Question about IEI Home Security
How do you program a key fob for an iei security system
Have bid key bobs and want to program them for iei system
raygin
  • 322 Answers
SOURCE: How do I program S Type Jaguar key fob Year 2000 Jag ?
Seperate key fobs only can be programmed in the following way.
Turn ignition on/off 8 x times (allow all functions to stabilise) after the 9th on - press a button on both remote fobs. then turn ign. off. use good remote to lock and then try new remote to unlock/lock. sometimes it works first time - sometimes you have to repeat actions. good luck.
Posted on Apr 07, 2009
baccardo
  • 150 Answers
SOURCE: Programming a key fob
you will need the dealership diagnostic tool to program the remote
Posted on Apr 24, 2009
rogrrabbit
  • 986 Answers
SOURCE: how to program key fob. I have the fobs.
Transmitter Programming Procedure
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on the transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of the transmitter.
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode.
Operate the transmitter functions in order to verify correct system operation.
Good luck
Posted on Jun 25, 2009
szanti
  • 36 Answers
SOURCE: require a manual for a home security/alarm system
go to this web site ITI is now GE
http://www.gesecurity.com/portal/site/GESecurity/menuitem.45121a7b14f68165b1e2ff10140041ca/?vgnextoid=343a148067b33010VgnVCM100000410014acRCRD
Posted on Nov 29, 2009
ZJLimited
  • 17970 Answers
SOURCE: 1999 Porsche Boxster : key
Not necessarily de-programed the keyfobs; if the car battery is uncharged, it possible that the security module sensed as an "disconected battery" condition and activated the antitheft system. Check in your owners manual disarm procedure.
The key fobs do get stuck in the on position, especially if you leave them in your pockets all day long. The buttons get stuck in the down/pressed position causing the battery to wear down and eventually the remote itself needs to be re-programed.
Also, could check the battery in the keyfob, its possible that they need replace it and re-programming. Check this ways:
1.- If the key had gone faulty, the key code must be re programmed on the vehicle computer. This can be done only using a PIWIS tool, available at the dealer or at a qualified Porche garage.
Try also the following reset:
* turn ignition on,
* turn off.
* remove the transponder from the column
* push any button on the fob within 6 seconds.
This procedure will reset the key synchronizing again with the vehicle computer.
2.- If you put the battery upside down you risk to short the key remote and break it. When the key fob is falshing slower it means that is not synchrronised with the car.
Try also the procedure below:
* Unlock your car using the key
* Open car door ( if alarm goes off, put key in the ignition to stop the alarm).
* Press unlock button on remote and the remote will resynchronize with the car.
If it does not work, then you have either two faulty remotes, if you are not, you have a faulty control module or a problem with ECU.
Hope helps. Keep us updated.
Posted on Dec 29, 2010
2007 Harley Davidson FLHX Street Glide key fob not working
Hi, Leonardo starting in 1996 Harley made available an optional security system with a Button Key Fob that had to be depressed to arm and disarm the system. In 2007 the smart security system was introduced in European countries with a buttonless proximity sensor Fob that only works within a 10-foot radius depending on battery strength and sensor receiver location. In 2012 Smart Security Systems became standard equipment on some models. In 2015 it was standard on all models. The following is a list of security system FOB failure:
BUTTON FOB'S
1. The FOB battery is weak or dead.
2. A new battery was installed upside down.
3. The FOB is no longer recognized by the security system and needs to be reprogrammed by the dealer.
PROXIMITY SENSOR FOB'S
1. Fob is more than 10 feet away from the bike.
2. The FOB battery is weak or dead.
3. A new FOB battery was installed upside down.
3. The security receiver antenna is broken.
4. The FOB is no longer recognized by the security system and needs to be reprogrammed by the dealer.
There is an option to override the security system by inserting a pre-programmed pin number. This is a 5 digit number that comes from the factory as 1-2-3-4-5. If you read your owners manual it "HIGHLY" recommends that you change this number to a personal one. You can do this yourself but it is complicated and tricky sometimes it works sometimes it doesn't. I have a 2003 FLHTCUI that the procedure did not work and had to go to my local dealership to have the system reprogramed to my own personal number. They wanted $50 for this 2-minute service but after explaining that I was a 40 year retired Harley wrench and waving a $20 bill to the service writer got me through. Money talks but not all the time.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Security System 2007 Street Glide Harley Davidson Forums
Find your Harley Davidson securty PIN code number
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
2008 Harley Davidson Touring Models Service Manual pdf
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/007-harley-davidson-owners-manuals
Instant Tech Relief To speak to me personally for only a mere $6
Apr 24, 2018 | 2007 Harley Davidson FLHX Street Glide
How do I replace the ignition switch?
