Question about HP Deskjet 3050 Wireless All-in-One Inkjet Printer, Copy/Print/Scan
HP 3050A won't load paper
A dog biscuit fell into the paper feed and I tried to print several times not knowing it was in there. Now one of the gears is loud and the paper won't feed properly. I keep getting the message to add paper. It's not going through unless someone stands there and holds one sheet at a time and feeds it.
  • ldhkah301 Dec 09, 2012
    It doesn't feed the paper through. You have to do one sheet at a time and hold the sheet of paper and "help it along." As a result, the margins aren't as they were formatted because when you're doing it manually, the feed is uneven.
checkitright
  • 1362 Answers
SOURCE: paper feed jam
it will give you a break if the tires are not worn out. Look and feel if they are smooth, if they are smooth and shiny then replace otherwise clean with alcohol.
good luck
Posted on Dec 12, 2007
checkitright
  • 1362 Answers
SOURCE: HP fax 1020
try cleaning with alcohol if it doesn't work then yes it needs to be replaced
Posted on Aug 12, 2008
SOURCE: sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Posted on Dec 12, 2008
biigg53566
  • 88 Answers
SOURCE: HP PSC 1510 All in One paper jams and wil not feed properly.
www.hp.com/support the people at HP have been very helpful to me try this and see what you get
biigg53566@gmail.com
Posted on Jan 07, 2009
  • 27 Answers
SOURCE: Fax double feeds sheets
This may occur if:
-the paper is too thick or too thin
-the roller mechanism is not properly aligned or has worn out
-the sheets of paper stick together
things you can try:
-unload the paper in the main tray and bend the stack of paper to loosen it up. Reload the paper to the main tray
Hope this helps!
Posted on Mar 05, 2009
Canon 4570dn squeals loudly when drawing from MP Tray
Hi
It sound like friction noises. it could be because of the rollers and lubrictaion on gears that got hard creating the noise and also produce strain on the feed motor . I would sugest a good service on all mechanical parts.
Dec 05, 2013 | Canon Office Equipment & Supplies
The paper jams coming out of the tray in the first set of feed dogs. Sometimes if i am printing more that one page the first sheet jame in the final set of feed dogs. I have to open back and pull sheet...
clean all the paths of the paper. maybe there are some paths are causing the jam. check also all gears on the path. check also the separator pad if it is worn out.
Jul 02, 2010 | Office Equipment & Supplies
Tried to feed envelope. Jammed. Printed two regular sheets that day after jam. Now, next time I turn on. Makes loud noise during warmup when rollers usually test their rolling. Same noise when I send print...
Beside you is broken drive seizing roller, here fault of the **** of the grapping or gear or electro relay. Persuasively - a repair for service this typical fault. Thank you
Sep 28, 2009 | Samsung ML 2010 Laser Printer
Paper does not feed - GRABS RIGHT SIDE
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Aug 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Lexmarkx73 Won't feed paper through while printing
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jul 13, 2008 | Lexmark X73 All-In-One InkJet Printer
Will not feed paper
Sounds like the gears are out of alignment for the paper pick up tray.
May 28, 2008 | Brother HL-2070N Laser Printer
Epson Photo RX600 error messages
Hi.
Check for a paper jam inside the paper feeder... There's something blocking the path that is why the 3-beep is activated. Also put lubricant to the head's round-bar, gears and levers.
Goodluck... Fixya me...
Feb 10, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Noisey vibration
Dear Rab,
Hope this solves your problem. I understand that you are having problem only on the reversei side tractor feed problem. We have encountered same problem even in different models and brands. Please check the Lever Paper Fed Selector is engaged well, so that the gears give less space clearance to each other. Please check the tractor tray is locked tightly both ends. Please check if the grease on the paper tray and contacting gears are not dried up. Please check also the paper path if there are remains or clogged parts of paper perforation holes. Finally check the flatten (stainless still or hard plastic) paper against the roller if not to tight. You can check manually by turning the paper roller knobs back and forth. But take NOTE: Turn Off the power in doing so, it may destroy the knob. Have a nice day.
Best regards,
Rosener Guyano
Feb 02, 2008 | Epson DFX-9000 Matrix Printer
Samsung ML 2510 printer won't feed paper
I have experienced the same problem . . . a little earlier this evening. I took all the inner components out, took apart the toner cartridge, I thought that the gearing was very hard to turn on it and on the inside of printer, paper feeding etc... and that is wear the loud noise is coming from. Out of desparation, I shook it to hear if anything internally was loose and there was and still is, I would not say its the best solution or by any means a permanent but you may be able to dislodge the debris from the gearing and be able to print. After it was dislodged from my printers gearing it has worked again. Though I believe it's temporary. I am looking for a guide or how-to on opening the printer casing to physically remove the debris. If you know of a guide let me know and I am sure it would help you too.
Nov 25, 2007 | Samsung ML-2510 Laser Printer
HP Deskjet 3050 Wireless All-in-One Inkjet Printer, Copy/Print/Scan Logo
59 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
