Question about Boating
Reel wont engage to wind in line
How do I take the reel apart?
    Problem Solver:
  • 14 Answers
Depending on the reel it could come apart differently. On a closed face reel you normally turn the top half about 1/4in. and then the top pulls off. On a open faced reel if you look atop the cylinder that the line wraps around there should be a screw on there. Or sometimes the whole top of the cylinder unscrews.
Posted on Dec 15, 2012
I have the 1276sli abumatic spincast reel. The issue is when am reeling the line in there is bump in the handle always at bottom as i crank the line in under load.
Hey michael,
Sometime when you add line to a spincast reel, where you tie the knot and wind line onto the reel, it makes a bump in the spool, this "bump" in the spool sometimes hits inside the reel everytime it makes a rotation....
May 18, 2017 | Fishing
How to take reel apart to reload line
Hi Karen:
If this is a fishing reel, pull off the old line into a plastic bag or wind it on to an old spool so it can be safely discarded. Tie the new line on to the reel, and wind the new line on.
There used to be a closed face spinning reel that you would unscrew the face cover to access the spool.
If this is a weed eater, grass whip, some of the older units had a threaded centre with a left hand thread. Once unscrewed, the spool lifted off and you could wind on the new cutting cord.
Happy fishing, or gardening.
May 14, 2015 | Sport & Outdoor - Others
Why is my reel able to reel both directions instead of locking in place?
Sounds like the slider switch didn't get back into it's socket properly, take it back apart and look at that.
Jan 31, 2015 | Abu Garcia 7000i RED Baticasting Reel
Fishing reel wont engage
Sounds like it needs some TLC and repair. Home
I've included a link to The Reel People. MIke can help you out.
Nov 12, 2014 | Fishing
The level wind guide moves when reeling in but does not move when the line is running out what is wrong
There may not be anything wrong.
some levelwindays reels disengage the line guide during casting or when releasing line.
Sep 23, 2014 | Fishing
What is a fishing reel?
A fishing reel is a round device attached to a fishing rod used in winding the line.
Feb 20, 2013 | Fishing
How do you change from right hand wind to left hand wind on a Shimano Moocher 2000 fishing reel.
unscrew the 2 screws and change position of line guide, remove anti-reverse ratchet,flip it over and re-assemble.if you get stuck go online to fishingmag.co.nz and put the name of your reel in. regards barry.
Sep 29, 2009 | Sport & Outdoor - Others
Wont coil back into its housing, so trimmer wont start. Has compression though
Hi, this a cut&paste from elswhere but it applies to your problem:
how to repair a recoil spring: whats missing is this, you should always wgear eye protection when dealing with springs of any kind.
remember safty first. :)
Remove the recoil shroud and take a look at the assembly.
You might have a broken spring or just a rope that has slipped out of the reel.
The spring usually breaks at one of the end tabs. If so, you will need to get a replacement spring and carefully wind that in, before re-assembling the rope reel. You might wish to replace the rope also, if it shows signs
of wear.
You will need to remove the entire cooling shroud. There should be 4 bolts on the sides. You might need to remove the fuel tank also. Pre-wind the recoil reel by hand [about 6 turns, to set the spring tension] and clamp it with Vise-Grip pliers. Remove the old rope. Thread
the new rope through the shroud housing eyelet and to the reel hub. Let the reel re-wind itself until it is full. If there is not enough spring tension you can wind it a couple of turns more by slipping the rope around
between the reel and shroud. Re-clamp the reel. Cut the rope to length and thread it though the handle. At all knots, burn and melt the rope with a
lighter to prevent untying. Re-assemble.
(special thanks to "Micheal"the author)
May 19, 2009 | Poulan Pro 25hht 25cc 22" Gas Hedge...
No instructions for how to feed line onto Penn fishing reel 500L
put line through ur spreader on the multi[plier then tie a loop not cut off the little bit after tying knot then wind up slowly till it starts to get tight then speed up ur process till u are happy with the amount on ur reel
Mar 01, 2009 | Penn Gt Levelwind Series Reels
Boating Logo
133 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
