LC320EM2 TV KEEPS BLOWING FUSES WHEN TRUHED ON
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
If it blows when turned on a short usually on the secondary side of the power supply---its the part or area where the voltages that are developed are distributed to the rest of the set.
One other odd thing can happen---say a 5 amp fuse is blowing, you go out and buy a generic fuse of same value--at like Radio Shack etc.
Many of the fuses used in modern gear will blow instantly if not the original type and made for that unit.
I had one customer who had a 4 amp blow every time he turned it on--generic fuse-----The correct fuse of same amperage did not do that.
Don't keep feeding it fuses as if a short sooner or later parts that are not now bad will get destroyed and make matters much worse.
Posted on Dec 08, 2012
Won't turn ON. Found F601 fuse blown on power supply/inverter board. What's the most likely culprit?
Emerson BA17F1F0102 Power Supply Repair Kit LC320EM2
www.shopjimmy.com/emerson-a17f1mpw-power-supply-co...
ShopJimmy
$19.94 - ‎In stock
This Emerson BA17F1F0102 Power Supply Repair Kit LC320EM2 ... board. If the TVhas no power it is most likely because of a blown fuse and failure of other preceding components. ... I tested F601, Q600, R602, 608 and 611, and found them to be bad. ...Power Supply / Inverter Board - Joseph A. on March 4th, 2015.
Common TV Repair for Emerson, Sylvania, Philips ...
? 5:35
https://www.youtube.com/watch?v=nQHWrJJg4Mc
Oct 11, 2013 - Uploaded by Tampatec
... LCD TV repairs for Emerson, Sylvania, Philips, Magnavox,blowing fuses "no power" i recommend a TV service LCD repair kit at ... powersupply power-supply "power supply" powerboard "power board" part2 part 2 pt2 ...
What Causes a Blown Fuse in TV Sylvania LCD - YouTube
? 15:31
https://www.youtube.com/watch?v=4P_0aLDZgBY
Jan 01, 2016 | Televison & Video
Why does it keep blowing fuses?
Hi Deborah,
Fuse is a protective device. When ever there is some short further in the circuit, there is an excess flow of current and fuse not being able to handle it blows off and thus restricts any further damage to the supply unit. Please check the components like rectifier, dc reservoir, power regulator etc in the power supply to find the cause of fuse blowing.
Aug 07, 2015 | Emerson LC320EM2 32" LCD HD Television
Toshiba 32c100u keeps blowing fuse and my tv wont come on
If fuses keep blowing, the power supply may have shorted.
Jun 23, 2014 | Toshiba 32C100U 32 in. TV
Remote control code list for EMERSON LCD TV MODEL #LC320EM2
Emerson LC320EM2.Code: LC"320"EM2 (0320) works for my Sony BR PS3 remote.
Apr 03, 2012 | Televison & Video
My tv keeps blowing a fuse when I turn on set.
DO NOT keep feeding it fuses more damage can accur-check rectifiers in power supply-then check regulator-chech H.O.transistor.if you need more help im gonna need a model number to go furthor
Sep 04, 2009 | Televison & Video
It keeps blowing fuses - two 12 inch cls subs 1
sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
Jul 16, 2009 | Cerwin Vega CLSC-12S Subwoofer
My ILO brand tube tv keeps blowing fuses, what could be the problem?
If you tv is blowing fuses it might mean you have a short in it. The fuses are a safety feature. Best thing to do is bring it to a repair shop. I do not suggest for anyone to open a tv without the repair knowledge.
Feb 18, 2009 | iLO IWT3206 TV
My sd-533hd5 keeps blowing the 5 amp 125v fuses
Yes! it sounds like a power supply problem! or the flyback in the main board needs replaced ( part is in the $70.00 range
Dec 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
means you have a part that is dead shorted after the line fuse, usually a bridge diode, regulator IC or possibly the Horizontal output transistor. Not really something a non tech will be able to find, a volt Ohm meter is required as well as soldering equipment.
Nov 27, 2007 | Panasonic CT-36G34 36" TV
Proscan PS32610
Tv keeps blowing fuses it is due to short ckt in your tv in 1 power supply. 2 horl output section it is mainly due to 1 switching transistr 2 main fil cap 3 rectifier diodes 4 print short 5 h/output tra. 6 eht transformer
Sep 25, 2007 | Proscan PS36810 TV
Televison & Video Logo
336 people viewed this question
Top Televison & Video Experts
