Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Frige cool freezer warm
Heard a zap type sound yesterday and today freezer was warmer and food was starting to defrost but stuff in frige is cold
    Top Expert:
  • Maytag Master
  • 9,472 Answers
IS the compressor running and is it hot?
Posted on Dec 08, 2012
  • 87 Answers
SOURCE: frige problem
This is almost a word for word common problem. On frost free fridge freezers of this type all cooling is generated through the freezer side and is merely forced into the fridge side through airflow. Therefore if you have a problem with the fridge you have a problem with the freezer section. The most likely cause is that the coil is frozen up. We would always suggest defrosting unit overnight in case it was simply a door left ajar being the cause of the fault. If the unit then pulls the fridge temp down and it was not the door ajar then you probably have a defrost problem (heater or defrost thermostat, or defrost timer). If it fails to pull the fridge temp down on restarting then it could be the fan or part of the defrost circuit or even possible the cooling circuit. The normal outcome after defrosting is that the temp will drop in the fridge due to air circulation improved, which will probably remain cool for 2-3 weeks until the coil becomes frozen again. On either result I would contact an engineer on the 2nd failure occurrs so that the engineer can establish the exact cause. Hope this helps.
Posted on Aug 28, 2007
SOURCE: MZD 2766GE refrigerator: freezer side is cold but refrigerator side gradually warms after a week and then freezer side warms.
fan won't start by itself.
Posted on Aug 10, 2008
  • 198 Answers
SOURCE: freezer working, not making ice; refrigerator not cooling
Look for excessive frost build up in the freezer, there may be a problem with the defrost cycle.
Posted on Jan 09, 2009
tomsat69
  • 219 Answers
SOURCE: Maytag Fridge MTB2156GEW Won't cool. Change thermostat today and ran it for four hours. Frige was warm after. There is a clicking noise every 2 to 5 minutes from the back of the fridge. I think it is
Yes you have a bad relay on your compressor.Remove the rear panel and take off the relay on the compressor shake it.If it sounds fried then you need to order new on .Just give your model# to your local parts depot and ask them to order you a new compressor relay hope i fixya:)
Posted on May 20, 2009
  • 49 Answers
SOURCE: Freezer is cold, main food compartment is warm
the evap fan probably stopped working because of the shorted defrost thermostat. if you remove the freezer drawer you will probably see frost build-up on the back wall. what you need to do is remove the back wall and manually defrost the coil with a hair dryer. have some towels handy. once the ice is melted you will need to replace the thermostat or this will happen again. you should buy a new thermostat before the repair so you know what you're looking for. hope this helps
Posted on Aug 20, 2009
A kenmore side by side model 106 5661 2500 has warm refer and cold freezer
If the freezer temps are normal and the refrigerator is warmer than normal, the the air flow from freezer to refrigerator is being hampered either by ice on the evaporator or the freezer is stuff in such a way that normal airflow between freezer and fridge is hampered. If the auto defrost is not working properly you will have warmer freezer temps and a relatively warm refridge. Check the defrost timer and defrost heater element.
Nov 26, 2013 | Kenmore 56612 Side by Side Refrigerator
I have a ge frige that the freezer works but frige is warm
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 01, 2011 | GE GTL18JBPBS Top Freezer Refrigerator
I have a Whirlpool refrigerator Model WBM 35 ix that is about 5yr old . The problem i am having is with the freezer. (the frige area stays cold) Some times the freezer will work and freeze food but i...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Apr 23, 2011 | Kitchen Ranges
Amana ars2464bs quit working overnight. Freezer may have been left ajar, all night. The motor is hot and a clicking sound can be heard every couple of minutes. Frige and freezer room temp.
Unplug and manual defrost This happens when warm moist air is drawn into refrigerator. It freezes as frost and confuses the motherboard or defrost timer and put a heavy strain on compressor.. You also have a defrost timer inside the fresh food compartment. It is possible you can run forward to force defrost=> 67001036 Defrost Timer turn timer with small flathead screwdriver slowly clockwise.Click Here=> ARS2464B Amana Refrigerator Control Parts List Part 711 in top left photo can be found in the control panel inside the fresh food compartment. Try that and let me know if this helped, Thanks, Sea Breeze
Click Logo below=>
Mar 21, 2011 | Amana ARS2464B Side by Side Refrigerator
My refrigerator is not staying cold...this just started to happen yesterday...it is warm today? The freezer is working fine? Help
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Dec 24, 2010 | Maytag MFD2561HE Bottom Freezer French...
I have condensation on the top in side of my frige that drips down and soaks my food
heatman101
Oct 19, 2010 | Whirlpool ER6AHKXPQ Top Freezer...
Frige not cooling, freezer is fine
its the problem of defrost timer.due to this the cold air from freezer section is not getting in to refrigerator section and its getting warm.check out the defrost timer.located beside the compressor at the back lower side of the unit.the cost of new defrost timer is near to $40.and you can get it from
www.repairclinic.com
thanks.
Jul 14, 2009 | Jenn-Air JFC2089HE French Door...
MAYTAG MZD2766GE SIDE BY SIDE
The freezer on top unit was keeping everything up top nice and cold, but the customer began to notice things in the fresh food section getting a little to warm. When the temperature selectors were adjusted to a colder setting, it seemed to help for a day or two, but then started getting warmer again. Sounding like a defrost problem, I paid this refrigerator a visit with hairdryer in hand, and parts in the van. Frost free refrigerators use a defrost heater to periodically assist with the melting of frost that builds up on the fins of the evaporator located in the freezer section. Frost forms each time the doors are opened to the unit, and the warmer, moist air from outside gets inside and heads toward the cold surface of the evaporator. As the frost continues to collect, the air passages in and around the evaporator start to close up and begin to prevent air circulation by the evaporator fan from the freezer to the fresh food section. As the cycle continues, the temperature in and around the evaporator will be cold, but the fresh food section will get warmer because warm air is not being exchanged with the colder air from above. The defrost sections of most units will consist of the same components. Namely, the heater itself, the bi-metal terminator, and the timer or defrost control. Each one of these components need to work properly for the defrost cycle to properly keep the unit frost free. On this unit, the timer could be advanced to begin a defrost cycle, but there was no current flow to the heater. After checking all connections and doing a quick resistance check of the circuit, I determined the bi-metal terminator had failed open. These bi-metal devices are used to prevent an overheating situation in the freezer section should the heater remain on to long. Once the trip temperature is reached, the bi-metal will open up a set of electrical contacts thus opening the circuit. Then when the unit cools back down to it's reset temperature, the contacts will again close, closing the circuit for the next defrost cycle. Because this bi-metal didn't reset, the circuit remained open and no defrosting took place. After using my trusty hairdryer and warm water squirt bottle to defrost the evaporator, I wired a new defrost terminator in line with the heater. With all the frost removed, the cold air started circulating again, and now everything within the fresh food section stays properly chilled.
Have a manual and can help you. Visit my site and enter your model number and part number in search feature. Click link below
http://servicepartstec.blogspot.com/
saebreezehvac@yahoo.com Thank You, Sea Breeze
Apr 02, 2009 | Maytag MZD2766GES Side by Side...
Compressor runs less frequently freezer warms between cycles
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,,
Mar 29, 2009 | GE Refrigerators
Warm frigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jun 14, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
93 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
