Question about LG LFC23760 Bottom Freezer Commercial French Door Refrigerator
I am replacing the PTC Relay when it gats here tomorrow. does anyone have a link to the service manual for a LG LFC23760 Bottom Freezer Commercial French Door Refrigerator?
  • LG Master
  • 4,654 Answers
This will work for what you are doing=> LFC23760 Service Manual
Thanks Sea Breeze
Posted on Dec 08, 2012
SOURCE: Bottom freezer door/drawer won't close all the way on one side.
Remove all the food from the freezer and then the drawer from the cabinet. Now using a silicone based lubricant, lube the tracks up real well. Be sure to clean the tracks first if gunked up. Make sure nothing small fell out of the basket over time and is laying on the floor in the rear of the freezer section. Once done, you should be fine.
Eric Campion
Posted on Feb 21, 2009
SOURCE: how do I reset the lg water filter indicator light
i fixed the problem by asking my son. he has more patience than i and just held down the button longer and it worked.
Posted on Oct 15, 2009
  • 161 Answers
SOURCE: LG Refrigerator; light stays on, not cooling
There is a recall for that problem the main board is bad. Contact LF for advise
Posted on Jan 24, 2010
  • 6 Answers
SOURCE: LG Model LFC23760 (French Doors, bottom freezer) power prob
Unplug fridge.
Open panel on back of fridge (the one at hip height that says Service Panel Only - Do Not Remove, blah blah blah)
See pictures here: http://www.amazon.com/LG-LFC23760SW-French-Refrigerator-White/dp/B00198A5C0/ref=cm_cmu_up_thanks_hdr
Replace fuse with 9A 250V slow-burn fuse. I used a gray fuse harness from Radio Shack so that if the fuse needs to be replaced again I can just pop in a new one without doing the soldering over.
I nuked the original fuse, the end-caps and the wires that went from the end-caps/fuse to the motherboard. I replace those wires with some I scavenged off a fresh thermal fuse (also bought at RS, just needed the wires themselves which seemed to be the same diameter/gauge as the original leads) and ran them from the motherboard to the wire harness.
So far, so good!
Good luck to you.
Posted on Mar 07, 2010
TheMobilian
  • 8220 Answers
SOURCE: French door LG refrigerator with freezer on the
It might be something simple like the water faucet is not open all the way
LG FRENCH DOOR SERVICE MANUAL
Posted on May 21, 2010
How do I clean the drip pan
You have to pull the refrigerator from the wall to gain access to the rear panel. Remove the screws and look to see the drip pan. Do Not Try To Remove! Big pain in the but, and you will probably break something in the process. You have to be creative what you use. Try a rag or paper towels on a stick to try to wipe the mold and what ever is in there. Then put a cap full or two of bleach in the drip pan to kill any remaining mold and discourage growth of new mold. Your refrigerator will defiantly smell better. Assuming that is why you are cleaning the drip tray.
If this helped help us by joining our Google Plus page.
Thanks
On Time Appliance Google
Jun 30, 2015 | LG LFC23760 Bottom Freezer Commercial...
Freezer warm no ice
replace the ptc overload relay on the compressor
May 02, 2012 | General Electric PFSS6PKXSS Stainless...
My LG LFC23760 Bottom Freezer Refrigerator stopped working. I checked the circuit breaker and the outlet and they're OK. Can I replace the power supply board myself (if that's it) ?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 03, 2011 | LG LSC26905TT Side by Side Refrigerator
LG LFC23760Sw has no power what could be the problem
You likely have a blown fuse on your Master Control Board, this problem has various solutions posted on this site. Look for LFC23760 problems on this site.
Aug 03, 2010 | LG LFC23760SW Side by Side Bottom Freezer...
Our LG LFC23760 was delivered last Saturday. It is now Friday. Ice cream is not freezing solid. I used the 4 setting for top and bottom, which is the recommended setting. We work all day so the door...
I believe that you fridge is anew one and if what you explained is true you must immeditely make a complaint in the LG's service website. If the door is rubbing it is not a good sign as the product may be damaged on transit and could have also resulted in gas leak. So if there is any such problem you must ask your dealer for explanation or replaement of the piece. make this complaint very seriously before you get this tampered by an unauthorised or DIY.
I hope you get me right and hope this helps you to decide. Good day
Jul 30, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Kenmore refrigerator PTC relay for compressor
This is for a Kenmore PTC relay that I just pulled from my fridge. It dosn't have an ice maker. Hope this helps.
Pin 1 = White
Pin 4 = Blue
Gold Pin = Red
Oct 19, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
LG LFC23760 Bottom Freezer Commercial French Door Refrigerator Logo
232 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
