Question about Dishwashers
Nothing is turning on it worked last time i used it
  • 23 Answers
My guess if you already made sure it was plugged in and the outlet is good, I would say the door switch is bad. You can check it with the power supply disconnect by using an ohm meter it should give resistance and say ol when open and closed. The service manual is normally behind the door panel if you remove it.
Posted on Sep 04, 2014
Radio static issues
Antenna Problem
Gounding Issues almost anywhere
Alternator Diodes Bad
Those problems are usually the result of the
last person to work on it
Mar 07, 2013 | 2008 Chevrolet Hhr
Went to try on the dryer and nothing! worked fine the last time I used it last week. what could be wrong?
main thermal fuse in the rear of the machine, if this tests good,, check the safety switch on the door itself you can hold it in and turn the machine on,, if it works,, replace the plunger shaft that turns it on
Aug 02, 2010 | Hotpoint NBXR463EBWW Electric Dryer
Mitsubishi WD-52525 was working fine and now it will not turn on
This is just a shot - but it worked with my Sony (same problem).
Pressed remote power on button AND held Power button on TV on at the same time.
Set clicked 4 or 5 times and then came on....
Other, most have a (VERY small) reset switch on the rear - near where the power cord enters the TV... Use a flashlight and a mirror to locate it on your set....
Nov 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
When turned over there is no fire
By nothing on the top end is working do you mean that the distributor is not turning (or turns but "stutters") This and unusually fast engine cranking usually indicate a failed chain (actually when you remove it the chain will be intact but the cam gear will be destroyed) Chain is stretched don't use it.
Apr 14, 2009 | 1997 Ford Crown Victoria
My laptop wont turn on
Does the battery charge? Or does nothing happen at all? If nothing at all happens then it is your motherboard and you need to replace the board
Feb 06, 2009 | Gateway (4000474) Motherboard
Total power failure
same here! first my original car charger stopped working, so i purchased a replacement (a generic one off ebay), plugged it in and the little light on the top right turns on. but i have not been able to turn it on. i've left it charging for at least a half hour and nothing. any ideas?
Nov 24, 2007 | Magellan RoadMate 3000T GPS Receiver
Selection and Start/pause bottons wont work
we had the same problem and use a hair dryer to blow hot air over the panel from say 300mm away - this seemed to work. We did a couple of time and has gone well since
Jan 15, 2007 | Haier XQJ50-31 Top Load Washer
Dishwashers Logo
98 people viewed this question
Top Dishwashers Experts
Owen Barnes
