Question about Cell Phones
I have a humax ir1020 its showing me an Error ( E04-4 please insert smartcard) eventhough smart card is inserted and working, i tried to switch off and on/ restore settings but it's still the same, please i need some advice to solve this issue
3 Suggested Answers
  • 5 Answers
SOURCE: my lg vu says insert smart card
I've dealt with this issue ever since I bought this phone - and would rather throw it across the room and watch it burst into 1,000 pieces than have to see the error pop up again. All I did was cut out about 1-inch by1/4" inch strip from a postcard - or any heavy weight paper. In other words, not cardboard, but not copy paper. More like the weight of a vhs cover box, cereal box, etc. I inserted one end of the strip above the sim card and below the phone shell (over the part of the sim card that's not showing); and folded the rest of the paper strip (might have to tear some off) to be double ply above the part of the sim card that is showing. Put on the cover; you should have to press firmly to get it to fit on and smash the double-ply strip down. Make sure the double ply is only over the sim card, not any over the battery. This worked for me!
Posted on Apr 01, 2010
SOURCE: k800i insert sim issue.
i have been using my k800i 8months now.it is showed on my screen insert sim card
Posted on Oct 30, 2010
I am getting insert Sim card error on Nokia 6030 eventhough i have inserted the SIM Card
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Jan 24, 2013 | Nokia 6030 Cellular Phone
Says to insert smart card on my hp laptop
Your laptop is locked and will not boot without the correct smart card. It has a smartcard reader on the left side of the laptop. If there's a card in the slot, make sure it's correcly inserted.
Nov 04, 2010 | HP Compaq nc6220 Notebook
Does anyone have the codes for eurovox 5a01 please
WATS THE CODES FOR TELEPESR 6TH MAY
TELLS ME TO INSERT SMART CARD
ANY HELP WUD BE APPRECIATED
Feb 03, 2010 | StarTech.com StarView SV211K 2-port KVM...
Dish Network - Loss of signal after smart card upgrade.
Hi I will be more than glad to assist you in this concern.. Since you did already all the troubleshooting to fix the problem and according to the customer service, just run the check switch and test, that should fix the problem, but it didnt. The blue card that your refering is the g3 smartcard, it started when u insert to the 301 receiver.. It could be a bad smartcard or the receiver is bad, If you have another solo receiver in the house, just to isolate the problem, try to hook up the other solo receiver in the room where the 301 receiver is hook, run a check switch and test to the other solo receiver, once its done check your sat and signal, once its ok, cancel all the way out and it should acquire the sat signal..it will show attention 015 and let it finish the progress until it download the programming guide.. once u got a picture and the problem still exist with a different receiver. the problem is with the receiver and the receiver needs to be replace, if you call on dish network tech support, tell them that you try using another receiver and install to the room were the 301 is located, so that they wont do a troubleshooting again.. that is.. if you have another receiver to test and isolate the problem, but if not request for a service call so that they will send tech to your house.. please feel free to get in touch.
Sep 04, 2009 | DISH Network 322 DTV Receiver
Dish Network "Blue" Smart Card upgrade... Now get only "015"
The solution is usually a simple one and that has been suggested already but I will ask you to try one thing first. Remove the new smartcard and do not put one in. If the receiver still displays a picture and yoou can get to menu 611 run a check switch. After this is performed cancel out of the screens and re insert the new smartcard. Once the system comes back up perform the same steps as you did before with the smart card removed. If this fails you can try the solution they offered which was to update the sofware. There is no reason your software should be outdated if you were using this receiver before the new smartcard but try anyway as it may SOMEHOW work. Using the remote turn the receiver itself off. Allow the receiver sometime to turn itself back on-this could take awhile so plan this when you leave for work or are going to be gone from the house for sometime so you do not get bored waiting for this to occur. If the receiver has not turned back on in 45 minutes or more then the receiver will either need replacing -which i suggest- or they will try to send you a new smartcard if you talk to Cust service. Tell them you want a service call to fix the receiver. While you have them on the phone verify your receiver number and the new smartcard number which is on the back of the card and ask them to send a hit to the receiver. If the receiver has not been associated with the new smartcard or if the smartcard was not loaded with all of your programmming this should fix the issue. Thanks for using Fix Ya.
Feb 22, 2009 | DISH Network 322 DTV Receiver
Dell Smartcard Keyboard error
i have the lost smart card's driver plz send me in mail...
bakhat25@hotmail.com
Oct 24, 2008 | Dell Smartcard USB Keyboard SK-3106
PlatinumPAS ? preboot authentication services verify please insert a valid smartcard
Under the keyboard have a switch. Set the key number 3 in "ON". that's all folks.....
Feb 27, 2008 | Acer TravelMate 613TXV Notebook
Transferring pictures
You might try putting the pix on a rewritable cd, and then copying them from that drive onto the smartcard drive with your card inserted. Or just try copying directly from your computer file to the smartcard drive with your card inserted, essentially using the computer's hardware to do the job instead of the camera's software.
Nov 03, 2007 | Cameras
Cell Phones Logo
116 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
