Question about Linear iEi Electronics ProxKey-25 HID Compatible ProxKey Key Fob
Program a key fob for iei security system
Have hid brand key fobs want to program them to work a iei bussiness security system
How do I bypass the factory security system in a 1998 Mitsubishi eclipse without having the door key
When the anti theft system was created,the dealers forgot to tell the new car buyers about how much the fob matters to the vehicle,without it,owners are stuck,your anti theft device is activated,you need to lock and unlock your doors a couple times with the key fob,not the key,and then you need to put the key in the ignition and start it,if you dont have your key fob,call your car dealer to get a new one,they are programmed for each car only,you cannot bypass it.if you lost your fob or never had it,whatever,you need to have the exact fob that came with that car from the factory,the key and fob have a chip in them that only go to that certain car,if you do not have it,then you need to buy a new one from the dealer or ebay and then you need to contact your dealer about programming the fob to your car,you might not have to have it towed if they have the documents from the car,the only other way is to get a junk car,with the steering column,key,fob and all computer boxes and door locks and switch them,i just did that with a 98 dodge dakota,and it works.
Jul 06, 2015 | Mitsubishi Cars & Trucks
Alarm wont stop sounding!
although you can open the door with a key ,unless the alarm system senses a fob key signal it will assume that the door is being opened illegally and will set of the alarm
keys can be cut for all cars requiring a key fob unit but the alarm is not cancelled and the engine will not start
you may have to get another key fob and have it programmed to the ECM system
Apr 23, 2015 | 1994 Chrysler Concorde
Program new key fob for Cadillac cts 2003
There are several methods of doing this - but your 2003 requires that you either go to the dealer for them to add a FOB with special equipment (ask if they'll do it for free - can't hurt). If you have time to kill, you can do it yourself with Method 3 as described and found at:
Key Fob Reprogramming General Cadillac Forums
Method 3 - Key Fob Auto Learn
This procedure will first erase all known key fobs. The procedure will then program a single or multiple key fobs. Method 3 is a series of three 10-minute key cycles, for a total of 30 minutes. This procedure requires that you have a replacement key fob and the vehicle mechanical key.
Important: All previously programmed key fobs will be erased upon completion of the 30-minute programming procedure. The order in which the key fobs are programmed will determine its numbering position within the RCDLR memory. The first key fob programmed will be key fob #1, and the second key fob programmed will be key fob #2. The number stamped on the key fob case is for reference only: #2 can be programmed as #1.
Do not place any known good key fobs in the vicinity of the vehicle when programming with Method 3. If the RCDLR recognizes a known good key fob during Method 3 programming, the programming mode will resort to Method 1.
The vehicle must be OFF.
Place the replacement key fob in the console pocket with the buttons facing forward.
Insert the vehicle key in the driver door lock cylinder located in the driver door handle and cycle the key 5 times within 5 seconds.
The DIC will display a message: OFF/ACC TO LEARN.
Press the OFF/ACC portion of the ignition button.
The DIC will display a message: WAIT 10 MINUTES, then it will count down from 10 to 0, one minute at a time.
When the counter reaches 0, DIC will display OFF/ACC TO LEARN.
Repeat steps 5-7 two more times, for a total of 30 minutes.
A beep will occur and the DIC will display: READY FOR FOB 1. At this time all previously known key fobs have been erased. When fob 1 is programmed a beep will be heard and the DIC will display a message: READY FOR FOB 2.
Additional key fobs can be programmed by taking fob 1 out of the pocket and inserting fob 2. If desired, up to 4 fobs can be programmed. Once 4 fobs have been learned, the DIC will display a message: MAX FOBS LEARNED, and automatically exit the program mode.
If learning less than 4 key fobs, press the OFF/ACC portion of the ignition button to exit the program mode.
Operate the active portion of each key fob in order to finalize the programming sequence and verify correct system operation.
Feb 25, 2015 | 2003 Cadillac CTS
How do i reset my security system i lost my fob and my dodge won't start
Firstly you need a good fob not a used one from another car as it is programmed to your vehicle "once" and cannot be programed from another car,this is a security procedure set with a PIN # assigned to your VIN # obtained from your Chrysler dealer,other wise any one could program a fob to your vehicle and drive away.Usually if a wrong key is detected either it won't start or will start momentarily then die,security light will flash with wrong key (fob)signal depending on year.
Dec 20, 2014 | Dodge Cars & Trucks
Turn off alarm without key fob
You can purchase a key fob from your dealer and they will have to program it to your car. The security system can be disconnected but it is not advised.
