Question about Mitsubishi 934C260003 Main Board for WD-C657
I'm looking for a main board 934C260003 for a WD-C657
I don't like Mitsibishi prices is there an after market product to replace this main board
    Top Expert:
  • Mitsubishi Master
  • 74,136 Answers
It will be very difficult to get original replacement board to Mitsubishi by open electronic spare part market.
Posted on Dec 08, 2012
I want whirlpool oven mechanic in kakinada
see the details and proceed according. fix it. God bless you
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Nov 15, 2012 | Whirlpool Microwave Ovens
Tcpv10 main board
I've looked all over, that main board is on back order. However the typical price for the board is $120-$170. Personally, I would toss the TV on Craigslist as a parts set. If you get $40-$60 for the set as is, TAKE IT AND RUN !!! I would buy a new set and use the money you get from the sale of the old TV to pay for extended warranty.
Sep 06, 2012 | Panasonic TC-P50V10 TV
I need the shematics to install A DMD chip in my Mitsubishi Model WD-C657
When you take off the back cover you are pretty much looking at the chip. Right in front of you in the middle of the light engine is a little fan.
Remove the fan and you will see a big metal heat sink / shield. remove the sheild and you will see a circuit board. in the middle of the board is the dmd chip.
Aug 19, 2012 | Mitsubishi Televison & Video
Mitsibishi Wd-73735 Ghost Lines Cooling Issue?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 05, 2017 | Mitsubishi WD-73735 Television
I have white spots and black spots on right side of Mitsubishi WD-C657. I've done research online, and have heard its the dlp chip. Is that true, and if so, is it something that I can replace myself,...
This tv is it the DLP projection light engine block main board itself is the problems,not easily to go into the tv itself and replacing the IC chip itself.Must take out many mechanical parts to get u the Light engine block it self.U can replaced IC but somethime the IC chip it replaced,will not solved the problems,because the tv problems now the it is spreading and going on beyond the IC chip itself.If want to keep this tv very exspensive repair,i would reconmend hire a bound qualify tv tech replaced the whole Light projection block itself,but first call Mitsubishi for some kind of deal,they might help with the repair amount cost.
May 13, 2011 | Mitsubishi WD-C657 65" HDTV
Will not turn on
if LED is blinking then following is the solution.....usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound ..but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective ......if LED is not blinking then.....on main board in power section area some component is deffective.....MAIN BOARD HAS TO BE CHECKED COMPLETELY...... so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 ( US$ 12) ........iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com ) .....i don't have any idea about EHT component's price & service charge in your area........this problem cannot be solved by user unless user is a technical person having idea about components (resistors, transistors,diodes,...etc..), having multimeter , soldering iron & other tools...so my suggestion call TV service engineer or contact philips service centre.........
Apr 20, 2011 | Philips Televison & Video
How to change tv lamp mitsubishi wd-c657
Read page 61 and 62, this s is the official Mitsubishi Owners Manual for you TV
http://static.highspeedbackbone.net/pdf/Mitsubishi-WD-C657-Manual.pdf
Jan 27, 2011 | Mitsubishi WD-C657 65" HDTV
I have a dull picture on my mitsibishi TV model WD-60C8 that just happened out onv nowhere. what could be the problem
The reason you have a dull picture is because the lamp/light of the television is bad.
Try to replace the lamp of the television and it will be okay once again.
And if that does not work then it means it is a cold joint as a result of melted lead on the main board of the television.
Take care
Oct 11, 2010 | Mitsubishi Televison & Video
Looking for a ballast part number and price Mitsubishi WD-C657
encompass.com or parstore.com is a good store parts.
Just provide model number tv.
Thank you
Aug 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 934C260003 Main Board for WD-C657 Logo
53 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
