MB-trac 800 turbo wont go back into mormal range it is almost like there isnt anything gear there
The tractor is about an 1988 year and has worked hard
3 Suggested Answers
  • 16 Answers
SOURCE: trac off light is on shifts hard
i believe theres a small button on your shifter to push for trac off and on, there was on my 98 anyways...
Posted on Oct 20, 2009
rx7rrr
  • 46 Answers
SOURCE: need fuse panel diagram 1988 rx7 non turbo it wont
You can download a FSM and wiring diagram from http://foxed.ca.
Posted on Mar 14, 2015
1.6 duratorq tdci wont start after cutting out during regen
sorru without my heads in the engine i couldnt tell you ,but providing that everything is ok like timing belt and oil and water ect then what i do with these engines is too use a external fuel pump and pressurise the fuel from the outlet of the filter to the common rail pump ,often they get a air lock and defy all but you know who.musnt say god in case i offend the muslims or the jehovehs or somehting but that normally works ,now another tip depending on year and look in the intake pipe from the turbo to inlet manifold and see if your one has a sensor halfway along this pipe ,if it has remove it and make sure that it isnt full of oil as this stops it from starting and make sure their isnt excessive oil in the turbo pipe indicating that the turbo bearings are worn ,then the oil builds up in this pipe causing this sensor to not read stopping the engine from starting ,as for a crank sensor then never had one fail as yet ,its whats known as a hall sensor its just a coil that a reads a magnetic field ,and yes its favourite among a lot of get rich quick garages.Especially opel dealers on the zafiro/astra range of engines when it just the computer needs remapping as its bolted to the engine and get hot . But thats another story
Apr 26, 2015 | Ford Focus Cars & Trucks
How do I fix a transaxle in a turf trac lawnmower that is tough to change gears in?
Could it have an object jammed inside the shifting arm or it could actually be bent just enough over the years from wear and tear.
Sep 24, 2014 | Mtd Garden
Why the gearbox can easily change the drive gear?why the 5th gear stop to drive?
first pull the fill plug and check the oil level if low add some if not then it's a bigger problem and you need to take it in.
May 09, 2014 | 1988 Toyota Land Cruiser
How do I find the model or year on 38" John Deere with no hood?
A ten year old mower that probably cost about $1500.00 at least twn years ago that has not been taken care of is not worth much.
John Deere is a good name as in Kohler. How much is it worth? It is currently worth what you paid for it, you just made it worth that much.
Mar 08, 2010 | Garden
88 dodge shadow idles very ruff. pedal to floor to start.
i have an 88 dodge shadow turbo with a five speed. the car will fall on its face at 5500rpm coming out of first gear. and its rpm range gets lover with each gear. the fuel pressure rises when it fall on its face. the car never dies just falls then picks back up and will fall again unless you keep it under the that rpm. then it is fine. what could be the problem?
Jul 17, 2009 | 1988 Dodge Shadow
Wont stay idle
The idle solenoid must have gone bad. have an expert come fix it for you.
May 27, 2009 | 1988 Suzuki Samurai
1988 Chevy pickup will not move when put in reverse.
reverse synchronizer isnt getting proper lubrication or is worn down. Check lines, and change filter and screen or fluid. But normally in cases like this a gear has dropped and wont grip because the teeth cannot clamp when trans wants to spin.
Hope it works out! It can be expensive
Feb 16, 2009 | 1988 Chevrolet C2500
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