if the car requires a fob key then you will need a fob key to operate the immobilizer
Nov 02, 2015 | 1998 Acura RL
Alarm wont stop sounding!
although you can open the door with a key ,unless the alarm system senses a fob key signal it will assume that the door is being opened illegally and will set of the alarm
keys can be cut for all cars requiring a key fob unit but the alarm is not cancelled and the engine will not start
you may have to get another key fob and have it programmed to the ECM system
Apr 23, 2015 | 1994 Chrysler Concorde
How do i reset my security system i lost my fob and my dodge won't start
Firstly you need a good fob not a used one from another car as it is programmed to your vehicle "once" and cannot be programed from another car,this is a security procedure set with a PIN # assigned to your VIN # obtained from your Chrysler dealer,other wise any one could program a fob to your vehicle and drive away.Usually if a wrong key is detected either it won't start or will start momentarily then die,security light will flash with wrong key (fob)signal depending on year.
Dec 20, 2014 | Dodge Cars & Trucks
Turn off alarm without key fob
You can purchase a key fob from your dealer and they will have to program it to your car. The security system can be disconnected but it is not advised.
Mar 22, 2014 | Honda Cars & Trucks
Installed battery into 09 street bob and cannot get the bike to start, oil light on and alarm system seems to cycle when key on
Hi Anonymous, you still might need an alarm reset, for more information about your question please visit the website below. Good luck and have nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 09, 2013 | 2009 Harley Davidson FXDB Dyna Street Bob
Reset alarm system 2006 street bob
Hi Anonymous, for more information on your question please visit the websites below and good luck:
Jan 06, 2013 | 2006 Harley Davidson FXDBI Street Bob
My 2006 Toyota Tundra SR5 will not go into program mode to program my keyless entry pads
The security system on Toyota products are added by the distributor in your region. Many of those security systems will not allow more than 4 key fobs to be programmed into them. Have you owned this vehicle since it was new? Have you tried to program more that 4 key fobs into it? Have you tried programming it more than 2 times? If you security system has had more than 4 key fobs programmed in then the only way to get it to reprogram is the replace the security unit with a new one. I found this out the hard way and had to replace mine in my 2000 tundra.
Aug 03, 2012 | Toyota Cars & Trucks
Replaced chip on key on 91 DTS and car lost all power while driving. It shut down and nothing works.
There are 4 methods for programming key fobs. Up to 4 key fobs may be programmed to the remote control door lock receiver (RCDLR). Each programmed key fob is given a position of #1-#4 in the RCDLR memory.
Method 1 - Key Fob Quick Learn This procedure will add key fobs. Fobs will be numbered in sequence based on when they are programmed; if 2 fobs are currently programmed to the RCDLR, a fob programmed using this method will be numbered as Fob 3. This procedure requires that you have a known good key fob, a replacement key fob, and the vehicles mechanical key.
Important: This procedure is not available when the maximum number of fobs (4) have been programmed. If 4 key fobs are programmed to this RCDLR and this method is attempted, the driver information center (DIC) will display MAX FOBS LEARNED and the programming procedure will exit. Method 4 must be used in this instance.
The vehicle must be OFF.
Place a known key fob within the interior of the vehicle.
Insert the vehicle key in the driver door lock cylinder located in the driver door handle and cycle the key 5 times within 5 seconds.
The DIC will display a message: READY FOR FOB X (X = fob 2, 3, or 4).
Place the replacement key fob in the console fob pocket with the buttons facing forward.
A beep will occur and the DIC will display: READY FOR FOB X (X = fob 3 or 4) or MAX FOBS LEARNED.
If programming additional key fobs, repeat steps 5 and 6, or press the OFF/ACC portion of the ignition switch to exit programming mode.
Operate the active portion of each key fob in order to finalize the programming sequence and verify correct system operation.
