Question about Amazon Kindle Paperwhite
Kindle reset button - Amazon Kindle Paperwhite
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Amazon Master
  • 102,366 Answers
Press and hold the power button for twenty seconds. You'll then have to hold the power button again for a second or two until the Kindle starts to reboot.
Posted on Dec 08, 2012
  • Fran Howse
    Fran Howse Jan 10, 2015
    Thank you very much. Your fix worked for my Kindle Paperwhite. I was lost without it and now it is back and I am good.
How to reset kindle
Hard and Soft Reset
  1. Make sure the Kindle is turned ON. ...
  2. Press the Power button for at least 20 seconds. ...
  3. Wait for it to reboot - wait a minute or two. ...
  4. Your kindle should be back to a responsive state.
  5. You will have to go through the setup again and then synchronize to put your e-books and other data back on the device.
Kindle Reset Procedures for all Kindles - Brainchamber Blog
www.brainchamber.com/2013/06/15/kindle-reset-procedures/
How to reset kindle Google Search
Dec 30, 2016 | Tablets & eReaders
Tip
How to reset the Amazon Kindle (useful when the unit is frozen)
Hi.
The Amazon Kindle is known for having several firmware issues, and it is not unusual seeing the unit freezing and not starting.
To start you can attempt doing a soft reset. To do a soft reset press and hold the <ALT>, <Shift>, and <R> keys simultaneously. The Kindle display should go blank for few seconds, and then restart.
If your Amazon kindle is still frozen, try resetting the unit to factory default settings with the hard reset procedure below. Procedure is different, depending on the Kindle model.
All you have to do to reset the Amazon Kindle 2 and Kindle DX is pressing and holding down the power button for about twenty seconds, then release the button and let the unit restart.
If instead you have the previous model, the amazon Kindle one, then you will need to open the back cover by pressing it and sliding it to the right with your finger, same as when you have to replace the batteries.
Behind the cover you will see the reset hole switch.
Push and hold a sharp pointed object, like a paper clip, or the tip of a pencil inside the hole button located under the battery cover.
Wait about ten seconds until the Kindle restarts and resets to default settings.
The last procedure and the picture below refer to Kindle one only. If you have kindle two, then please use the first procedure.
If the above does not fix the problem, then the unit is faulty. In that case contact Amazon to get support.
Regards.
on Feb 21, 2010 | Amazon Kindle Wireless Reading Device
Where is the reset button on the kindle fire?
According to eHow.com: " E-Reader Soft Reset
  • 1 Open your Kindle's Menu while on the Home screen. Do so by pressing the Menu button, or the onscreen Menu icon for Kindle Paperwhite owners. Select the "Settings" option.
  • 2 Choose "Menu" again from within the Settings menu. This displays a different menu than before.
  • Sponsored Links
  • 3 Choose the "Restart" option. Wait while your Kindle powers off and on again.
E-Reader Hard Reset
  • 1 Charge your Kindle e-reader before performing a hard reset. Charging helps ensure your problem isn't related to the device having a low battery.
  • 2 Hold down the Power button for 20 seconds. The screen will change after a few seconds, but continue holding the power button for the full 20 seconds before releasing.
  • 3 Wait while your Kindle restarts.
E-Reader Factory Reset
  • 1 Press your Kindle's Menu button. Select "Settings" from the menu.
  • 2 Open the menu once more from within the Settings window. Select "Reset to Factory Defaults," or "Reset Device" if you're using a Paperwhite.
  • 3 Select "Yes" in the confirmation window after reading the warning. Wait while your Kindle restarts and restores.
Fire Soft Reset
  • 1 Hold the Power button down for three to five seconds. A Shutdown window appears.
  • 2 Tap the "Power Off" button in the Shutdown window. Wait for the Fire to shut down completely.
  • 3 Press the Power button to turn the device on again.
Fire Hard Reset
  • 1 Plug your Kindle Fire in and give it time to charge before performing a hard reset. This helps ensure your issues aren't related to having a low battery.
  • 2 Hold down the Power button for 20 seconds. The Kindle Fire will shut down.
  • 3 Press the Power button to turn the Kindle Fire back on.
Fire Factory Reset
  • 1 Swipe your finger down from the top of your Kindle Fire's screen, presenting the Quick Settings menu.
  • 2 Tap the "Settings" option and select "Device."
  • 3 Select "Reset to Factory Defaults," then tap the "Reset" button. Wait while your Kindle Fire restarts and restores.