Mar 22, 2014 | Honda Cars & Trucks
Programming keyless remote
Below is a couple proceedures on the subject --first one sets your personal security code in case you lose your Fob or if the battery should die the second one is ASSIGNMENT of a Key Fob to the bike
Below
mail_dir.ashx?url=http%3a%2f%2fwww.fixya.com%2flxp.gif%3ftype%3dimpression%26mailid%3d204&met=0&mt=204 This must be done when you buy a new button type key fob for the Alarm if you lose one.
I assume you know your personal entry code using the directional switches and the key switch to activate , if not , it's in the
Owners Manual
If you never set the code,the dealer can help you out here.
1. Set run switch to off
2. ign to acc
3. hold both turn sigs till lights flash
4. use
Left Turn Signal to enter number by pushing 7 times
5. use right turn signal as enter key
6. repeat until all 5 are entered and you hit enter
lights should flash and you should be OK.
KEY FOB ASSIGNMENT
The Key fob on TSSM motorcycles must be set so it will operate the alarm system on the vehicle.
This assignment must be completed with no pauses between steps greater than 10 seconds.
Turn the ignition OFF after all key fobs have been assigned.
The
programming mode will also exit after 60 seconds has elapsed without detecting any fob signup messages
or turn signal switch activity.
Two key fobs may be assigned to the TSSM.
The first successful attempt to program a fob will disable all previously assigned fobs.
If a second fob is to be programmed, it must be done in the same programming sequence as the initial fob.
Nov 16, 2013 | Harley Davidson Motorcycles
My 2006 Toyota Tundra SR5 will not go into program mode to program my keyless entry pads
The security system on Toyota products are added by the distributor in your region. Many of those security systems will not allow more than 4 key fobs to be programmed into them. Have you owned this vehicle since it was new? Have you tried to program more that 4 key fobs into it? Have you tried programming it more than 2 times? If you security system has had more than 4 key fobs programmed in then the only way to get it to reprogram is the replace the security unit with a new one. I found this out the hard way and had to replace mine in my 2000 tundra.
Aug 03, 2012 | Toyota Cars & Trucks
Replaced chip on key on 91 DTS and car lost all power while driving. It shut down and nothing works.
There are 4 methods for programming key fobs. Up to 4 key fobs may be programmed to the remote control door lock receiver (RCDLR). Each programmed key fob is given a position of #1-#4 in the RCDLR memory.
Method 1 - Key Fob Quick Learn This procedure will add key fobs. Fobs will be numbered in sequence based on when they are programmed; if 2 fobs are currently programmed to the RCDLR, a fob programmed using this method will be numbered as Fob 3. This procedure requires that you have a known good key fob, a replacement key fob, and the vehicles mechanical key.
Important: This procedure is not available when the maximum number of fobs (4) have been programmed. If 4 key fobs are programmed to this RCDLR and this method is attempted, the driver information center (DIC) will display MAX FOBS LEARNED and the programming procedure will exit. Method 4 must be used in this instance.
Place a known key fob within the interior of the vehicle.
The DIC will display a message: READY FOR FOB X (X = fob 2, 3, or 4).
Place the replacement key fob in the console fob pocket with the buttons facing forward.
A beep will occur and the DIC will display: READY FOR FOB X (X = fob 3 or 4) or MAX FOBS LEARNED.
If programming additional key fobs, repeat steps 5 and 6, or press the OFF/ACC portion of the ignition switch to exit programming mode.
Method 2 - Key Fob Slot Programming
This procedure will add or replace a key fob. Method 2 allows you to choose which location (slot) the unprogrammed fob will be learned to. If you are replacing a key fob, this method will erase the previously known key fob programmed to that particular slot. This procedure requires that you have a known good key fob, a replacement key fob, the vehicle mechanical key, and a scan tool.
Important: This procedure is not available when the maximum number of fobs (4) have been programmed. If 4 key fobs are programmed to this RCDLR and this method is attempted, the DIC will display MAX FOBS LEARNED and the programming procedure will exit. Method 4 must be used in this instance.
Install a scan tool.
Use the scan tool, to access the following:
• Vehicle Control Systems
• Computer/Integrating Systems
• Module Replacement/Setup
• RCDLR
• Program Key Fobs
Select Fob X (X = 1, 2, 3, or 4) on the scan tool. This will be the slot you wish to program to.
Place the replacement key fob in the console pocket with the buttons facing forward. A beep will occur indicating programming completion. The previously known fob is now erased.
If programming additional key fobs, repeat steps 4-8, or press the OFF/ACC portion of the ignition switch to exit programming.
Remove the scan tool.
Method 4 - Service Programming System Fob Programming
This procedure is a 10-minute relearn procedure using the Techline Terminal with SPS software. Once the 10-minute timer has expired, the fobs can be programmed similar to Method 2 using slot programming. A scan tool, Techline Terminal, and a replacement key fob are required to perform this procedure.
Place the vehicle in the Vehicle On, Engine Off mode.
