is a normal occurance for projectors and is the result of heat. The filters and/or the mirrors might need to be changed.
Dan
May 08, 2008 | Sanyo PLC-SW30 Multimedia Projector
Ghosting image
Hi there
Mar 26, 2008 | Sanyo PLC XU30 Multimedia Projector
MULTIMEDIA PROJECTOR
have you ever seen the lamp come on? has the unit been used for a prolonged period with lamp on?
May 24, 2007 | Sanyo PLC XU35 Multimedia Projector
Projector randomly shuts off
hi CLEAN IT!! all these things leads to 1 conclusion: the device is packed with tons of dust it has a safty powerdown on heatup http://www.fixya.com/user-guide/p196016,m4858,gm38/Sanyo-PLC-XP41-Multimedia-Projector.aspx good luck
Apr 06, 2006 | Sanyo PLC XP41 Multimedia Projector
Sanyo PLC-XT10A Logo
485 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