Read more : http://www.ehow.com/how_6122863_reset-kindle.html
May 10, 2015 | Tablets & eReaders
How do I reset my first generation Kindle Fire and where is the reset button
Restarting Kindle Fire may resolve intermittent issues like a frozen screen, battery issues or trouble downloading content to your Kindle Fire.
To restart your Kindle Fire, press and hold the power button for 40 seconds and then release. After the device has completely turned off, press the power button to restart your Kindle Fire.
If your Kindle Fire is still unresponsive, try charging your Kindle Fire before trying to restart the device again.
Make sure you have the latest software version available installed on your Kindle Fire. The latest version is available at www.amazon.com/kindlesoftwareupdates
Mar 01, 2015 | Tablets & eReaders
Kindle, stuck in sleep mode
How to Reset Kindle - courtesy Andrei Pushkin
Kindle DX, Kindle 2 or Kindle 3: This is easy - just hold the power button (next to the headphone jack) for 15 seconds and the device will reboot.
Reset Kindle 1: This is trickier as you'll first have to remove the back cover; you'll also need a paperclip.
Read more: Reset Kindle
Jan 29, 2014 | Amazon Kindle Wireless Reading Device
Where is reset button in a kindle
Hold down the 'on' switch for 20 seconds. The Kindle will reboot - you will not lose anything on your Kindle.
If you need to reset it to factory default (which will remove ALL content) then:
  1. From Home, press the Menu button, and then select Settings.
  2. In Settings, press the Menu button again, and then select Reset to Factory Defaults. Your device will power off and power back on.
Oct 22, 2013 | Amazon Kindle 1
How to reset your kindle
Hey
To reboot or restore your kindle to factory setting do the following:
Hold the power button to the right for 20 secs
This will switch the kindle off
Hold the 'Home' button for 60 secs
The kindle reset screen will be displayed
To reboot the kindle without lose of files, press the 'Del' button
To restore to factory settings, type DELETE in the box provided
The kindle will restore once the final 'E' is entered
I hope the above helps and resolves your issue.
Mar 14, 2012 | Amazon Kindle 3 WiFi
Amazon kindle reader reset
To perform a hard reset of the Kindle just press and hold the power on button for 20 seconds as described in the Kindle Support web site for dealing with Frozen devices.
If you want to reset your Kindle back to Factory defaults then you would need to press the Menu button, then go into Settings and you will find an option there to Reset to Factory Defaults.
Dec 30, 2011 | Amazon Kindle Wireless Reading Device
How to set password if we lost the old
Hey there,
If you cannot enter the password, you will need to reset your kindle back to factory settings. On the back panel, there is a small reset button: http://www.blogkindle.com/wp-content/uploads/2009/03/kindle-reset.gif
  1. First, you need something pointed like a paper clip or the tip of your earing.
  2. Now, open the back cover of your kindle by pressing it firmly while sliding it to the right using your thumbs.
  3. You will then see the reset button as shown on the picture. Use the paper-clip or your earing's pointed tip to press on the reset button.
  4. A few seconds after pressing the button, your kindle will then reboot and will be restored.
Note that you will need to reload all of your eBooks back onto the kindle after doing this.
Hope this helps, thanks for using fixya. Dont forget to rate!
Mar 11, 2011 | Amazon Kindle 1
My Kindle 3G seems to have frozen.
Amazon recommends the following steps. As I'm sure you have already tried the power switch, try starting from Step #5 to do a hard reset on your Kindle.
Source: Amazon.com
  1. Unplug Kindle from power adapter or computer.
  2. Slide and release the power button. The LED light that surrounds the power button will display green for two seconds.
  3. Shut down Kindle by sliding and holding the power button for five seconds. The LED light will blink three times. Wait for the screen to go blank, then release the power button.
  4. Turn on the Kindle by sliding and releasing the power button.
  5. If Kindle is still not working, you can perform a hard reset by sliding and holding the power button for 15 seconds.
  6. If Kindle is still unresponsive, try charging Kindle before trying to restart the device once again.
  7. Make sure you have the latest software version available installed on your Kindle. The latest version is available here: www.amazon.com/kindlesoftwareupdates
Please let me know if I can assist you further.
Regards,
KYTechnology
Mar 01, 2011 | Amazon Kindle 3G
Amazon Kindle Paperwhite Logo
211 people viewed this question
Top Amazon Tablets & eReaders Experts
Lesley Cameron
Lesley Cameron
castletech
castletech
Martin Murray
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