Method 2 - Key Fob Slot Programming
This procedure will add or replace a key fob. Method 2 allows you to choose which location (slot) the unprogrammed fob will be learned to. If you are replacing a key fob, this method will erase the previously known key fob programmed to that particular slot. This procedure requires that you have a known good key fob, a replacement key fob, the vehicle mechanical key, and a scan tool.
Important: This procedure is not available when the maximum number of fobs (4) have been programmed. If 4 key fobs are programmed to this RCDLR and this method is attempted, the DIC will display MAX FOBS LEARNED and the programming procedure will exit. Method 4 must be used in this instance.
Install a scan tool.
Use the scan tool, to access the following:
• Vehicle Control Systems
• Computer/Integrating Systems
• Module Replacement/Setup
• RCDLR
• Program Key Fobs
Select Fob X (X = 1, 2, 3, or 4) on the scan tool. This will be the slot you wish to program to.
Place the replacement key fob in the console pocket with the buttons facing forward. A beep will occur indicating programming completion. The previously known fob is now erased.
If programming additional key fobs, repeat steps 4-8, or press the OFF/ACC portion of the ignition switch to exit programming.
Remove the scan tool.
Method 3 - Key Fob Auto Learn
This procedure will first erase all known key fobs. The procedure will then program a single or multiple key fobs. Method 3 is a series of three 10-minute key cycles, for a total of 30 minutes. This procedure requires that you have a replacement key fob and the vehicle mechanical key.
Important: All previously programmed key fobs will be erased upon completion of the 30-minute programming procedure. The order in which the key fobs are programmed will determine its numbering position within the RCDLR memory. The first key fob programmed will be key fob #1, and the second key fob programmed will be key fob #2. The number stamped on the key fob case is for reference only: #2 can be programmed as #1.
Do not place any known good key fobs in the vicinity of the vehicle when programming with Method 3. If the RCDLR recognizes a known good key fob during Method 3 programming, the programming mode will resort to Method 1.
The DIC will display a message: OFF/ACC TO LEARN.
Press the OFF/ACC portion of the ignition button.
The DIC will display a message: WAIT 10 MINUTES, then it will count down from 10 to 0, one minute at a time.
When the counter reaches 0, DIC will display OFF/ACC TO LEARN.
Repeat steps 5-7 two more times, for a total of 30 minutes.
A beep will occur and the DIC will display: READY FOR FOB 1. At this time all previously known key fobs have been erased. When fob 1 is programmed a beep will be heard and the DIC will display a message: READY FOR FOB 2.
Additional key fobs can be programmed by taking fob 1 out of the pocket and inserting fob 2. If desired, up to 4 fobs can be programmed. Once 4 fobs have been learned, the DIC will display a message: MAX FOBS LEARNED, and automatically exit the program mode.
If learning less than 4 key fobs, press the OFF/ACC portion of the ignition button to exit the program mode.
Method 4 - Service Programming System Fob Programming
This procedure is a 10-minute relearn procedure using the Techline Terminal with SPS software. Once the 10-minute timer has expired, the fobs can be programmed similar to Method 2 using slot programming. A scan tool, Techline Terminal, and a replacement key fob are required to perform this procedure.
Place the vehicle in the Vehicle On, Engine Off mode.
Connect a scan tool to the vehicle.
Insure that all power consuming devices are turned OFF on the vehicle.
With a scan tool, select Request Info under Service Programming System and follow the scan tool on-screen instructions.
Disconnect the scan tool from the vehicle and connect the scan tool to a Techline Terminal with the current Service Programming System (SPS) software.
Turn the vehicle OFF.
On the Techline Terminal, select Service Programming System and follow the Techline Terminal on-screen instructions. Ensure the correct programming procedure is selected based on component being replaced or programmed. See Important above.
Disconnect the scan tool from the Techline Terminal and re-connect the scan tool to the vehicle.
With a scan tool, select Program ECU under Service Programming System.
At this point the scan tool must remain connected for the duration of the 10 minute relearn procedure.
When the 10 minute relearn procedure has completed, use the scan tool to access the following:
• RCDLR
• Program Key Fobs
If programming additional key fobs, repeat steps 12-13, or press the OFF/ACC portion of the ignition switch to exit programming.
Oct 26, 2011 | 2006 Cadillac DTS
Home Security Logo
90 people viewed this question
Top IEI Home Security Experts
Lawrence Oravetz
Are you an IEI Home Security Expert? Answer questions, earn points and help others
