Question about HP Photosmart Pro B9180 InkJet Printer
Hp photosmart pro B9180 does not sense paper
My printer loads 2.5 sheets of 8.5x11 before telling me there is no paper in the tray. its almost like its not senseing the paper. sometimes it will grab multiple sheets but it always shuts down after 2.5 sheets.
this problem come up no matter what tray i use.
  • 2 more comments
  • mheideman Jan 12, 2009
    Thanks for your help! where is the sensor and what does the sensor look like.
    thanks again!
  • gabeck Jan 28, 2009
    The same thing is happening to my printer!!!  Did cleaning the rollers help?
  • Anonymous Feb 10, 2009
  • Anonymous Feb 24, 2009
    Same thing - and just out of warranty!
    President:
  • HP Master
  • 990 Answers
Hello sir; You need to clean paper pick up roller, and rubber pad(right underneath the roller) as well as paper sensor.
Posted on Jan 12, 2009
  • Anne Strose Apr 25, 2012
    How do you clean it? I'm having the same problem. Is there also a paper sensor on the printheads?
Whenever a print job is sent to my dell 3100cn laser printer, ?Load tray 1? appears in the small window of the printer. I loaded the tray several times but it doesn?t work. Please guide me through the...
You sent a paper size different of the requested by the printer. Just load the requested size or delete the spool.
Some PDF downloaded from internet has A4 or 8,5x11", maybe is requesting one of this sizes.
If you can not delete this message, delete the spool using the printer manual in the control panel of the printer.
Dec 11, 2010 | Dell 3100cn Laser Printer
How do I realign my hp photosmart c4480 printer?
To align the print cartridges from the HP Photosmart Software
1. Load letter or A4 unused plain white paper into the input tray.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
2. In the HP Solution Center, click Settings.
3. In the Print Settings area, click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Features tab, and then click
Printer Services.
box. In the Print Properties dialog box, click the Features tab, and then click the
Printer Services button.
The Printer Toolbox appears.
4. Click the Device Services tab.
5. Click Align the Print Cartridges.
When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
press the button next to OK.
The product prints a print cartridge alignment sheet.
7. Load the page print side down on the right front corner of the glass, and then press
the button next to OK to scan the page.
When the On button stops flashing, the alignment is complete and the page can be
removed. Recycle or discard the page.
Jul 18, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Load paper
To resolve this issue pick one blank sheet and insert it in the tray and try to print self test page. If the printer prints self test page then load the paper properly and try to print. If self test page won't print then check the paper settings.
May 22, 2009 | HP Photosmart 3210 All-In-One InkJet...
Won't print
Hi, try upgrading your firmware to version 27A.
Look there to learn how : http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01326792&lc=en&dlc=en&cc=ca
Apr 06, 2009 | HP Photosmart Pro B9180 InkJet Printer
HP PHOTOSMART 6180
Tips for Avoiding paper jams
  • Do not use extremely smooth, shiny, or coated papers unless they are specifically designed for HP Photosmart printers.
  • Do not use multi-part forms (such as duplicate or triplicate forms).
  • Do not use torn, dusty, damp, wrinkled, or curled paper.
  • Do not use paper with bent edges or paper that will not lie flat.
  • Make sure that the OUT tray is installed correctly.
  • Make sure that the paper adjusters are not pushed up so tightly against the paper that it is bending in the paper tray. The paper-width adjuster should be placed against the left side of the paper. The paper-length adjuster should be placed against the end of the stack of paper.
  • Do not put more than 100 sheets of 75 g/m2 paper (or a 1/2-inch stack) in the paper tray.
  • Do not keep more than 50 sheets in the OUT tray.
  • Do not use paper longer than 356 mm (14 inches).
  • Do not mix paper types in the paper tray.
Source:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpy20231&lc=en&cc=us&dlc=&product=60363
Sep 28, 2008 | HP PhotoSmart C4180 All-in-One Color...
Loading A5 paper into photosmart 8450
your printer is capable of accepting a5, load the paper on a different direction, with the leading edge 5.83" feed first, then properly aligned the side guides to match your paper this will surely work this time, then slect a5 on your printing properties on your pc
cheers
Sep 27, 2008 | HP Photosmart 8450 InkJet Printer
HP Photosmart Pro B9180 InkJet Printer Logo
428 people viewed this question
Seeker5211
Seeker5211
