Question about Breville Coffee Makers & Espresso Machines
Breville - BES860 doesn't automatically stop coffee pour anymore
Water (coffee) just keeps pumping into cup till turned off manually
danforddan1
  • 192 Answers
SOURCE: water leaks out from underneath coffee maker
Well they don;t give these away for sure. Lets see if we can help you out. ? are you over filling it.This happened to me because I was reading the fill line wrong. {got new glasses} . If not may be you could try makeing less. But if only 1/2 cup comes out and no more, that wouldent indacate a leak in the tank, if there was it would all leak. Try backing off on the coffie and water, and see if it still leaks. if it does get back to me. DFD
Posted on Apr 13, 2009
  • 460 Answers
SOURCE: hot water does not go through the individual cup
check to see if the outlet hole is plugged up and use a tooth pik to clean it out then try bo brew again..
Posted on Nov 12, 2009
  • 58 Answers
SOURCE: My Breville Keurig won't brew the coffee
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
Posted on Jun 24, 2010
heatman101
  • 43501 Answers
SOURCE: keurig coffee maker pours water back into tank
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Posted on Feb 26, 2011
heatman101
  • 43501 Answers
SOURCE: Hot water keeps pouring back
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 13, 2011
I have a Breville Fresca BES860 2Cup Coffee Maker and I've lost my manual. The Clean light is on and I can't remember what to press to start the clean process on my machine. Can you please...
Turn your machine off, then push and hold the 1 and 2 cup buttons and then while still holding them push and hold the power button. Wait until the clean cycle begins.
Sep 07, 2011 | Breville Fresca BES860 2Cup Coffee Maker
Water still does not flow, even after I cleaned it and tried running just water.. don't know what else to try?
water flow very little have cleaned machine but stil the same, also what is the allen key for?
Aug 23, 2011 | Breville Fresca BES860 2Cup Coffee Maker
I just bought a Breville BES860 Fresca Espresso Machine and when I tried to put the basket into the portafilter, it doesn't fit. The portafilter came standard with the machine. Do I need a bigger...
They require a bit of effort to push them in when new, you should have gotten a set of single wall and dual wall baskets. There is a spring clip inside the grouphead (portafilter) and you have to overcome the clamping of the spring it is a reasonably tight fit to stop the basket retaining in the machine.
Jul 02, 2011 | Breville Fresca BES860 2Cup Coffee Maker
No steam no hot water
Do you have enough water in the tank? Is the filter secured in the tank?
Move the steam dial from standby to steam and wait about 20-30 seconds, should steam if it doesn't most likely faulty.
Jun 14, 2011 | Breville Fresca BES860 2Cup Coffee Maker
Keurig B70 won't stop cycling water. it just keeps draining the resevoir. Water is cold, not heated.
heatman101
Feb 02, 2011 | Keurig B70 Coffee Maker
Does anyone know about the issue with the water holder on the Breville Fresca BES860. It wont sit in place correctly and spills water all through the machine...
There should not be a problem, it has moulded holders built in to both the back of the machine and in to the reservoir. They fit together, not just against each other. Once fitted together it locks securely, do not overfill it and do not fill it while on the machine. That will cause it to spill.
Oct 17, 2010 | Breville Fresca BES860 2Cup Coffee Maker
Coffee Makers & Espresso Machines Logo
44 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
