Question about Coby Kyros 716829701508 Tablet PC
No power tablet will not charge, have tried on several different outlets, any way to tell if it a charger or tablet problem?
  • minid harris
    minid harris Dec 20, 2013
    i tried all outlets and none of them work i even tried charging it in the car
  • melitza
    melitza Apr 06, 2014
    me to wont work
I had the same problem! It's not your charger, it's the tablet.
Most likely, the soddering came apart on the inside of the tablet, on the part that connects the charging port with some important wires. You can either take the cover off and fix it, but if it's like mine, it'll just come apart again.
This is what i did: plug in the tablet, and cross the cord from the right across the screen, to the left, and make sure it's tight. I use a binder clip to make sure it stays and charges.
Now try powering it up....that should work :)
Posted on Dec 13, 2012
  • minid harris
    i will try this but i hope it works
The charger no longer charging the tablet all the home outlets have been checked, & working with my other tablet. What could be the issue I received this as Mothers day gift
the charging circuit does not charge or the batteries need replacement ....IT is probably the batter. Try new batteries, if they work the problem lies elsewhere
Also, try a different charger, and the tablets charger on something else...if the tablet's carger charges other batteries that can be discounted as the problem.
May 26, 2015 | Nextbook Premium 8 Se Android
My tablet want come on what's wrong with it
I've had the same problem with my RCA 10 inch tablet. I have charged it, tried the hard reset, used different chargers and even different outlets, and held the power button on for 60+ seconds with NO RESULTS! My recommendation is to contact RCA, which is what I am doing, and request an immediate replacement if yours is still under the 1 year manufacturers warranty. If you look these tablets up, you will see (as I have found) that this is apparently a common problem with the tablets. Wish I had known that prior to purchasing!
Jan 01, 2015 | Tablets & eReaders
Tablet doesn't turn on, it shows a battery with an triangle and this symbol!
When you have the charger plugged into the tablet and wall outlet does the triangle change to a lighting bolt if it doesn't change try a different changer either the charger or charging port or charging cable might be bad
Dec 31, 2014 | Tablets & eReaders
How do I fix my Toshiba tablet that won't show me that it is charging?
Have you checked the following:
  1. Power cord for breaks
  2. The power outlet you are connecting into (try at least 2 other outlets before settling, but use different outlets for the sake of argument.
  3. When was the last time you charged and it actually did?
  4. Do you have the correct cord?
  5. Have you tried to replace the cord?
Nov 22, 2014 | Toshiba Tablets & eReaders
What do I do if my android tablet stops charging
If you have tried different chargers and still can't get it to charge, then it sounds like the charger port may have physical damage. You can also do a hard reset by holding in the power button for thirty seconds then turning it on agin . Try several times. Also inspect the charging port for lint or dammage.
Oct 14, 2014 | Tablets & eReaders
My coby kyros wont charge
Try plugging in your charger to a different outlet. If that doesn't do anything, there might be a problem with your charger or your USB port on the Tablet. May have to replace the charger.
Mar 07, 2011 | Coby Kyros 716829701508 Tablet PC
Coby Kyros 716829701508 Tablet PC Logo
1,074 people viewed this question
Top Coby Tablets & eReaders Experts
Fred Block
Fred Block
Martin Murray
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
