Question about Genie Company Genie& Wireless Garage Keypad Entry (GWKP-BL)
Reset code on the genie gxl 9550 keypad
Reset the key code on keypad
Both of my intellicode remotes stopped working. When I tried to reset them, nothing happens. They are still not working.
test use the digital camera or cell when you hit any key the LED must be ON see the picture attached.. Otherwise open the r.control and clean the keypads for dirty, oxide, etc use contacts cleaner.
Oct 17, 2013 | Genie Company Televison & Video
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
Rese gxl 9550 keypad
try and push the learn button on the back of the opener thats hanging in your garage.. while its lite up enter a new code and hit enter..
Dec 08, 2012 | Sears Craftsman LiftMaster Chamberlain...
Can Genie Wireless Keypad work for door w/o LEARN button?
If the keypad doesn't have dip switches it will not work with that opener.
Jun 29, 2012 | Sears Craftsman LiftMaster Chamberlain...
I need to reset the MEP counter. 10 wrong codes were entered in BB 9550. Please help.
For setting the MEP code counter to reset, you can set it on grand reset. This can be done by a good mobile shop. After that you can again get 10 attempts to unlock your Blackberry 9550. Then you can buy the unlocking code with cheaper but reliable rates from an online vendor, for example, Blackberry unlocking codes with IMEI. Good luck and have a nice day.
Jul 22, 2011 | RIM BlackBerry Storm2 9550 Smartphone
Will a genie wireless keypad work a liftmater opener?
No. These components are not compatible between different manufacturers. You can get a universal keypad that will work with the liftmaster opener though.
Good Luck!
Mar 06, 2011 | Genie Company Genie Gwkp Keypad...
Key pad stopped working
Have you changed the battery in it? Most often, this is the cause for key pad failure. Or if you have already changed the battery, is the + & - facing the proper direction?
Jan 16, 2011 | Genie Company Genie Gwkp Keypad...
I was looking on the genie web site on how to change my pin on the key pad. Evidently it wasn't the same key pad. Now my key pad doesn't work at all. How can i fix and do the or original job I started out...
There are many outside keypads and all are different to program. If you go to genie.com or overheaddoor.com(owns genie) there will be a helpline number that will walk you through this. Thanks BB
Jan 09, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
Genie Company Genie& Wireless Garage Keypad Entry (GWKP-BL) Logo
218 people viewed this question
Top Genie Company Building Materials Experts
chrisheman
Ian Lulham
Ian Lulham
Level 1 Expert
robert
Are you a Genie Company Building Material Expert? Answer questions, earn points and help others