Connect a scan tool to the vehicle.
Insure that all power consuming devices are turned OFF on the vehicle.
With a scan tool, select Request Info under Service Programming System and follow the scan tool on-screen instructions.
Disconnect the scan tool from the vehicle and connect the scan tool to a Techline Terminal with the current Service Programming System (SPS) software.
Turn the vehicle OFF.
On the Techline Terminal, select Service Programming System and follow the Techline Terminal on-screen instructions. Ensure the correct programming procedure is selected based on component being replaced or programmed. See Important above.
Disconnect the scan tool from the Techline Terminal and re-connect the scan tool to the vehicle.
With a scan tool, select Program ECU under Service Programming System.
At this point the scan tool must remain connected for the duration of the 10 minute relearn procedure.
When the 10 minute relearn procedure has completed, use the scan tool to access the following:
• RCDLR
• Program Key Fobs
If programming additional key fobs, repeat steps 12-13, or press the OFF/ACC portion of the ignition switch to exit programming.
Oct 26, 2011 | 2006 Cadillac DTS
Keyless entry remote programming
Hello here is the instructions for programming the key fobs
This procedure will add, replace, or invalidate all key fobs. This procedure requires that you have a known good key fob available, a new/replacement key fob, the vehicles mechanical key, and a scan tool.
Method 1 is also used for the initial programming of fobs to a new replacement RCDLR. In this instance, the new RCDLR comes ready to learn the first key fobs introduced. Perform the learn procedure as outlined, with the exception that the new RCDLR does not require a known good key fob be placed within the interior of the vehicle.
Note: This procedure is not available when the maximum number of fobs (4) have been programmed. If 4 key fobs are programmed to this RCDLR and this method is attempted, the driver information center (DIC) will display MAX FOBS LEARNED and the programming procedure will exit. Methods 2 or 3 must be used in this instance.
  1. The vehicle must be OFF.
  2. Place a known key fob and any new/replacement key fob(s) to be programmed in the cupholder inside the vehicle. DO NOT place any fobs in the console fob pocket at this time.
  3. Insert the vehicle key in the driver door lock cylinder located in the driver door handle and cycle the key 5 times within 5 seconds.
  4. The DIC will display a message: READY FOR FOB X (X = fob 2, 3, or 4). → If the DIC displays: OFF/ACC TO LEARN, the known fob has not been recognized. At this time, programming will revert to Method 2.
  5. If the DIC is displaying the correct fob number that needs to be programmed, skip ahead to step 9.
  6. If the DIC is not displaying the correct fob number that needs to be changed (i.e., the DIC is displaying: READY FOR FOB 3, and you wish to program FOB 1), use the scan tool to access the following: • Vehicle Control Systems • Computer/Integrating Systems • Module Setup • Remote Control Door Lock Receiver • Program Key Fobs
  7. Select the fob position you wish to program: Note: Selecting Invalidate All Fobs will erase any known fobs and will cause the DIC to prompt READY FOR FOB 1, requiring all fobs to be relearned to the vehicle.
    • Invalidate All Fobs • Program Fob 1 • Program Fob 2 • Program Fob 3 • Program Fob 4
  8. With the fob position selected, press the PROGRAM soft key on the scan tool. The DIC should display: READY FOR FOB X (X = fob 1, 2, 3 or 4, depending on the selected position)
  9. With the DIC displaying the correct fob position that is to be programmed, place the new/replacement key fob in the console fob pocket with the buttons facing forward.
  10. A beep will occur once the fob has been learned.
  11. If programming additional key fobs and there is no DIC prompt that indicates READY FOR FOB X, repeat steps 7 and 8.
  12. Exit programming mode by pushing the OFF/ACC portion of the ignition switch. Note: Failure to exit programming mode (press OFF/ACC) prior to pressing the UNLOCK button of each key fob programmed will result in that fob being inoperative. Pressing the UNLOCK button completes the programming sequence and is require to ensure transmitter operation.
  13. Press the UNLOCK button on each key fob that was programmed to finalize the programming and confirm system operation.
Nov 03, 2010 | 2006 Cadillac STS
Programming a keyless entry remote
Key Fob Auto Learn
Do not place any known good key fobs in the vicinity of the vehicle when programming.
Good luck and hope this help's keep me posted, there are 3 other methods and the 5th method is a tech 2 scan tool that the dealer uses but this should work on your year of cadillac.
Jul 01, 2009 | 2003 Cadillac Deville
Linear iEi Electronics ProxKey-25 HID Compatible ProxKey Key Fob Logo
210 people viewed this question
Top Linear Home Security Experts
ka4iup
ka4iup
Albert Barkley
Albert Barkley
Are you a Linear Home Security Expert? Answer questions, earn points and help others
